    Looking for PCB designer with spare time :)
    Off Topic
    486
    • o_lampeundefined
      o_lampe
      Hi guys, this is not an employment add.
      Just need help with a small PCB that translates stepper-commands for DC-motor w. encoder
      The prototype is already working (with interupt control for quadrature encoder and without). The original idea was to squeeze it into the pololu stepper driver compatible form. That would require double sided part-population and at least 4 layers. Too much for Eagle-hobbyusers like me.
      For the above linked N20 motor it would be different. Could be an In-Line PCB that sits on the Encoder connector along the motor/gearbox. Input would be two connectors for DC-power and the usual 4-wire stepper-extension cable.
      If you're interested, contact me here for details.
      • Martin1454undefined
        Martin1454
        Do you already have a complete schematic?
        • o_lampeundefined
          o_lampe @Martin1454
          @Martin1454
          I don't have a schematic, but I can write a BOM and Netlist. The design is already 2 years old, I have to digg into the details again.
          Currently I have problems with login (spawn ENOMEM-error).
          We should contact via email. olaf-lampe {at} gmx de
          Thanks in advance
          Olaf
          zaptaundefined 1 Reply Last reply Reply Quote 0
          • zaptaundefined
            zapta @o_lampe
            @o_lampe said in Looking for PCB designer with spare time 🙂:
            That explains why you mentioned Eagle rather than Kicad, the current favorite in Makers circles. 😉
            • o_lampeundefined
              o_lampe @zapta
              @zapta
              Thanks for the tip!
              I guess every free software has some restrictions, what about KiCad?
              • oliofundefined
                oliof @o_lampe
                @o_lampe KiCAD is open source (see https://kicad.org/about/licenses/ for details), and it seems to provide the four freedoms of open source software for all it's components unless I have missed something.
                zaptaundefined 1 Reply Last reply Reply Quote 1
                • zaptaundefined
                  zapta @oliof
                  I believe that the Duet's boards were designed with Kicad.
                  oliofundefined 1 Reply Last reply Reply Quote 1
                  • oliofundefined
                    oliof @zapta
                    @zapta That's correct.
