    Dotstar duet3 problem
    427
    • tom33undefined
      tom33
      I order dotsar led from adafruit (https://www.adafruit.com/product/2237?length=2). When I send a command nothing appened.
      I try M150 R255 F1 Y30 and M150 R255 P128 S20 F1 for exemple
      I have the M150 X0 Q3000000 in the config files for configuring the led
      I use RRF 3.2.2 and duet 3MB6HC
      dc42undefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @tom33
        @tom33, I will re-test DotStar LEDs on Duet 3, probably tomorrow.
          @tom33, I confirm that the DotStar driver was not working. I have now fixed it. The fix will be in the 3.3beta3 release. A preview 3.2beta2+ build including the fix is available at https://www.dropbox.com/sh/dupd9u1xppr1om5/AADYg4guuj2n8LJokVqtK-C7a?dl=0.
          • tom33undefined
            tom33
            @dc42,
            The led works well now thanks !
            And do you know if is it possible to make them blink during printing for example ?
              @tom33 said in Dotstar duet3 problem:
              @dc42,
              Yes, using either commands embedded in the GCode you are printing, or commands in the daemon.g file.
              pkosundefined 1 Reply Last reply Reply Quote 0
              • pkosundefined
                pkos @dc42
                @dc42 I'm happy to report - this also fixes the problem with mini 12864.
                Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
                • CanDo415undefined
                  CanDo415
                  Hi. I also have the Dotstar LED-strip. But its not working with Firmware 3.3.0
                  Any ideas why?
                  I tryed to use
                  M150 X1
                  and
                  M150 X0
                  both without any red LED
                  • CanDo415undefined
                    CanDo415
                    Nr. 1 is white. but i can't change anything
                      dc42 administrators @CanDo415
                      @cando415 have you checked the connections? Unfortunately the pinouts are not standard for DotStar strips, neither are the colours. The +5V and ground connections are usually easy to identify, but the clock and data inputs may be either way round.
                      • CanDo415undefined
                        CanDo415
                        Thanks. My Fault. Dotstar on Dotstarconnection. Didn't check the wiring
                        • dc42undefined dc42 marked this topic as a question
