Duet Wifi Controller Box
Just published this
https://www.thingiverse.com/thing:2481027
Obviously depends on your needs, but you can always adapt it.
That's really well done. Almost seems a shame mine is just hiding in the bottom of my delta printer.
This looks really good! Nice work.
I guess a Duex5 won't fit without modification? Do you have the native file so it can be moded?
If you want to fit a Duex5 as well, the one I designed might be of interest. I included the OpenScad files so it's be easy enough to tweak. https://www.thingiverse.com/thing:1859048
Nice! especially the light pipes using transparent filament.
I'll check it out.
Thank you.
Not sure about the Deux5 yet, I've got one for my new Idex project, but I'm still printing the printer parts. The issue would be that you cant use the light pipe version if the Deux5 is back to back. However thanks to a thought jog from Alexander Mundy on my thread https://www.duet3d.com/forum/thread.php?id=2157 I think I may have an answer using Fibre Optic, but it will be a couple of weeks before I have the design.
Sorry I cant publish OpenScad as I use a full CAD program, don't know if it can open other file types. I can export in DWG, STP, STEP, and a bunch of others, let me know if I can help further.
I use Solidworks so most 3D file types will work. Parasolid, IGES, SAT
Thank you,
STP files uploaded.
Thanks !
