    How is the “Height Map” Used?
    4.4k
    • tmeryhewundefined
      tmeryhew
      I’ve looked around online and see a lot of helpful information on how to set up a z probe and get all of that dialed in.
      But can someone explain to me just how and when exactly the height map is used? Is it automatic? Do I need to reconfigure printer settings in my slicer?
      Thanks in advance!
        This may help: https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
        tmeryhewundefined 1 Reply Last reply Reply Quote 0
        • tmeryhewundefined
          tmeryhew @Phaedrux
          @Phaedrux I read through that page. I'm still not understanding what is actually being done with the height map once it is created and stored.
          Any idea what the process is for how the data points are incorporated into a file that is being printed? I just want to confirm that its actually being used to improve my first layers.
          Here is my start Code:
          G28 ;Home
          G29 ; Auto Bed Leveling
          G92 E0 ;Reset Extruder
          G1 Z2.0 F3000 ;Move Z Axis up
          G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
          G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
          G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
          G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
          fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • tmeryhewundefined
            tmeryhew
            • fcwiltundefined
              fcwilt @tmeryhew
              @tmeryhew said in How is the “Height Map” Used?:
              G28 ;Home
              The action of the height map and how it is used for mesh compensation is fairly simple.
              For each grid point on the height map the firmware can read from the height map file how much above or below the reference point (see G30) that grid point is.
              For any XY position that information can be used to determine how much above or below the reference point the point at that XY position is.
              So using that ability when printing the firmware, based on the current XY position, "tweaks" the Z position based up or down as needed to better follow the irregularities of the bed.
              The height map needs to be loaded and mesh compensation enabled for that all to happen.
              If you want to see it in action in a very clear way I could send you a 4 point height map using extreme height variation from left to right such that when you jogged the X axis from its min value to its max value you can clearly see the Z position being "tweaked".
              • tmeryhewundefined
                tmeryhew @fcwilt
                @fcwilt so looking at my start code I posted above, am I doing this right?
                Are there any additional steps I need to take to ensure this is being incorporated into my first layers?
                Thanks for responding and giving more info. I really appreciate this. I feel like I am either there, or damn close.
                • fcwiltundefined
                  fcwilt @tmeryhew
                  Well I'm not sure what you are doing with the extruder there - priming it I guess?
                  In any case to use the height map you need to do two things at the start of the print
                  1 - set the Z=0 datum
                  2 - load the desired height map
                  To do this you need the following commands in your start code before any commands that try to print;
                  G90
                  G1 Xaaa Ybbb Fccc
                  G30
                  G29 S1 or G29 S1 P"name_of_height_map_file.csv"
                  The G90 insures you are in absolute positioning mode for the following G1 command.
                  The G1 command is needed to move the Z probe (not the nozzle) to the center of your bed. The values aaa and bbb you have to compute so that the Z probe ends up at the center of your bed. The value ccc sets the move speed to whatever speed you wish.
                  The G30 command probes thebolded text bed and sets the Z=0 datum that is needed to load the height map.
                  The G29 S1 will load the height map file using the default file name heightmap.csv. To load any other heightmap you use G29 S1 with the P parameter specifying the name of the file.
                  Remember when creating and when loading a height map the Z=0 datum must be set first and it must always be at the same XY position and the best XY position is the center of the bed.
                  If that is not clear just let me know.
                    Phaedrux Moderator @tmeryhew
                    G28 ;Home
                    If this is your start gcode it should be good to go. We would need to see what is in your homeall.g first to make sure that the Z0 is being set by the probe with G30.
                    If you want to do a fresh heightmap each time, G29 by itself is what you want. If you want to load a saved heightmap from the last time you did a G29, you would use G29 S1.
                    So what you have now should work to enable mesh compensation during your print. You can verify if it's enabled by sending M122 in the console and looking for the line that says "compensation in use: mesh"
                    • tmeryhewundefined
                      tmeryhew @Phaedrux
                      • tmeryhewundefined
                        tmeryhew
                          Ok so your homeall is using endstop homing for Z instead of the probe.
                          This section
                          G1 H1 Z-305 F360
                          G90
                          G92 Z0
                          Should be replaced by
                          G90 ; absolute position
                          G1 X150 Y150 F6000 ; move probe to bed center
                          G30 ; probe the bed
                          But you haven't shown us your config.g yet, so I'm not actually sure you have a probe configured. What probe do you have? Does it work?
                          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                          • tmeryhewundefined
                            tmeryhew @Phaedrux
                            @Phaedrux
                            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Mar 19 2021 21:41:05 GMT-0700 (MST)
                            M550 P"Genesis"                                    ; set printer name
                            M551 P"shatner1"                                   ; set password
                            M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
                            M569 P0 S0                                         ; physical drive 0 goes backwards
                            M569 P1 S0                                         ; physical drive 1 goes backwards
                            M569 P2 S1                                         ; physical drive 2 goes forwards
                            M569 P3 S0                                         ; physical drive 3 goes backwards
                            M584 X0 Y1 Z2 E3                                   ; set drive mapping
                            M92 X80.00 Y80.00 Z400.00 E105.00                  ; set steps per mm
                            M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                            M203 X12000.00 Y12000.00 Z240.00 E1200.00          ; set maximum speeds (mm/min)
                            M201 X800.00 Y800.00 Z800.00 E250.00               ; set accelerations (mm/s^2)
                            M906 X1200 Y1200 Z1200 E1200 I30                   ; set motor currents (mA) and motor idle factor in per cent
                            M208 X300 Y220 Z300 S0                             ; set axis maxima
                            M574 X1 S1 P"^xstop"                               ; configure active-high endstop for low end on X via pin ^xstop
                            M574 Y1 S1 P"^ystop"                               ; configure active-high endstop for low end on Y via pin ^ystop
                            M574 Z1 S1 P"^zstop"                               ; configure active-high endstop for low end on Z via pin ^zstop
                            M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
                            M558 P9 C"^zprobe.in" H5 F240 T12000               ; set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X-45 Y-7 Z2.345                            ; set Z probe trigger value, offset and trigger height
                            M557 X15:215 Y15:195 S20                           ; define mesh grid
                            M308 S0 P"bedtemp" Y"thermistor" T98801 B4185      ; configure sensor 0 as thermistor on pin bedtemp
                            M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
                            M143 H0 S100                                       ; set temperature limit for heater 0 to 100C
                            M308 S1 P"e0temp" Y"thermistor" T98801 B4185       ; configure sensor 1 as thermistor on pin e0temp
                            M143 H1 S250                                       ; set temperature limit for heater 1 to 250C
                            M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                            M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                            M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                            M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
                            M501                                               ; load saved parameters from non-volatile memory
                            T0                                                 ; select first too
                              Ok looks like you have a bltouch. If it's working, you should be able to change the homeall as I indicated above, and it should start using the probe to home Z, and with your slicer start gcode it should home XYZ and then generate a new heightmap and it should be active during the print.
                              • tmeryhewundefined
                                tmeryhew
                                ; homeall.g
                                ; called to home all axes
                                G91 ; relative positioning
                                G1 H2 Z5 F12000 ; lift Z relative to current position
                                G1 H1 X-305 Y-225 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
                                G1 H2 X5 Y5 F12000 ; go back a few mm
                                G1 H1 X-305 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                G90 ; absolute positioning
                                G1 X150 Y110 F6000 ; move probe to bed center
                                G30 ; probe the bed
                                ;G91 ; relative positioning
                                ;G1 Z5 F200 ; lift Z relative to current position
                                ;G90 ; absolute positioning
                                • tmeryhewundefined
                                  tmeryhew
                                  And to clarify, yes it appears to be working. I can definitely generate a height map. Are there other things I should be looking for to confirm its working?
                                  Other than obviously not crashing into the bed.
                                    The best way to test is to print a first layer test print twice. Once with G29 in the start gcode, and again with G29 S0 in the start gcode to disable it.
                                    Something like this file works well.
                                    bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
                                    I think the missing piece of the puzzle in your case was not using the probe to home z.
                                    tmeryhewundefined 2 Replies Last reply Reply Quote 1
                                    • tmeryhewundefined
                                      tmeryhew @Phaedrux
                                      @Phaedrux thank you so much. You guys really know your stuff. I'll go ahead and work on this right now.
                                      How can I save/export all of my settings as a JSON once I have it dialed in?
                                        You can back up the .g files in the /sys folder of your SD card.
                                        From DWC, go to the system tab, there is a check box above the list of files, click it to select all the files, then right click on the file list area and select "Download as zip" to save all the files there as a zip file on your computer.
                                        Then if you ever needed to restore the configuration to that point you could upload that zip file again to the system tab. Or extract it and upload a particular file you want.
                                        tmeryhewundefined 1 Reply Last reply Reply Quote 1
                                        • tmeryhewundefined
                                          tmeryhew @Phaedrux
                                          I've gone in and made the changes you describe. I am running the file you sent as we speak. I sent M122 and this was the result.
                                          Should my "comp offset" be 0.000? Does this mean anything?
                                            No the important thing is that it indicates the mesh is loaded.
                                            It should be moving the Z axis to compensate for the surface of the bed now.
