    Mosquito hot end fan
    18
    867
    • gpermanundefined
      gperman
      This topic has been covered but the solutions in other threads did not seem to solve my problem.
      The pitch and tone of the fan is so shrieking that it's headache inducing after a very short period of time.
      I tried:
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 C"fan1" S.7 H1 T45                     ; set fan 1 value. Thermostatic control is turned on
      as per Mosquito's suggestion but the fan just sits there and jiggles (struggles) with any other setting other than S1. Not sure why I can't seem to PWM the fan down. I tried all the way down to 6KHz (Q6) and S.7 which made the fan pulse like it was speeding up then slowing down. any other S setting the fan just turned off.
      24v fan in 24v system duet2wifi
      • fcwiltundefined
        fcwilt @gperman
        @gperman said in Mosquito hot end fan:
        Just FYI the Q parameter is in Hz not kHz.
        As to the speed setting I think mine works ok but I will need to check it to be sure.
          Try adding B1 to the M106 line that would blip it to full power for 1 second at startup.
          Try Q100 or even Q10000 (and places in between.
          • gpermanundefined
            gperman
            Tried B1, that didnt affect anything.
            Tried Q6-50000 at various points, probably about 40 or so random points. 10000 was the only frequency that affected a change and it only allowed S1-S0.7, S0.6 shut the fan off. At Q50000 the fan just ran 100% at all speed points.
            Even at S0.7, it's still screamingly loud. I have a feeling even if I slowed it down to S0.3 it'd still be too loud.
            Aside from having a 0.06w 24v box fan on order (mosquito is 0.1w) I'd still like to get the speed function working properly.
            Phaedruxundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @gperman
              That's more a factor of the fan itself than anything. Some fans take well to it, others not so much.
              • MartinNYHCundefined
                MartinNYHC
                This works for me:
                M950 F1 C"out4" Q500
                M106 P1 C"Hotend" L0.75 X0.75 H1 T70 S0.75
                gpermanundefined 1 Reply Last reply Reply Quote 0
                • o_lampeundefined
                  o_lampe @gperman
                  @gperman
                  Maybe the fan is defect or the housing is bent?
                  • gpermanundefined
                    gperman @MartinNYHC
                    @MartinNYHC
                    Just tried this, didnt work either. Not sure whats up. Going to replace the fan and see what that does.
                    Attached the fan to my variable DC power supply and dialed it down to 12v and it worked fine with that. I dont think the pin output on the Duet is voltage variable though.
                      No, not exactly. PWM control means the voltage is the same, but it's only applied in short durations. Pulse width modulation. So we are modulating the width of the pulses of voltage over a time slice, ie at the frequency chosen.
                      You could try adding a resistor to the + leg and run it at a reduced voltage that way.
                      Also try a different fan port to see if the behaviour is any different there.
                      • gpermanundefined
                        gperman
                        The resistor thing would be a last ditch effort IMO. Figuring out why the fan cant change speeds via PWM is the main objective. I'm wondering if the people contributing config code have a mosquito fan or another.
                        I switched connector to fan2 output and the behavior was the same. I'll try another fan. I'll try and contact mosquito and see what they say about their fan, pwm and freqency.
                        hackinistratorundefined arhiundefined 2 Replies Last reply Reply Quote 0
                          As efficient as the mosquito cold end is I'm surprised they went with such a typhoon of a fan.
                          • hackinistratorundefined
                            hackinistrator @gperman
                            @gperman those fans have electronics inside . not all fans can accept pwm signal .
                            can it run from on board 5v or is it too low ?
                            you can also try adding small electrolytic capacitor in parallel with the fan and try is with S0.7
                            gpermanundefined Egon.Netundefined 2 Replies Last reply Reply Quote 0
                            • gpermanundefined
                              gperman @hackinistrator
                              @hackinistrator
                              It seemed fine at any voltage when modulated that way. Now, I'm not sure what speed it will be best at for printing. Havent gotten to that point yet. I might be able to install a variable DC board with a pot that sticks out of the electrical enclosure to play with it manually since it doesnt seem the duet can do it electrically.
                              Then again, perhaps the new fan en route will be more cooperative.
                              • arhiundefined
                                arhi @gperman
                                There are 2 type of fans that does not play well with speed control.
                                The first set of fans will change the speed but will fail quickly, rattle, and have another type of problems as they are designed only to run at full speed. Typical example are fans with "air bearing", they are quiet and last a very long time but must run at 100% speed. If you drop the speed (by any mean, pwm or lower voltage or...) they will not last long (dropping speed to 50% usually make them last less than 10% of their life time in my experience). So while these fans will often behave ok when you try to pwm them, you should not and you should use other fans. They are good option only for hotend cooling, not for part cooling where you want to vary them.
                                Second set of fans will not work at all or will work "weird" (strange noises, blocks..) and for them the problem is just the type of bldc controller inside the fan that does not play well with PWM ... Sometimes you can solve it by providing lower voltage to them but that also reduce the lifetime of the fan so also this fan is ok only for running at 100%. Sometimes you can "force" this type of fans to work with PWM by varying the PWM frequency, sometimes going very low with PWM frequency will make them work ok, but usually lowering the pwm freq. will also produce audible noise from the fan that I'm sure you want to avoid
                                Most 3 wire fans are ok with PWM input, good brands will have in datasheet if they are pwm-able or not, 4 wire fans are also 99% working with pwm on the voltage input (they are actually expecting to receive speed control signal on the 4th wire, but will usually accept pwm on the voltage too). Small 25, 30, 40mm 2 wire fans very often come with driver that does not support pwm input.
                                gpermanundefined 1 Reply Last reply Reply Quote 1
                                • gpermanundefined
                                  gperman @arhi
                                  @arhi
                                  good info, thanks.
                                  so for the hot end cooling fan: good practice is to find what kind of cooling is necessary for filaments you plan to use and stick with that, hopefully it's quiet.
                                  I'm confused as to why the duet2 board only provides 2 wire fan outputs and pwm control when primarily only 3 and 4 wire fans are PWM'able. That makes it difficult to modulate the part cooling fan properly.
                                  arhiundefined 1 Reply Last reply Reply Quote 0
                                  • arhiundefined
                                    arhi @gperman
                                    In my experience the more you cool the hotend the better. You cant cool it too much, only too little. Especially with mosquito, you can't go wrong with a lot of cooling of the cold part of the hotend.
                                    Because 3 wire fan uses 3rd wire (yellow commonly) to report back the RPM so you just cut that third wire and use the two (red/black) to power and pwm the motor. Since duet don't really care what real rpm of the fan is they don't waste cpu power to count the impulses from the third wire.
                                    The 4 wire fan you could connect to duet but imho it's a waste of money as 4 wire fan's in small sizes are expensive as hell if you can even find them. You would connect the GND (black) and 12V (usually yellow or red) to GND and 12V directly, the third "sense" wire that reports RPM you again cut off and don't use (it is usually green or white) and fourth wire that's pwm control wire (usually blue) you connect to duet's pwm output (ground of the fan connector) with a 10k pullup resistor to 12V
                                    So, 3 wire, you just dump the third wire and 4 wire you either use only first two and it works or you use the three + resistor so no need really for any changes on the duet 🙂
                                    • Egon.Netundefined
                                      Egon.Net @hackinistrator
                                      I have the very same problem with many fans, and my solution was converting PWM to an analog voltage. If you can (so it seems) use a high enough PWM frequency, an inductor-capacitor lowpass (inductor from V+ wire from Duet, capacitor parallel to fan) could be a solution. For cases where PWM frequency can't be adjusted (Duex5) or when needing more control, I designed a small board:
                                      https://forum.duet3d.com/topic/21680/designing-a-pwm-to-analog-mini-board-for-fans
                                      @hackinistrator said in Mosquito hot end fan:
                                      If you just use a capacitor, the PWM pulse will charge the capacitor completely, and you loose regulation capability. It'd probably run at 100%RPM from 100%PWM to... ¿50%? PWM and then almost stop. There might be a very small window of regulation when PWM period is small enough not to charge the capacitor completely and discharge through the fan, but that's a lottery and seldom works. You need to use a current control device (inductor, or even a resistor) and form a lowpass.
                                      hackinistratorundefined 1 Reply Last reply Reply Quote 0
                                        hackinistrator @Egon.Net
                                        @Egon-Net you are right, its trial and error. I've done it before many times, but i use scope, which makes it much easier.
