    wpa_supplicant.conf missing from DuetPI
    Firmware installation
    • war4peace
      war4peace last edited by
      Hi all,
      I am in the process of setting up a RatRig V-Core 3 printer using Duet 3 6HC, PanelDue 5i and Raspberry Pi 4.
      I have successfully downloaded the DuetPi image (the one with GUI), written successfully to SD Card using BalenaEtcher (also verified written image), I can see the SD partition.
      The guide (https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_DuetPi) says "To set up WiFi, you can edit "wpa_supplicant.conf" on the SD card (first partition)."
      ...which doesn't exist.
      There is no "wpa_supplicant.conf" anywhere on that partition.
      So I'm stuck. How can I configure Wireless for the boot image?
      Thank you in advance for your replies!
      jay_s_uk droftarts 2 Replies Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @war4peace last edited by jay_s_uk
        @war4peace there is no wpa_supplicant.conf included in GUI image as its expected the user will connect a screen.
        see here for instructions on how to create a wpa_supplicant.conf https://www.raspberrypi.org/documentation/configuration/wireless/headless.md
        • droftarts
          droftarts administrators @war4peace last edited by
          @war4peace see https://duet3d.dozuki.com/Wiki/SBC_Setup_for_Duet_3#Section_Step_2_Setup_wifi
          war4peace 1 Reply Last reply Reply Quote 1
          • war4peace
            war4peace @droftarts last edited by
            @droftarts Thank you, I somehow missed that wiki page. Searched for "DuetPi" instead...
