    Stepper motor problem Duet 3 MB6HC
    1.3k
    • kkallasundefined
      kkallas @droftarts
      @droftarts
      Fuses are ok.
      When I manually move the engines no message appears.
      Yes, the DWC shows the motor position incremented by the desired value but the motor does not move at all.
      I disconnected everything except power supply, stepper motor and power cable - still nothing.
        droftarts administrators @kkallas
        @kkallas I really can’t see anything that would stop the motor moving. Seems like an SPI failure (@dc42)? When and where did you buy the board from?
        kkallasundefined 1 Reply Last reply Reply Quote 0
        • kkallasundefined
          kkallas @droftarts
          @droftarts
          I bought the plate on March 31 from my local retailer. I was very satisfied because the only reseller in Poland is a few hundred meters from me and is on the Duet3D list
          Maybe it' s possible to check SPI through RaspberryPi ports, I have several Pi Zero. @dc42
            Have you tried configuring each driver and moving the motor for testing?
            • kkallasundefined
              kkallas @Phaedrux
              @phaedrux Yes. Yesterday I also tried to move the steppers with arduino with motor shield and they work.
                Very strange. Please contact your vendor and initiate a warranty exchange. Include a link to this thread as authorization.
