    12864 Display Unresponsive on Preheat Page 3.3b2
    Beta Firmware
    906
    • JadonMundefined
      JadonM
      Good afternoon!
      I routinely use my set of display files (Github) for the 12864 display on my Duet Maestro, but recently the preheat page stopped working. When you open it the text is sometimes jumbled and it always freezes up the display. The easiest way to fix it is to simply reset the board. I did not edit the display code when the issue happened.
      I have two different machines with the issue (both Maestros, one with 3.2-RC2 and another with 3.2.2). Another user just reported on Github that he's having the issue as well.
      Below I've attached the code and also an M122 dump after it freezes. All other pages appear to work well.
      Thanks for your help!
      Jadon
      ; Duet 12864 Menu Files
      ; This is a set of menu files for running a 12864 display with a duet3D control board.
      ; Written by Jadon Miller - 2/27/2019
      ; Partially adapted from the work of tinkerlifeprojects on Github.
      ; File "preheat"
      ; The goal of this menu is to make it easy to preheat the printer. It
      ; has a group of buttons to set the temperature and the current temperatures
      ; at the bottom with a shortcut to print/resume.
      ; Note: To modify the preset temperatures, there are two places to change for
      ; each temperature. The "T" parameter determines what is shown on the button
      ; and the number after the "S" is the temperature sent to the firmware. For example,
      ; if I wanted to change the second bed heater button to 45C, I would change this line:
      ; button C46 W19 T"40" A"M140 S40"
      ; To this line:
      ; button C46 W19 T"45" A"M140 S45"
      ; The hotend buttons work the same way.
      ; Note: you may need to change the gcode commands for each button if you don't use the
      ; default heater configuration.
      ; --------------- Header ---------------
      text R0 C0 W63 F0 H1 T"Preheat"
      image L"imgs/vline.img"
      button W64 F0 T"Back" A"return"
      image R11 C0 L"imgs/hline.img"
      ; --------------- Preheat Bed ---------------
      image R14 C6 L"imgs/bed.img"
      button C23 W22 T"Off" A"M140 S0"
      button C66 W19 T"50" A"M140 S50"
      button C86 W19 T"60" A"M140 S60"
      button C106 W19 T"70" V3 A"M140 S70"
      ; --------------- Preheat Hotend ---------------
      image R27 C6 L"imgs/temp.img"
      button C23 W22 T"Off" A"G10 P0 S0"
      button C46 W19 T"130" A"G10 P0 S130"
      button C66 W19 T"200" A"G10 P0 S200"
      button C86 W19 T"210" A"G10 P0 S210"
      button C106 W19 T"230" A"G10 P0 S230"
      ; --------------- Print Button---------------
      ; The "print" button is shown when not printing and "resume" when paused.
      button R40 C0 W128 V5 T"Print" A"menu selectSD"
      button R40 C0 W128 V6 T"Resume" A"M24|menu main"
      ; --------------- Temperatures ---------------
      image R53 C0 L"imgs/hline.img"
      ; Bed Temperature
      image R54 C5 L"imgs/bed.img"
      value H2 N180
      text T"/"
      value N80
      ; Hotend Temperature
      image L"imgs/temp.img"
      value H2 N100
      text T"/"
      value N0
      M122
      RepRapFirmware for Duet 2 Maestro version 3.2-RC2 running on Duet Maestro 1.0
      Board ID: 08DJM-956DU-LLMS4-7JKD2-3S07J-1VPQJ
      Used output buffers: 1 of 24 (11 max)
      Static ram: 22292
      Dynamic ram: 73632 of which 24 recycled
      Never used RAM 18884, free system stack 216 words
      Tasks: NETWORK(ready,206) HEAT(blocked,340) TMC(blocked,117) MAIN(running,467) IDLE(ready,20)
      Owned mutexes:
      Last reset 00:06:22 ago, cause: power up
      Last software reset at 2021-03-11 07:40, reason: User, GCodes spinning, available RAM 18376, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU temperature: min 13.3, current 22.7, max 23.3
      Supply voltage: min 0.0, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, read errors 0, write errors 0, ifcnt 8, reads 63622, writes 8, timeouts 0, DMA errors 0
      Driver 1: position 0, standstill, read errors 0, write errors 0, ifcnt 8, reads 63622, writes 8, timeouts 0, DMA errors 0
      Driver 2: position 0, standstill, read errors 0, write errors 0, ifcnt 9, reads 63621, writes 9, timeouts 0, DMA errors 0
      Driver 3: position 0, standstill, read errors 0, write errors 0, ifcnt 8, reads 63622, writes 8, timeouts 0, DMA errors 0
      Driver 4: position 0, standstill, read errors 0, write errors 0, ifcnt 6, reads 63624, writes 6, timeouts 0, DMA errors 0
      Driver 5: position 0, assumed not present
      Driver 6: position 0, assumed not present
      Date/time: 2021-03-12 13:49:00
      Slowest loop: 81.19ms; fastest: 0.17ms
      === Storage ===
      Free file entries: 9
      SD card 0 detected, interface speed: 15.0MBytes/sec
      SD card longest read time 3.6ms, write time 0.6ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 129.51ms; fastest: 0.02ms
      Responder states: HTTP(0) HTTP(1) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8
      Interface state active, link 100Mbps full duplex
      === Filament sensors ===
      Extruder 0 sensor: ok
      Topherundefined dc42undefined 2 Replies Last reply Reply Quote 1
        Would you be able to test with 3.3beta2?
        JadonMundefined 1 Reply Last reply Reply Quote 0
        • JadonMundefined
          JadonM @Phaedrux
          @Phaedrux said in 12864 Display Unresponsive on Preheat Page:
          Absolutely! I can confirm that it behaves in exactly the same way. Here's another M122 dump:
          M122
          RepRapFirmware for Duet 2 Maestro version 3.3beta2 running on Duet Maestro 1.0
          Board ID: 08DAM-9F9GA-J24TD-6J9DL-3SW6K-T71YV
          Used output buffers: 1 of 24 (16 max)
          Static ram: 21348
          Dynamic ram: 74636 of which 0 recycled
          Never used RAM 19512, free system stack 210 words
          Tasks: NETWORK(ready,253) HEAT(delaying,335) TMC(notifyWait,116) MAIN(running,469) IDLE(ready,21)
          Owned mutexes:
          Last reset 00:06:26 ago, cause: power up
          Last software reset at 2021-03-06 11:14, reason: User, GCodes spinning, available RAM 18776, slot 0
          Error status: 0x00
          Aux0 errors 1,1,1
          MCU temperature: min 15.9, current 17.2, max 23.9
          Supply voltage: min 0.0, current 24.7, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, read errors 0, write errors 0, ifcnt 8, reads 64281, writes 8, timeouts 0, DMA errors 0
          Driver 1: position 0, standstill, read errors 0, write errors 0, ifcnt 8, reads 64281, writes 8, timeouts 0, DMA errors 0
          Driver 2: position 0, standstill, read errors 0, write errors 0, ifcnt 8, reads 64281, writes 8, timeouts 0, DMA errors 0
          Driver 3: position 0, standstill, read errors 0, write errors 0, ifcnt 9, reads 64280, writes 9, timeouts 0, DMA errors 0
          Driver 4: position 0, standstill, read errors 0, write errors 0, ifcnt 8, reads 64281, writes 8, timeouts 0, DMA errors 0
          Date/time: 2021-03-12 15:14:42
          Slowest loop: 79.93ms; fastest: 0.17ms
          === Storage ===
          SD card longest read time 3.6ms, write time 1.4ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = 1 -1, chamberHeaters = 2 -1
          Heater 0 is on, I-accum = 0.0
          Heater 2 is on, I-accum = 0.0
          Segments left: 0
          === Network ===
          Slowest loop: 30.73ms; fastest: 0.02ms
          HTTP sessions: 2 of 8
            Thanks. Moved to the beta firmware section.
              jay_s_uk
              odd, I use your menu system on the Fly-E3 running 3.3b1 (we don't have b2 yet) and haven't seen any issues reported.
              we haven't had any reports on our discord either
              • Topherundefined
                Topher @JadonM
                @jadonm did you ever figure it out? Ive got 2 machines on my bench testing the Fysetc 12864 display and Im seeing this issue only within the preheat menu. The text file looks ok and nothing seems out of the ordinary. its doing it on a duet3 mini and a duet 2. Both have the same symptom that can be cleared by resetting the board. Ill probably go in and delete one function at a time to see what is triggering this to happen.
                JadonMundefined 1 Reply Last reply Reply Quote 1
                • o_lampeundefined
                  o_lampe
                  @JadonM and @LeckieTech
                  Just for fun, you could make a special menu version, where the preheat menu is at top level/main page.
                  Just to see, if there are any sub-sub-menu out_of_mem/stack overrun issues.
                  • JadonMundefined
                    JadonM @Topher
                    @leckietech Unfortunately, I haven't figured anything out yet.
                    If you have the time to troubleshoot it, I'd greatly appreciate it! I'm simply too busy to work with it right now.
                    @dc42 Have you and your team had a chance to look into this? It's no rush, but my curiosity is getting the best of me! Thanks!
                      jay_s_uk @JadonM
                      @jadonm I can confirm we've since had a couple of reports on the STM32 port as well
                        dc42 administrators @JadonM
                        @jadonm, I have just reproduced this, although in my case I get a firmware reset when I select Preheat. I will find out the cause. We're in the middle of doing the 3.3beta3 release, so unfortunately it's probably too late to include the fix in this version.
                        Topherundefined 1 Reply Last reply Reply Quote 2
                        • Topherundefined
                          Topher @dc42
                          @dc42 said in 12864 Display Unresponsive on Preheat Page 3.3b2:
                          Im getting a firmware reset on the duet3 mini and duet2 wifi just has some menu freezing. Both are running 3.2.2
                            dc42 administrators @Topher
                            The problem appears to be the combination of these lines:
                            Image bed.img is OK, but temp.img is 13 pixels high, so when it is positioned starting on line 54 the last row overflows the display. RRF should detect this and truncate the image, but that's not working.
                            The menu works OK (apart from the display not being what was intended) if either R54 is replaced by R53, or temp.img in the second line is replaced by bed.img. Either way, the image no longer overflows past the last line of the 64-line display.
                            Edit: another fix is to replace the "Hotend temperature section by this:
                            image R53 L"imgs/temp.img"
                            value R54 N100
                            text T"/"
                            value H2 N0
                            I changed the row to 53 for the image, and set it back to 54 for the following text.
                            • JadonMundefined
                              JadonM @dc42
                              @dc42 Thanks a lot for your time! I really do appreciate it, and will update the repository soon with the fix for that bug in the display file.
                              dc42undefined 1 Reply Last reply Reply Quote 2
                                @jadonm, I have fixed the RRF code in the soon-to-be-released 3.3beta3.
                                Topherundefined JadonMundefined 2 Replies Last reply Reply Quote 1
                                • Topherundefined
                                  Topher @dc42
                                  @dc42 I just updated to the RRF 3.3 beta2 on the Mini5, im now not seeing the Display card under files anymore although the SD card files are still there. Any ideas? Screen Shot 2021-04-22 at 2.52.57 PM.png
                                    jay_s_uk @Topher
                                    @leckietech Theres a dropdown menu top left in system to switch to the menu/display files
                                    Topherundefined 1 Reply Last reply Reply Quote 0
                                    • Topherundefined
                                      Topher @jay_s_uk
                                      @jay_s_uk said in 12864 Display Unresponsive on Preheat Page 3.3b2:
                                      Ah, got it. Thanks, heres a photo for anyone stuck in the future:Screen Shot 2021-04-22 at 3.12.20 PM.png
                                      • JadonMundefined
                                        JadonM @dc42
                                        Wow! Your excellent support continues to amaze me! 😄
