    [Duet 3 mini 5+/6HC] Accelerometer not found on specified port
    Beta Firmware
    1.5k
    • sebkritikelundefined
      sebkritikel
      Quick update - I was running a rather long cable (about 11feet). I was confident in the integrity of the cable, however I trimmed 4feet off the Duet side, re terminated, and now the accelerometer is working well.
      Large(ish?) IDEX - 6HC, 1HCL
      Stratasys Dimension 1200es to 6HC Conversion
      pkosundefined 1 Reply Last reply Reply Quote 0
      • pkosundefined
        pkos @sebkritikel
        @sebkritikel Interesting. My wire was about 4 foot long. And leghtwise it was the same as the one I used for the arduino (the only difference was the pins on the arduino one). But that is something to check definitely.
        Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
        sebkritikelundefined 1 Reply Last reply Reply Quote 0
          sebkritikel @pkos
          @pkos Of course, it might not be the cure for you - as a note, the 'finished' cable is 7ft long.
          • pkosundefined
            pkos @sebkritikel
            @sebkritikel I got it to work, only in my case I had to go with a 40cm wire and wrap it in aluminum foil to shield it from outside interference (thanks to @Diamondback in the other thread for leading me onto it asking about the length). Even the 40cm wouldn't work without shielding.
            Possible the wire could be made longer, but I'm done crimping those damned dupont connectors 😉
            • par_apwnundefined
              par_apwn
              I can't make it work,
              With 3 feet ethernet cable, crimps checked, foiled up, based on wiki instructions.
              M955 P0 C"spi.cs3+spi.cs4"
              Error: M955: Accelerometer not found on specified port
              Any idea?
              • par_apwnundefined
                par_apwn
                on Duet2 wifi 1.04
                  dc42 administrators @par_apwn
                  @par_apwn you could try adding a 1K resistor in series with SDO at the accelerometer end of the cable, as described in the other thread.
                  Do you have a temperature daughter board installed as well? If so then on the connector on top of that board, CS3 and CS4 are in the positions that correspond to CS1 and CS2 underneath it.
                  rockydubbundefined 1 Reply Last reply Reply Quote 0
                  • rockydubbundefined
                    rockydubb @dc42
                    @dc42 Hi, I’m having the same issue with the accelerometer not being found. I cut the cable in half and then it was found. But I had to wrap the CS wire in tinfoil.
                    I’m going to go to the electronics store and purchase the resistor you’re talking about I just needed to know one thing. They sell the 100 ohm 1K resistor but in different wattages.
                    They have: 1/4 W, 1/2 W, 1 W, 2W 100 ohm 1k resistors …
                    Which one can I purchase?
                    Ender 5 Plus - Duet 3 6HC / TMC5160's
                    Creality CR-10 V2 - Duet 2 Wi-Fi / TMC5160's
                    FlashForge Inventor Dual Extruder / Bondtech BMG Dual Extruders
                      dc42 administrators @rockydubb
                      @rockydubb said in [Duet 3 mini 5+/6HC] Accelerometer not found on specified port:
                      Any of them will do.
                        rockydubb @dc42
                        @dc42 Great! Sounds good. Thanks so much for the prompt reply!
