    Berd air wired to bed heater.
    • Surgikillundefined
      Surgikill
      Hi all,
      I just got a berd air system. I have a 24V printer and I would like to wire the berd air up to my bed heater output. I believe I need a flyback diode on the motor.
      I have also read these threads:
      https://forum.duet3d.com/topic/5238/berd-air-pump-configuration-notes-for-duet-users/36
      https://forum.duet3d.com/topic/21925/mains-bed-pwm-frequency-flickering-lights/43
      It seems that running the pwm at a high freq (>20khz) will reduce noise. Will this pose any problems with the bed heater mosfet? I have a bunch of other heater mosfets I can use if the bed heater mosfet is not spec'd for this.
      What way does the flyback diode need to be run?
      Thanks.
        Details on the air pump?
        Surgikillundefined 1 Reply Last reply Reply Quote 0
          Which Duet?
            Based on his other threads I think Duet Wifi.
              Surgikill @Phaedrux
              @Phaedrux it's a 24V pump from makerhive. https://the-makerhive.myshopify.com/products/berd-air-max
              @dc42 Duet 2 wifi.
