    "Cat whiskers" sensor as Z-probe?
    cat whisker sensor piezo smart effector z-probe underbed sensor
    1.2k
    • o_lampeundefined
      o_lampe
      Another way of hotend probe came to my mind, where a silicone tube around the heatsink neck is used to feel the nozzle touch the bed. Like 'Precision Piezo', but without the need for speed.
      arhiundefined 1 Reply Last reply Reply Quote 0
      • arhiundefined
        arhi @o_lampe
        last time I was looking at any decent (resolution and speed) gas pressure sensor for a project I could not find anything worth looking below 80 US$ in volume šŸ˜ž so I gave up. I see this one is 8US$ in volume so that's acceptable but the speed is serious problem here. Also you would have to make differential measurements non stop as this is heated environment so air pressure varies a lot with temperature ... also the housing of this sensor is not very friendly for what you'd wanna do.. something from SDP3x series like SDP31-500PA-TR-1500PCS would be much better (3x more expensive, 20x faster with 2kHz update rate )
        • o_lampeundefined
          o_lampe @arhi
          @arhi said in "Cat whiskers" sensor as Z-probe?:
          As I wrote above the response time can be as low as 0.5ms = 2kHz if we find a way to change oversampling rate.
          But I'm open for your pressure sensor, it's also well suited. But regarding integration we'd start from zero. ( the analog version would be the simplest, just treat it as a switch)
          Let's see, if we can get some development samples.
          The GY-63 MS5611 has been used in Arduino&Multicopter world and comes with a basic Cpp-library.
          • o_lampeundefined
            o_lampe
            Ouch, those SDP3x sensors are expensive. ~25€ a piece...
            The analog sensors are quite slow (3-9ms response time), while the I²C version in 2kHz continuous mode also offers averaging, smoothing and mass flow data. That's quite useful, we just have to read the direction of flow, and it doesn't matter if it's hot or cold.
            • arhiundefined
              arhi @o_lampe
              @o_lampe yes, ~25E at volume, 3x more expensive than 5611 that's ~9E at volume ... still super cheap comparing to sensors I checked few years ago, looks like price dropped significantly (these types were around $100 and more) ... one should investigate more there might be other ones better suited... imho 5611 has not only issue with speed but serious problem with packaging, how will you attach a tubing to it? you would have to put the whole pcb inside a balloon... not an easy design decision..
              • arhiundefined
                arhi
                btw I have in my "garbage box" NBPLANN150PAUNV no clue why I purchased it but I guess I found it useful at the time. This type of sensors are used in medical apps (blood pressure monitor for e.g.) so might be interesting for this application
                https://sensing.honeywell.com/honeywell-sensing-board-mount-pressure-tbp-nbp-series-datasheet-3008328.pdf
                .. they are analog output $8 at volume, $10 in onzies .. Wheatstone Bridge configuration so should be super fast and precise (IIRC 0.2% accuracy) .. of course for this sensor going with 0-1psi version (available) would be better than 0-150psi šŸ™‚ as you would want to detect minute changes so a very small range is optimal ... proper barbed port so you can attach a tube..
                • o_lampeundefined
                  o_lampe @arhi
                  @arhi
                  Thanks for all the input, it helps not starting from zero or work on something, others have abandoned already.
                  It would be pretty easy to set up a wheatstone bridge with our beloved 100k NTC thermistors and use them as mass flow sensor.
                  THAT would be cheap, but requires an old-school analog circuit expert. (me: looking in the mirror)
                  But at first I want to have a working sensor and go on from there.
                  If anyone else wants to work on this concept, I don't mind and I have no financial interest.
                  • arhiundefined
                    arhi @o_lampe
                    @o_lampe well the NBP series are imho great for this
                    • lot of choices for range so you can select best one for application
                    • good package so you can easily attach a tube
                    • $10 for single piece is not a dealbreaker for prototype design
                    • they come both smd and through hole version so soldering is not a problem even for beginners
                    • wide range of power option (1.8 to 12V)
                    • wide range of temperature (compensated 0-85C for TBP version)
                    • analog output, bridge, should be fast and sensitive, even the lowest output of mV/V of 1.5 will produce 0-7.5mV if powered by 5V that's decent output spam to not be drowned by noise and not to have to use expensive opamps
                    So, IMHO, I think it is the ideal candidate for a sensor like that. I think the mechanic design and manufacture is going to be a much bigger problem.
                    • o_lampeundefined
                      o_lampe @arhi
                      @arhi
                      It only makes sense to spend more money than a BLTouch would cost, when the result is equal or better. I've hoped the footprint would be small, but the silicone bulbs I linked earlier are 20mm diameter. Good for underbed probes, but a real winner would be the heatsink-necklace as it has zero offset and requires less force than piezos.
                      We'll see. I have plenty of projects ATM. Maybe someone beats me with this one?
                      • arhiundefined
                        arhi @o_lampe
                        @o_lampe said in "Cat whiskers" sensor as Z-probe?:
                        @arhi
                        To me it would make sense investing time if it would solve a problem that exist and is not solved. TBH I don't see what unsolved problem this could solve except to work as underbed probe. ATTM I don't know of reliable underbed probe. Probing from the top, I doubt it can have smaller footprint than some piezo/bltouch/easytouch/.. sensor .. and as for precission and repeatability a simple microswitch is "good enough" so
                        I can't visualize how would this work
