    Shrinking on Y axis
    483
    • alangibsonundefined
      alangibson
      Hello all.
      I just did a 200mm wide print that ended up measuring only 192mm wide. The part has several holes along the width. I measured their deviation from what they should be and the error seems to accumulate along the width. It's not just missing 8mm, it really 'shrunk'.
      I know my rod lengths are perfectly equal (ordered from Seemecnc), so I'm already out of ideas as to what could be causing this. Does anyone have any suggestions of what I should check next?
      My board is a DuetWifi and my Z probe is a Duet IR sensor.
        I'm assuming this is a delta?
        Post your config.g, homedelta, config-override, bed.g, and the results of M122 and M98 P"config.g" please.
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
        alangibsonundefined 1 Reply Last reply Reply Quote 0
          alangibson @Phaedrux
          Yes indeed, it is a delta. I've attached the files you asked for.
          I've had some success dialing it in by setting the axis steps/mm with M92. Right now, my 200 mm test shape is 202. So that's progress. The weird issue I'm seeing at this point is that I can never hit 200. I'm always at 198 mm or 202 mm.
          Thanks in advance for your help.
          M122.txt
          M98.txt
          homedelta.g
          config-override.g
          config.g
          bed.g
            Rather than change the steps per mm, which should be mechanically accurate and calculatable from the physical states, you could use axis scaling to make the correction in firmware.
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M579_Scale_Cartesian_axes
            However, I suspect that something is off mechanically. Loose bolt, stretched belt, binding carriage. Something like that.
            Did the top of your M122 get cut off? I was hoping to see the firmware version string in there as well.
            G31 X0 Y0 P465 Z0.333
            You're missing the X Y offset of the probe from the nozzle.
            M558 P1 You're missing some additional parameters here as well. Hopefully the defaults are suitable.
            Macro file "CONFIG.G" not found.
            Can you try lowercase config.g? M98 P"config.g"
              @phaedrux
              Thanks. I'll set everything back where it was and give this a shot.
              "On a Cartesian RepRap you can get prints exactly the right size by tweaking the axis steps/mm using the M92 G Code above. But this does not work so easily for Delta and other RepRaps for which there is cross-talk between the axes."
              I guess that would explain why I can't seem to hit 200mm.
              I noticed that I had removed the belt tensioner springs at some point and forgot to replace them. I put them back on but they didn't make a difference. Everything else seems solid.
              I just printed out an 8 pointed asterisk shape that is off by the same amount in every direction. That makes me think that it really is a scaling issue somewhere.
              M122 is complete. My (ancient) firmware version is 1.17e (2017-02-10)
              I'll add this.
              Still nothing.
              M98 P"CONFIG.G"
              It's echoing upper case, but I'm definitely entering M98 P"config.g"
                Phaedrux Moderator @alangibson
                @alangibson said in Shrinking on Y axis:
                Ah ok, that explains it a bit.
                  alangibson
                  @phaedrux
                  I've added the following line to the epilogue of config.g and I've now got an exactly 200mm test shape
                  M579 X1.03 Y1.03
                  The odd thing about this is that the math says the adjustment should be 1.015 (1.015 == 200/197). But using 1.015 makes no difference in final size at all.
                  Thanks for your help.
                  • o_lampeundefined
                    o_lampe @Phaedrux
                    @phaedrux said in Shrinking on Y axis:
                    But it doesn't explain why the off-scale prints kept unnoticed for so long?
                    @alangibson what did you set as 'rod-length' ? The actual rod length or did you add the diameter of the Mag-balls too?
                      alangibson @o_lampe
                      @o_lampe
                      I normally print small things where dimensional correctness doesn't really matter, so I just never noticed it most likely.
                      I'm using the 290 mm ball-cup arm kit from Seemecnc. I used their published center-to-center value of 290 in my config.
                      https://www.seemecnc.com/products/290mm-ball-cup-arm-set-of-6pcs
                      • o_lampeundefined
                        o_lampe @alangibson
                        @alangibson
                        Did you ever 'measure' the length yourself? Just trying to think about everything...
                          alangibson @o_lampe
                          @o_lampe
                          I did some smallish calibration shapes (20mm I think) a very long time ago. At that size the problem is not visually recognizable and I would have considered deviations less than 1mm to be OK for my purposes.
                          It's only when I recently got into printing large center punching templates that I got to a place where accuracy matters enough for me to even notice the problem.
