DWC 3.1.1
NON HO CAPITO . HO FATTO G 29 LA MACCHINA HA LAVORATO MA NIENTE GRAFIGO RAPPRESENTATO COME SI VEDE. UNA VOLTA HA FATTO GRAFICO CON UN G 29 POI NON PIU'
gives me this error Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT + 0100 (Central European Standard Time)
It sounds like you are missing a ; to commend out that line?
NON COMPRENDO SCUSA
MI HA MANDATO QUI NON SO SE HA IMPORTANA PENSO RIGUARDI LO SPESSORE E IL MATERIALE, DEVO CREARE UN FILE
Create a folder on your SD card called
menu
and another calledfilaments
Check your config files for that line. Some where there is a file that has that line and it's missing a
at the start to mark it as a comment. -
; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale)
; IN GONFIG.G OK
Check your config files for that line. Some where there is a file that has that line and it's missing a ; at the start to mark it as a comment.
What are you doing when that error message shows up?
HO FATTO MENU FILAMENT IN SD CARD
ECCO
SE TOCCO PIANO-SONDATO .CSV SI BLOCCA TUUO.
This post is deleted! -
DA L ERRORE QUANDO ARRIVA SUL PIATTO ED ESTRAE LA SONDA HO UN BBLTouch
Please post all your config files. config.g homeall.g homex.g homey.g homez.g homedelta.g bed.g deployprobe.g retractprobe.g
Do you have a file called mesh.g in the system folder?
no non ho la mesh.g G29 Esegui il file sys / mesh.g, o se quel file non viene trovato, esegui G29 S0 ho fatto cosi errore:
G29 S0
Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale)...ora confronto ifail detti da te config files. config.g homeall.g homex.g homey.g homez.g homedelta.g bed.g deployprobe.g retractprobe.g con i vecchi senza problema se non risolvo li posto ,
@luca-Massimiliano said in DWC 3.1.1:
RISOLTO
COME DICEVI TE NO ERA NASCOSTO NEL FILE DELOYPROBLE.G -
non penso sia correto,
VORREI USARE REPETIER HOST TRAMITE WIFI , NON SO COME FARE , MI PUOI INDIRIZZARE ?
I WOULD LIKE TO USE REPETIER HOST VIA WIFI, I DON'T KNOW HOW TO DO IT, CAN YOU ADDRESS ME?
I do not know how to use repetier host.
