    Extruder disappeared from DWC
    Beta Firmware
    • Sytac072undefined
      Sytac072
      Hello, I have an issue...
      I own a duet2 wifi and yesterday I tried to upgrade from RRF 3.2.2 to RRF 3.3 b3 and at this point, the extruder disappeared from the DWC 3.3 b3 as well as from the paneldue.
      config.g
      Any idea?
        droftarts administrators @Sytac072
        @sytac072 I think it might be the F-1 in your M563 tool definition, causing the tool not to be defined. It’s not needed. Not sure why this works in 3.2.2 and not in 3.3b3. Send M98 P”config.g” first, which will run config.g and show if there are any errors.
        Sytac072undefined 1 Reply Last reply Reply Quote 0
        • Sytac072undefined
          Sytac072 @droftarts
          @droftarts Thank you very much for your quick reply and tip. This was the issue. I removed the F-1 and the extruder came back.
