    Duet 2 Wifi - pin names on expansion header
    393
    • ZipZapundefined
      ZipZap
      Hey guys, quick question:
      In RRF3, how do i declare at thermistor input on the expansion header?
      The thermistor is on VSSA and the other end on the THERMISTOR7-pin and has a pullup of 4K7 to 3V3 as dc42 suggested (in older threads).
      M308 S7 A"Chamber" P"e7temp" Y"thermistor" T100000 B3950	;set thermistor for heated chamber
      Any helpt on how to declare would be appreciated.
      /Julien
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @ZipZap
        @zipzap From THIS page I think one of these will be what you want
        • e6temp, duex.e6temp, exp.thermistor7, exp.39
        • ZipZapundefined
          ZipZap
          Works, i should have scrolled to the bottom... i also added the R4700 value to the command.
          The thermistor reads about 2000°C, fluctuating to 19xx and 45xx occasionally.
          Is there a wiring issue?
          The thermistor works fine, when connected to the e0 or e1 input on the board.
            alankilian @ZipZap
            @zipzap E0, E1and E2 have the pull-up installed on the board already.
            4.7K pull to ADVREF.
            ZipZapundefined 1 Reply Last reply Reply Quote 1
            • ZipZapundefined
              ZipZap
              This post is deleted!
              • ZipZapundefined
                ZipZap @alankilian
                @alankilian
                Done.
                Thermistor reads now -273,15° as if not connected, but the pin seems to work.
                Does the other end go to VSSA, or GND?
                  alankilian @ZipZap
                  @zipzap Looks like VSSA to me.
                  • ZipZapundefined
                    ZipZap @alankilian
                    @alankilian
                    According to the documentation the fuse should be intact, because all other temps are working properly.
                    Why could it read open circuit?
                    Stupid me has had a connection issue, where i had the sensor between, VSSA and VAREV and the pullup between VSSA and input7...
                    Everything is working fine now, thanks a bunch alan!
                    alankilianundefined 1 Reply Last reply Reply Quote 1
                      alankilian @ZipZap
                      @zipzap AWESOME!
                      I'm glad you got it working.
