    PID Tuning help needed
    2.3k
      droftarts administrators @deckingman
      @deckingman Yes, read the whole thread. @Reefwarrior said "The graphs show spikes". While I'm sure the heater can create a spike up in temperature, it probably can't create a drop as quickly! But a dodgy thermistor can, though I guess it could be a power drop across the board when the heater switches on, if the PSU isn't up to it.
      @Reefwarrior A screenshot of the temperature graph misbehaving would go some way to disambiguate the cause of the "spikes". Try wiggling the thermistor wires, see if that causes the spikes, too.
      • deckingmanundefined
        deckingman @droftarts
        @droftarts I guess it depends on the definition of "spike". I read this (quote)
        Other strange thing is, there are quite a lot of oscillations with regards to the temperature being sensed. (Up to 3 to 4 degrees up and down)
        As you say, we need a picture of the graph......
          A picture of the graph would be nice, but don't don't run that 12v heater at 24v just to make a graph for us. You're liable to melt something. Just replace the heater with a 24v version before you do anything else.
          • Reefwarriorundefined
            Reefwarrior
            Hi all,
            OK so I swapped the cartridge for a 24V one. Did the PID tuning... results:
            Warning: heater behaviour was not consistent during tuning
            Auto tuning heater 1 completed after 4 idle and 25 tuning cycles in 1494 seconds. This heater needs the following M307 command:
            M307 H1 R3.064 C165.3 D10.06 S1.00 V24.3
            Send M500 to save this command in config-override.g
            Bothers me a bit with the 'warning'. Also it seems the temperature sensing thing is a PT1000 I think? It's a little silver cylinder that connects directly to the board, no daughterboard. Chinese brand.
            https://imgur.com/p5oTiy3
            there is the picture that I am referring to. Look at both the blue and the red - the curves are not smooth - it's like jagged. Even the 'MCU Temperature' seems to oscillate by about 1 degree up and down (including the decimals....)
            Also got this after PID tuning my bed:
            Auto tuning heater 0 completed after 4 idle and 25 tuning cycles in 1536 seconds. This heater needs the following M307 command:
            M307 H0 R1.369 C277.3 D5.29 S1.00 V24.2
              Phaedrux Moderator @Reefwarrior
              @Reefwarrior said in PID Tuning help needed:
              Why do you think Pt1000? It could be a plain thermistor.
              Photos?
              Yeah that graph looks a bit fuzzy which would explain the warning.
              The overall curve of the graph looks ok though, so I think the values it provides should be usable.
              Perhaps a good time to replace the temp sensor with something better quality.
              Reefwarriorundefined 2 Replies Last reply Reply Quote 0
                Reefwarrior @Phaedrux
                @Phaedrux Unfortunately I am not in a position to be able to do that. I'm one of 70 pilots that got retrenched when our government decided to liquidate the national airline.
                  I'm not sure that that means, but if you want to continue to roll with the equipment on hand, you can verify that the tuning results are accurate by setting a printing temp and seeing if the graph and reported temps are stable.
                  The fuzziness in the graph may also be a result of noise from running near other cables. You could verify that by temporarily isolating the thermistor wiring and seeing if that makes a difference.
                    @Phaedrux hi, yeah it's a plain thermistor NTC 100k; 3950B.
                      droftarts administrators @Reefwarrior
                      NTC 100k; 3950B
                      These are known for being pretty cheap, poor thermistors, which might explain your fuzzy readings.
                        Reefwarrior
                        Ok, seems I got it fixed, somehow. Next issue is now the heatbed....
                          Reefwarrior
                          Ok, bed issue solved too. Seems the algorithm is too sensitive in my case.
                          How do I mark this as 'SOLVED' ?
