    Motors for duet 2 wifi
    2.1k
    • mendeleviumundefined
      mendelevium @timcurtis67
      @timcurtis67
      What did you do for the heat-bed? Aluminum plate? I am a bit concerned about the possibility of warping with the heat pad under the plate and losing the flatness...
      timcurtis67undefined 1 Reply Last reply Reply Quote 0
        dc42 administrators @mendelevium
        @mendelevium said in Motors for duet 2 wifi:
        If I increase the feed like F1000, the motors will simply vibrate and whine and do not move
        Two likely reasons:
        1. You have set the acceleration too high in the M201 command.
        2. The combination of steps/mm of your machine, motor choice and supply voltage means there is insufficient supply voltage to drive the motor that fast. However, F1000 is a low speed, so that should only be the case if either your machine has a very high steps/mm value, or the motors have high inductance. Use the EMF calculator at https://www.reprapfirmware.org/ to check.
        This printer is one of two prototypes I designed and manufactured and spent much time with it. I wish to maybe market in the future.
        Definitely change to 24V power then.
          mendelevium
          my extruders/ Water cooling/ hot end ![2_1615555696051_160480591_174566437831827_872159458352239571_n.jpg](Uploading 100%) ![1_1615555696051_160220999_849863792229384_3326401001603109912_n.jpg](Uploading 100%) ![0_1615555696051_160103537_3967567926635363_6334736638490467259_n.jpg](Uploading 100%)
            @mendelevium, unfortunately the uploads attached to your last post failed. If you are using Chrome, try uploading them from Firefox instead - that's what I do when I have this problem [frequently].
            • timcurtis67undefined
              timcurtis67 @mendelevium
              @timcurtis67
              Here is what I use for my bed.
              https://www.midweststeelsupply.com/store/castaluminumplateatp5
              It is very stable when heating. I do have it leveled at 70C. I usually run anywhere from 60C-70C while printing. I used the 1/4" thick plate.
              mendeleviumundefined 1 Reply Last reply Reply Quote 0
                @timcurtis67
                The heat-bed plate looks great. What thickness did you manage to get. The thinnest I found was 5mm. It will be a bit heavier but with ball-screws it will be more powerful...
                  mendelevium
                  Some of the gear on my 3D printers. Everything manufactured in house, including the anodizing This is the Extruder I produced x 3 reduction, the water cooled hot end the water cooler.
                  I will load some more pics with the ball screws
                    @timcurtis67
                    I used a 1/4" thick plate for my build. 18" X 18" X .250"
                    That is a very nice looking extruder. Dual drive for the filament?
                      mendelevium @mendelevium
                      @mendelevium
                      I have received the steppers 60mm Nema 17 and changed the control for 24V. Runs ok and I am happy with the help you all contributed. Thank You
                        @mendelevium, I'm glad it's sorted now! I'll mark this as solved.
