    How do I use a multi meter?
    • gnydickundefined
      gnydick
      I've probably damaged 4 duet boards from using my meter incorrectly.
      I remember that voltage is measured across a circuit and current is measured in line.
      But, for some reason, I kept putting into VDC mode and connecting it right up to the 2 pins. Then poof.
      I don't know why my brain goes on autopilot and does this. Anybody have any suggestions to help train my brain to use the right settings?
      alankilianundefined HebigTundefined zaptaundefined 3 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @gnydick
        @gnydick You do set the meter for Volts DC mode and connect across any two pins and you should safely get a reading of the voltage between those two pins.
        Are you maybe setting for Amps?
        Youtube should show you a million point five videos on how to use a multimeter.
        And ask away here. There are many who can help you. We've all been there.
        • HebigTundefined
          HebigT @gnydick
          @gnydick What's your method for measuring across pins?
          Measuring directly at the pins with the probes is risky because it's very easy touch the probes by accident and cause a short.
          When I need to measure something on the board (e.g. voltage at fan header) I plug breadboard jumper wires into each pin to extend them, then I measure them far away from eachother.
          gnydickundefined 1 Reply Last reply Reply Quote 0
          • zaptaundefined
            zapta @gnydick
            @gnydick, what voltmeter are you using? Can you post a link to the model or a picture?
            • gnydickundefined
              gnydick @HebigT
              @hebigt I use the leads coming off the board so I can spread them apart for safety.
