    Watermark printing with M593 Input shaper? [obsolete]
    input shaper logo qr-code texture mapping watermark
    843
    • o_lampeundefined
      o_lampe
      I just came across the Input shaper M593.
      While I studied several calibration cubes for ringing, I noticed, that I had to turn the cube to the light to see the ringing.
      Why not misuse M593 to add some logo or image into the print surface!?
      The method to avoid ringing is to change acceleration.(DAA)
      If we'd force ringing at the right places, we could create a pattern, picture or logo. Maybe even a QR-code? Just need a preprocessor that chops a single track into various pieces and changes acc. to create the bumps.
      I'm sure this could also be done by embossing the surface of the part, but that would lead to a rattling and shaking printer.
      The shaper-mod would be more quiet and stealthy
      //edit I just noticed that watermark is the more common word.
        You mean like this?
        https://all3dp.com/2/velocity-painting-how-to-paint-your-3d-prints-with-style/
        o_lampeundefined JoergS5undefined 2 Replies Last reply Reply Quote 2
        • o_lampeundefined
          o_lampe @Phaedrux
          @Phaedrux
          Not exactly, but BETTER! 😀
          I've missed a lot, when I turned my back to 3D printing...glad I came back #thankstocovidlockdown
          • JoergS5undefined
            JoergS5 @Phaedrux
            @Phaedrux said in Watermark printing with M593 Input shaper? [obsolete]:
            You mean like this?
            This is from my point of view a very good example to transform a 3d printing disadvantage (layer bulges) into something positive. Maybe one can invent more such ideas. E. g. using ringing for a positive effect.
            For house printers, the bulges are advantageous because walls are easier to plaster.
            • o_lampeundefined
              o_lampe @JoergS5
              @JoergS5
              I played around with velocity painting, but the effect it had on a surface is minimal. At least with a 0.8mm nozzle and the yet unchanged jerk/acc and e-steps settings. There's not much information about the GUI or a tutorial for specific setup.
              I guess, it's another roll of filament I'll spend until I've dialed it in.
              Although their pictures in the web are quite nice.
              JoergS5undefined 1 Reply Last reply Reply Quote 0
              • JoergS5undefined
                JoergS5 @o_lampe
                @o_lampe nice that you're back to the 3d community. Let's discuss wire based printers 😉
                o_lampeundefined 1 Reply Last reply Reply Quote 2
                • o_lampeundefined
                  o_lampe @JoergS5
                  @JoergS5 said in Watermark printing with M593 Input shaper? [obsolete]:
                  I've made an Aramid wire-driven XY plotter lately and where ever I can, I use the dual roller constrain-method to avoid racking axis'...
                  • JoergS5undefined
                    JoergS5 @o_lampe
                    @o_lampe in summer I'll have to paint a wall, a wire based hangprinter would be perfect for this. I am thinking about it...
                    • o_lampeundefined
                      o_lampe @JoergS5
                      @JoergS5
                      Ahhh, the ** Hangprinter**!
                      It actually made it in the hall of fame by getting a dedicated kinematic profile in RRF.
                      Not sure if it can paint outside of it's own print envelop?Or do you have plans on mounting it horizontally? 😉
                      • JoergS5undefined
                        JoergS5 @o_lampe
                        @o_lampe the "nozzle" (the brush) can have an offset to the position - and so being outside of the construction - , so one has only to change this offset to plus/minus at the edges to get the necessary offsets. But I am currently at the idea stage, not further (no prototypes, nothing).
                        (not my house, unfortunately 😉 but interesting use case, to paint the correct regions, some camera data involved)
                        • o_lampeundefined
                          o_lampe @JoergS5
                          @JoergS5
                          Let's get crazy and build a giant inkjet printer to spray grafitis and other Art on House Walls 😁
                          • JoergS5undefined
                            JoergS5 @o_lampe
                            @o_lampe that's a good idea, and then go viral and make a challenge!
                            • o_lampeundefined
                              o_lampe @JoergS5
                              @JoergS5
                              Banksy! Here we come...
                              • o_lampeundefined
                                o_lampe
                                Back to topic...
                                I designed a panorama frame and tried transparent PETG. It seems, Velocity painting doesn't like Arc Welder, or pressure advance, so I switched both off and got a pretty good result.
                                The frame is on thingiverse
