    M83 Problem
    560
    • Heartleander81undefined
      Heartleander81
      Hi guys. I should have a question about absolute and relative extrusion. When I have the sartcode in cura, the relative extrusion goes. if I have the start code as a file on the Duet3 6hc only absolute extrusion is possible. Because with relative the extruder no longer rotates, it just doesn't retract anymore Do not get the relative M83 to run.
      Startcode
      T0
      M116
      M501
      G4 S30
      M98 P"/macros/LED/LED_gruen"
      G32 		;True Bed Leveling und Meshbedleveling
      G29 S1 P"heightmap.csv"
      G1 X5 Y2 Z5 F4500.0
      G1 Z0.4
      G1 E20 F200
      G1 X200 E45 F600
      G92 E0.3 ; reset extruder
      M83
      M593 F33.56
      G4 S10
      M98 P"/macros/LED/LED_weiss"
      When I Start the board first time then work the print. After this print is finish, the next print doun't work.
      Is the end Code the problem?
      Endcode
      G10 P0 R0 S0		        ; Set hotend temp to 0
      M140 S0			            ; Set bed temp to 0
      G91
      G1 Z1
      G92 E0
      G1 E-10 F300
      G90
      M106 S20 		            ; Fan to cool nozzle and bed
      M220 S100		            ; Set speed factor back to 100% in case it was changed
      M221 S100		            ; Set extrusion factor back to 100% in case it was changed
      M290 R0 S0
      G90                  ; clear babystepping
      G1 X5 Y300 F6000
      G92 E0
      M300 S290 P1000
      G4 S60		            	; wait 1 minute for nozzle to cool
      M107
      • T3P3Tonyundefined
        T3P3Tony administrators @Heartleander81
        @heartleander81 few questions:
        1. do you have M83 in your config.g?
        2. why do you need M82 at any point in the print file? can you configure cura to not put it in at all?
        3. are you running this with an SBC or in stand alone mode?
        Cheers
        www.duet3d.com
        Heartleander81undefined 1 Reply Last reply Reply Quote 0
          Heartleander81 @T3P3Tony
          @t3p3tony
          1.) yes m83 have I in the Config.g
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 26 2020 16:14:58 GMT+0200 (Mitteleuropäische Sommerzeit)
          G90                                                ; send absolute coordinates...
          M83                                                ; ...but relative extruder moves
          M550 P"Duet3"                                      ; set printer name
          M912 P0 S-5                                        ; sstzt CPU Temp korrektur
          2.) When I slice a Cube in M82 runs normal.
          When I slice in M83 doun't come filament out the nozzel
          3.) I use SBC Raspberry Pi4
            Heartleander81 @Heartleander81
            I have found the problem. In the endcode was ist.
            • T3P3Tonyundefined
              @heartleander81 so cura was putting M82 in the endcode of the print file?
              What i would still like to explore is why the M83 in the start gcode did not override that. To confirm this exactly, what files do you need where to recreate the problem?
              www.duet3d.com
              Heartleander81undefined 2 Replies Last reply Reply Quote 0
                This post is deleted!
                  @t3p3tony no I have load the wrong file.
                  I have a Video on Youtube.
                  https://youtu.be/9JsrLHGQCIY
                  The Prime is 45 long and after the Prime E not resetet to 0
                    @heartleander81 now have I set a G92 E0 in the slicer after my loadet file then work the extruder
                    • LeonMFundefined LeonMF referenced this topic
