DWC 3.1.1
DWC 3.1.1 not compatible only javaScript
but displays only a and a bed if I deactivate it it displays everything ok bed plus two heaters, but it is not possible to use it all buttons blocked
thank you is there a solution ?
thats not DWC 3.1.1
TI RINGRAZIO , MA MI TROVO INDIFFICOLTA' A RICONOSCERE LA VERSIONE
E EVIDENTE HO ERRATO NELLISATLLAZIONE
you need to install this. https://github.com/Duet3D/DuetWebControl/releases/download/v3.2.2/DuetWebControl-SD.zip
best thing to do is delete the contents www folder from the sd and then unzip the contents of the above zip file into the www folder.
also you should update from 3.2 to 3.2.2 -
TI RINGRAZIO MOLTISSIMO , ORA NON POSSO FARLO PER IMPEGNO INDEROGABILE ,MA FRA 2 ORETTE CI PROVO , E TI OGGIONO SULLA RISOLUZIONE GRAZIE
ti chiedo perdono, ho provato solo ora, mi ha dato questo erroreYour Duet rejected the HTTP request: page not found
Check that the SD card is mounted and has the correct files in its /www folder proverò a rricipiare lo direttory www con il tua procedura -
@luca-Massimiliano said in DWC 3.1.1:
Check that the SD card is mounted and has the correct files in its /www folder proverò a rricipiare lo direttory www con il tua procedurasounds like you didnt extract the contents into the www folder
Extract the contents of this zip file into the /www folder on your SD card.
The error means that it can't find the DWC files.
The www folder should contain this:
└── www ├── css │ ├── Lumen.theme.css.gz │ ├── Sandstone.theme.css.gz │ ├── Slate.theme.css.gz │ ├── Superhero.theme.css.gz │ ├── United.theme.css.gz │ ├── bootstrap.theme.css.gz │ └── dwc.css.gz ├── favicon.ico.gz ├── fonts │ ├── glyphicons.eot.gz │ ├── glyphicons.svg.gz │ ├── glyphicons.ttf.gz │ ├── glyphicons.woff.gz │ └── glyphicons.woff2.gz ├── html404.htm ├── js │ └── dwc.js.gz ├── language.xml.gz └── reprap.htm.gz
Si l ho fatto ma devo verificare se tutto ok . sono sicuro che il procedimento indicato da te carissimo amico sia giusto , devo solo metterlo in pratica . ti ringrazio molto appena sarò sicuro ti do la conferma della nuovo dwc grazie buona serata.
sono rimasto a questo errore
With the SD card in the Duet send M122 and report the results here.
)1)non posso dare nessun comando .
quando estraggo il file zip dopo aver cancellato tutto ,non compare file dwc.json erore solito e' nessuna applicazione e concesso di usare la porta.)2) se estraggo il file zip previa svuotamento www rimane la versione precedente
)2) se estraggo il file zip senza svuotamento www rimane la versione precedente
posso fare m122 versione senza dwc3.1.1
lo ripete ciclo for nest una chiamata indirizzo diverso dall'attuale . scusatemi
difetti scheda improbabile
difetto ssd comprata nuova ieri pari alla vecchia
mi rimane la procedura ma identica alla vostra consigliata
problemi sistema operativo ,preciso originale .
chiedo aiuto se avete un caso analogo. grazie sempre gentilissimi -
When connected to USB terminal, send M122 and share the results here so we can see what it says about the SD card.
PRIMA DELL AGGIORNAMENTO
M122
=== Diagnostics ===RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
Board ID: 08DGM-917NK-F23T0-6JTD0-3S46T-TGA0F
Used output buffers: 3 of 24 (16 max)
Static ram: 23460
Dynamic ram: 72904 of which 0 recycled
Never used RAM 15716, free system stack 189 words
Tasks: NETWORK(ready,221) HEAT(blocked,309) MAIN(running,452) IDLE(ready,19)
Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
Last reset 00:02:07 ago, cause: power up
Last software reset at 2021-02-17 13:39, reason: User, GCodes spinning, available RAM 15680, slot 2
Error status: 0x00
Aux0 errors 71,71,71
MCU temperature: min 32.1, current 35.6, max 36.0
Supply voltage: min 11.3, current 11.4, max 11.5, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 62571, standstill, SG min/max not available
Driver 1: position 62571, standstill, SG min/max not available
Driver 2: position 62571, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-03-11 20:14:51
Cache data hit count 156303538
Slowest loop: 7.39ms; fastest: 0.20ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.7ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is ready with "M122 " in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is assembling a command in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 29.58ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address 84:0d:8e:b3:ae:3e
WiFi Vcc 3.42, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24912
WiFi IP address 192.168.178.105
WiFi signal strength -74dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 0 2 0 0 0 0 0 0
- WiFi -
DOPO AGGIORNAMENTO
20:18:53M122
Used output buffers: 7 of 24 (10 max)
Static ram: 23460
Never used RAM 15716, free system stack 199 words
Tasks: NETWORK(ready,245) HEAT(blocked,307) MAIN(running,466) IDLE(ready,19)
Last reset 00:00:23 ago, cause: power up
Error status: 0x00
Aux0 errors 18,18,18
MCU temperature: min 32.0, current 35.1, max 35.5
Date/time: 2021-03-11 20:18:50
Cache data hit count 27845843
Slowest loop: 14.50ms; fastest: 0.20ms
=== Storage ===
SD card longest read time 0.9ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
=== Network ===
Slowest loop: 28.05ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
WiFi flash size 4194304, free heap 25680
Socket states: 4 4 0 0 0 0 0 0
- WiFi -
E' UTILE PER CAPIRE?
