Duet 3 Expansion Fan Output issue
418
  • undefined
    maddy
    I have a fan (F0) connected to Out6 of Duet 3 expansion, and trying to activate the fan thermostatically with heater (H1), which is the Out1 of the Duet 3 Mainboard.
    The fan F0 is not activated when the temp of H1 reaches the limit (T45), can somebody check the config.g file
    M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
    M308 S1 P"spi.cs0" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs0
    M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
    M308 S2 P"spi.cs1" Y"rtd-max31865" ; configure sensor 2 as thermocouple via CS pin spi.cs1
    M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
    M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M143 H2 S280 ; set temperature limit for heater 2 to 280C
    M308 S3 P"spi.cs2" Y"rtd-max31865" ; configure sensor 3 as thermocouple via CS pin spi.cs2
    M950 H3 C"out3" T3 ; create nozzle heater output on out3 and map it to sensor 3
    M307 H3 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M143 H3 S280 ; set temperature limit for heater 3 to 280C
    M950 F0 C"1.out6" Q500 ; create fan 0 on pin 1.out6 and set its frequency
    M106 P0 S0.5 H1 T45 ; set fan 0 value. Thermostatic control is turned on
    M950 F1 C"1.out7" Q500 ; create fan 1 on pin 1.out7 and set its frequency
    M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
    M950 F2 C"1.out8" Q500 ; create fan 2 on pin 1.out8 and set its frequency
    M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
    • undefined
      @maddy said in Duet 3 Expansion Fan Output issue:
      S0.5
      Can you try changing the S0.5 to S1. Perhaps it's trying to start up 50% power isn't enough to get it off and running. You could also try adding a B1 to the M106 P0 to give it a blip of full power for 1 second before going to 50% in case you want to have half speed for reduced noise or something.
      Does the fan work at all if you send M106 P0 H-1 S1?
      • undefined
        deckingman
        In addition to what @Phaedrux has said, a couple of other things come to mind. The first is your tool definitions which you haven't posted. What I mean by that is that by default, fan 0 is the part cooling fan and is normally non thermostatic. So unless you have mapped some other fan to a tool, then any M106 without parameters will try to control fan 0. It's generally easier to stick with the default protocol and define fan 0 as the part cooling fan, and other fans as thermostatic.
        The second thing that comes to mind is the frequency. Some fans simply don't play nice with PWM. I have some tiny blower fans and find that they work best with a PWM (the Q value) set right down low at 10 (Hz - you have 500).
        • undefined
          maddy
          @Phaedrux the fan works fine, I tried with code M106 P0 H-1 S1.
          @deckingman Tried with fan0 and fan1. The duet3 MB controlled fan 0 (connected to out7) thermostatically, instead out7 of the duet3 MB, now I want to use out6 of duet3 expansion for thermostatically controlling the fan0.
          The duet3 expansion fan terminals (out3-8) behaving strangely, what I mean is that the fan is always ON on most terminals (out3-8) even if they are not called in the config.g. Also, I tested all the terminals (out3-8) to fan0, one by one I enabled once in the config.g file, the fan is always ON in all cases even after disabling them in the config.g file. See the test config.g file, I tried to change the code 1.outX (X=3...8) in the Fans section(line 50 M950 code).
          This behavior could be due to the latest firmware? I recently got the expansion board (duet3 exp v1.0) and updated the firmware 3.2.2. What do you suggest?
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Mar 12 2021 18:57:07 GMT-0500 (Eastern Standard Time)
          M550 P"Duet 3" ; set printer name
          M569 P0.1 S1 ; physical drive 0.1 goes forwards
          M569 P1.0 S1 ; physical drive 1.0 goes forwards
          M584 X0.0 Y0.1 Z1.0 ; set drive mapping
          M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
          M92 X640.00 Y640.00 Z640.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X150 Y150 Z30 S0 ; set axis maxima
          M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin !io0.in
          M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
          M574 Z1 S2 ; configure Z-probe endstop for low end on Z
          M558 P5 C"^io7.in" H5 F120 T1800 ; set Z probe type to switch and the dive height + speeds
          G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
          M557 X15:150 Y15:150 S20 ; define mesh grid
          M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
          M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on
          undefined undefined 2 Replies Last reply 13 Mar 2021, 07:23 Reply Quote 0
          • undefined
            jay_s_uk @maddy
            fan is always ON
            I'm not surprised. you're setting the none thermostatically controlled fans to be on straight away. This is what the S1 does in M106
            • undefined
              deckingman @maddy
              @maddy
              How did you test the terminals? The positive pin will always be live because the MOSFET switches the negative side.
              I have my part cooling fans connected to out6 of an expansion board (board 2 in my case).
              This is the relevant part of my config.g file
              M950 F0 C"2.out6" Q10; fan 0, part cooling fan frequency 10 hz, connected to expansion board 2 out6 (12v)
              M106 P0 S0.0 H-1 C"Print Fan"; Set print cooling fan name, thermostatic control is turned off
              I've had to remove my part cooling fans temporarily but IIRC, they were working fine in RRF 3.2.2.
              Update. I've now refitted my part cooling fans, connected them to out6 on expansion board 2 and they work just fine (RRF 3.3Beta2)
              • undefined
                maddy
                Thank you @deckingman @Phaedrux @jay_s_uk your feedback is very helpful. After a couple of trials, I understood that the fan outputs of a board can ONLY be thermostatically controlled if they are linked to heaters of that board. For example, out6 of a duet3 expansion can only be thermostatically turned on if it is linked to the heaters (out0-3) of the expansion board in the M106 code.
                In my case, I have heaters on the mainboard and the fans on the expansion board (in the above code), I tried to thermostatically activate the fans linked to the mainboard heaters, but it did not work.
                I guess that the fan outputs have some kind of relationship with the heater outputs of a duet board, @dc42 can you please shed some light on this issue.
                On the other note, it was suggested that to use high current outputs of a board for waterpump/airpump to better handle the current requirements of the motors. I tried to use heater output(out0) of the duet 3 expansion board for the air blower, it did not work. Any feedback on this, please?
                undefined 1 Reply Last reply 14 Mar 2021, 02:45 Reply Quote 0
                • undefined
                  Phaedrux Moderator @maddy
                  Correct.
                  A thermostatically-controlled fan on an expansion board can only be controlled by a temperature sensor on the same expansion board.
                  https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations
                  • undefined
                    maddy
                    It is now working when the terminal connections are reversed. While connecting the airpump to the board I followed the Wiring diagram of Duet3 Expan 3HC, https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_3HC_Wiring_Diagram, the heater terminals on the board are opposite to the representation of the wiring diagram. I have the Duet 3 Expan 3HC V1.0 board.
                    1 out of 9
