    [SOLVED] Duet2 Ethernet RRF3 Motor issue
    627
    • printerdadundefined
      printerdad
      Hey dudes. Ive been trying to configure the firmware for my new duet2, and suddenly my motors are acting strangely even though I was only changing settings for m208. I was sending them movement commands testing the end stops etc, and about 30% of the commands dont "register." The motor tries to move, making an unusual noise, and travels about 5mm instead of the requested 50mm. I have lowered the acceleration and movement speeds with no luck.
      Any tips appreciated.
      Dad
      • 3DPMicroundefined
        3DPMicro
        Motor current set correctly?
        Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
          We'll need more to work with. Please post your config.g and homing files.
          Do things behave better after a power cycle and returning to the values in config.g?
          @printerdad said in Duet2 Ethernet RRF3 Motor issue:
          What commands would those be?
          Did the motors work before that? Off noises and halting movement could be a loose wire on one half of the phase.
          Did you happen to alter the steps per mm?
          printerdadundefined 1 Reply Last reply Reply Quote 0
            printerdad @Phaedrux
            @Phaedrux
            I have not altered the steps/mm.
            The unregistered commands are the movements I tell it to do through the web interface. When I say unregistered I mean they act up, ie only move a small amount, noisy etc.
            Each motor has its current set to 80% of its rated value.
            Today is the first day I have seen this problem with these motors. They moved fine before.
            Both my X and Y motors are showing problems. Can't test Z motors because I cant home Z so I cant ask it to move Z.
            config.g
            homeall.g
            Thanks
            Dad
            3DPMicroundefined 1 Reply Last reply Reply Quote 0
              Video of the behaviour?
              Do you have mesh compensation active?
              You can force the X and Y axis to be homed by sending G92 X100 Y100 (or whatever coordinate you like) to tell the firmware the axis is homed and at that location.
                @phaedrux
                heres a link to a video showing the problem.
                https://youtu.be/hlwBr45LDo0
                I dont believe I have mesh compensation active. I have never turned it on via the web control at least.
                • 3DPMicroundefined
                  3DPMicro @printerdad
                  @printerdad you can send "G92 Z" so it thinks its home
                    The noise sounds like it could be binding and the motor is stalling. Does the motion move smoothly by hand when the power is off? (move it slowly)
                    You say that, but I don't see any motor current settings in config.g. There's no M906 command.
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M906_Set_motor_currents
                      @phaedrux
                      interesting, i input all the motors' current in the config wizard but something must have happened...
                      the motor is smooth when powered off.
                        If you send M906 in the console by itself it will report back with whatever default currents it's using. See what that is. Then change your config.g to add a M906 line to set the currents correctly and see how it behaves.
                        printerdadundefined 2 Replies Last reply Reply Quote 0
                          @phaedrux
                          m906
                          Motor current (mA) - X:0, Y:0, Z:0, E:0:0, idle factor 30%
                          hm.... currently looking up my motors' rated currents again to reenter info.
                          Dad
                          EDIT:
                          Alrighty so I have these motors at the rating listed:
                          X,Y - 1.5amps each
                          Z,Z in series - 1amp each
                          E,E - 1amp each
                          Is this the proper format for m906 assuming 85% ratings in milliamps?
                          M906 X1275 Y1275 Z850:850 E850:850
                            Phaedrux Moderator @printerdad
                            @printerdad Yes.
                            Duet 2 WiF/Ethernet is done in steps of 100mA and is rounded down.
                              @phaedrux ok so
                              M906 X1200 Y1200 Z800:800 E800:800?
                              Im not sure about the Z motors in series if I list it twice like I do for the 2 extruders.
                                @phaedrux said in Duet2 Ethernet RRF3 Motor issue:
                                ^ After finally getting a chance to input the correct current values for the motors, the binding seems to have stopped!!! Thanks guys.
                                  @printerdad said in [SOLVED] Duet2 Ethernet RRF3 Motor issue:
                                  @phaedrux ok so
                                  Nope, you only need a single value for Z. Only E requires multiple values.
