    Sinking vs Sourcing Alarm Output Pin Connection to Duet WiFi
    379
    • dieguitoundefined
      dieguito
      I need to wire an alarm to a drive to the Duet WiFi. Which would be the best pins to connect the alarm to and should I use a sourcing or sinking output?
      Thanks in advance!
        Use a sinking output.
        dieguitoundefined 1 Reply Last reply Reply Quote 0
        • T3P3Tonyundefined
          T3P3Tony administrators @dieguito
          @dieguito said in Sinking vs Sourcing Alarm Output Pin Connection to Duet WiFi:
          If you have a free endstop you can use that (along with a trigger macro to take an action when the pin changes state).
          www.duet3d.com
          CNCModellerundefined 1 Reply Last reply Reply Quote 0
          • dieguitoundefined
            dieguito @dc42
            @dc42 can ALM connect to ENC_A in the CONN_LCD header? What does COM0 connect to?
            • CNCModellerundefined
              CNCModeller @T3P3Tony
              @t3p3tony said in Sinking vs Sourcing Alarm Output Pin Connection to Duet WiFi:
              So I'm fitting a household fire alarm and solenoid activated co2 fire extinguisher to my large printer once I've built the enclosure. That is assuming I don't get random alarms from just the print fumes.
              Should I / can I use an endstop input and a macro to trigger a shutdown equivalent to power failure, before disconnecting the mains power?
              Any constructive thoughts would be great.
              Cheers
              Barry M
              Polar Duet3 Mini + 1HCL
              https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
              Wanhao D4S: Duet2
              https://forum.duet3d.com/post/296755
              K40 Laser, Duet2
              https://forum.duet3d.com/post/312082
              Wanhao D5S
              https://www.youtube.com/CNCModellerUK
                Phaedrux Moderator @CNCModeller
                @cncmodeller said in Sinking vs Sourcing Alarm Output Pin Connection to Duet WiFi:
                Do you mean to save the position for power loss recovery? Simply using the pause command should allow for the same data to be saved.
                  CNCModeller @Phaedrux
                  Thanks @phaedrux
                  Wanhao D4S: Duet2
                  K40 Laser, Duet2
                  Wanhao D5S
                    dc42 administrators @dieguito
                    The CONN_LCD pins have no input protection at all, so I don't recommend a direct connection. A simple and safe alternative would be to use an opto isolator and a couple of resistors.
