    Duet 3 mini 5+ sensorless homing not working
    677
    • Frieckundefined
      Frieck
      Hi i am having big prolems setting um my sensorless homing with the duet 3 mini 5 + wifi.
      if i try to home it it always crashes into the end reguardless of the sensetivity i type in i read many poast but still cant get it to work properly. Any suggestions?
        jay_s_uk @Frieck
        @frieck Which firmware version are you running as there were issues in older builds
        • Frieckundefined
          Frieck
          @jay_s_uk i have at the moment the 3.3.0-b2 installed but i tested ist with 3.2.2 and3.2.0 i.
          i am rebuilding an old printer so it never worked before i am normally very
          experienced with 3d printers
          Argoundefined 1 Reply Last reply Reply Quote 0
          • Argoundefined
            Argo @Frieck
            @frieck
            Could you post your config.g and homing files please?
            Frieckundefined 1 Reply Last reply Reply Quote 0
            • Frieckundefined
              Frieck @Argo
              @argo
              config.g
              G90                                          ; send absolute coordinates...
              M83                                          ; ...but relative extruder moves
              M550 P"Big One"                              ; set printer name
              M552 S1                                      ; enable network
              M586 P0 S1                                   ; enable HTTP
              M586 P1 S1                                   ; enable FTP
              M586 P2 S0                                   ; disable Telnet
              M569 P0.0 S1                                 ; physical drive 0.0 goes forwards
              M569 P0.1 S1                                 ; physical drive 0.1 goes forwards
              M569 P0.2 S1                                 ; physical drive 0.2 goes forwards
              M569 P0.4 S1                                 ; physical drive 0.4 goes forwards
              M584 X0.0 Y0.1 Z0.2 E0.4                     ; set drive mapping
              M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z400.00 E420.00            ; set steps per mm
              M566 X900.00 Y900.00 Z60.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180.00 E1200.00      ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 E250.00          ; set accelerations (mm/s^2)
              M906 X700 Y800 Z800 E800 I30                 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                      ; Set idle timeout
              M208 X10 Y10 Z0 S1                           ; set axis minima
              M208 X400 Y400 Z400 S0                       ; set axis maxima
              M574 X1 S3                                   ; configure sensorless endstop for low end on X
              M574 Y1 S3                                   ; configure sensorless endstop for low end on Y
              M574 Z1 S2                                   ; configure Z-probe endstop for low end on Z
              M950 S0 C"io1.out"                           ; create servo pin 0 for BLTouch
              M558 P9 C"^io3.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X0 Y30 Z2.5                         ; set Z probe trigger value, offset and trigger height
              M557 X25:375 Y25:375 S20                     ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
              M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
              M307 H0 B0 S1.00                             ; disable bang-bang mode for the bed heater and set PWM limit
              M140 H0                                      ; map heated bed to heater 0
              M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
              M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
              M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
              M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
              M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
              M950 F0 C"out5" Q500                         ; create fan 0 on pin out5 and set its frequency
              M106 P0 S1 H1 T45                            ; set fan 0 value. Thermostatic control is turned on
              M950 F1 C"out6" Q500                         ; create fan 1 on pin out6 and set its frequency
              M106 P1 S1 H-1                               ; set fan 1 value. Thermostatic control is turned off
              M563 P0 D0 H1 F0                             ; define tool 0
              G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
              G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
              ; homex.g
              M400
              M913 X50
              M915 X S-128 R0 F0 H400
              M569 P0.0 V10
              G4 P200
              G91               ; relative positioning
              ;G1 H2 Z5 F6000    ; lift Z relative to current position
              G1 H1 X-415 F4000 ; move quickly to X axis endstop and stop there (first pass)
              ;G1 H2 X5 F6000    ; go back a few mm
              ;G1 H1 X-415 F360  ; move slowly to X axis endstop once more (second pass)
              ;G1 H2 Z-5 F6000   ; lower Z again
              G90               ; absolute positioning
              M913 X100
              M915 S63 X R0
              • Argoundefined
                Argo @Frieck
                @frieck
                For home.g I'd try:
                M913 X75
                M915 X S-128 R0 F0 H200
                M569 P0.0 V0
                I find too low currents produces unreliable stall detection.
                M915 H400 is for 0.9 motors "where full_steps_per_rev is 200 or 400 (for 1.8 or 0.9deg motors)"
                M569 V0 to force it into StealthChop
                Also please confirm with M122 that you are running RRF 3.3b2. With M915 "S-128" it should trigger stallguard homing. I have the suspicion that you might be still on 3.2.2.
                It did happen to me that the DWC reloaded but did not flash. At some point (3.3 beta?) the location of the firmware file changed from sys to firmware which caused some confusion.
                Frieckundefined 1 Reply Last reply Reply Quote 1
                • Frieckundefined
                  Frieck @Argo
                  @argo M122
                  RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2 running on Duet 3 Mini5plus WiFi (standalone mode)
                  Board ID: S6LD7-7396U-D65J0-40KM8-2213Z-RMB7V
                  thx your code works a litelbit at least it is detecting something now i will try now to tune the crash theshold
                  • Frieckundefined
                    Frieck @Frieck
                    @frieck ok it works just fine now
                    thx for the support and the fast ansers👍
                    • Argoundefined
                      Argo @Frieck
                      @frieck
                      Glad to hear 🙂
                      • Frieckundefined
                        Frieck @Argo
                        @argo I think i am a bit stupid but i just cant get the code working for the Y achsis
                        M400
                        M913 Y75
                        M915 Y S-15 R0 F0 H200
                        M569 P0.0 V0
                        G1 H2 Y20 F6000
                        G1 H1 Y-415 F4000 ; move quickly to X axis endstop and stop there (first pass)
                        ;G1 H2 X10 F6000    ; go back a few mm
                        ;G1 H1 X-415 F2000  ; move slowly to X axis endstop once more (second pass)
                        M913 Y100
                        • Argoundefined
                          Argo @Frieck
                          @frieck
                          Do you have
                          M17
                          G4 P150
                          before any movement in your homing files?
                          I have my whole homing procedure in homeall.g and before any movement M17 enables the motors.
                          See documentation:
                          „ Use this command to energise a motor for stealthChop tuning, followed by a short pause eg G4 P100 to allow the driver to establish the motor parameters.“
                          I use P150 just to be sure the pause is long enough.
                          • Frieckundefined
                            Frieck @Argo
                            @argo said in Duet 3 mini 5+ sensorless homing not working:
                            M17
                            G4 P150
                            thx i implemented it into my Code. But it wasn't the Problem i forgot to set
                            M569 P0.0 V0
                            to
                            M569 P0.1 V0
                            now it works thx for the Help again👍 👍 👍 👍
                              dc42 administrators @Frieck
                              @frieck, thanks for the update. I'll mark this as solved.
