    Laser filament monitor/filament present switch
    • mendelevium
      mendelevium last edited by
      I am about to fit the laser type filament monitors. My extruders are designed with a built in microswitch for detecting filament present. According to the instructions, the terminals are normally closed when the filament is present. Can someone link me to a wireing diagram of a laser filament monitor (1.7) incorporating the filament present microswitch?
      Some links to configuration appreciated. I have two extruders with two seperate hotends in my setup.
      Many thanks in advance...
      alankilian 1 Reply Last reply Reply Quote 0
      • alankilian
        alankilian @mendelevium last edited by alankilian
        @mendelevium
        THIS page says to connect your "Filament-out" microswitch to the "SW" pins on the LASER filament monitor PCB.
        THIS page says then choose monitor type 6 "P6"
        mendelevium 1 Reply Last reply Reply Quote 1
        • mendelevium
          mendelevium @alankilian last edited by
          @alankilian
          So the switch is just connected to the pcb. Thought otherwise. Thanks for your link says all.. been trying to lookup all this. Thanks again.
