    Hot end fan switches off at the start of the print.
    959
    • GrahamExpundefined
      GrahamExp
      I saw another post about this where you recommended swopping the hotend fan to fan1 instead of fan 0. I tried this and it did not work for me. I use Cura 4.8 as my slicer and it is set to use reprap in the settings. It does seem that it is a command to switch the fan off because after the print starts I can manually switch it on again and then it works. What I noticed is that to switch it on both tool fan (0) and fan 1 react as if they are the same item. I can then switch off fan 1 again and tool fan remains on. On the older Duet 2 board there were always on fan options. Isn't there a similar option on the duet 3 board?
      I have put my config.g file back to the original as the change made no difference.
      this is my current config.g
      "; Fans
      M950 F0 C"out7" Q500 T45 ; create fan 0 on pin out7 and set its frequency - Hotend Cooling Fan
      M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out8" Q0 ; create fan 1 on pin out8 and set its frequency - Parts Cooling Fan
      M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off"
      Also tried
      "M950 F1 C"out8" Q0 M106 P1 So H-1
      M950 F0 C''out7'' Q500 T45 M106 P0 S1 H1
      no change in the printer behaviour.
      • SIamundefined
        SIam
        @grahamexp said in Hot end fan switches off at the start of the print.:
        try this :
        M950 F0 C"out7" Q500  ; create fan 0 on pin out7 and set its frequency - Hotend Cooling Fan
        M106 P0 S1 T45 H1 ; set fan 0 value. Thermostatic control is turned on
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        GrahamExpundefined 1 Reply Last reply Reply Quote 0
          GrahamExp @SIam
          @siam Nope that does not fix it.
            dc42 administrators @GrahamExp
            Please do not use Fan 0 as the hot end fan. Doing so adds another layer of complexity, because all slicers control fan 0 as the part cooling by default. On a machine with a single hot end, use Fan 0 and the part cooling fan, and Fan 1 or any other fan number you like (up to the maximum allowed) as the hotend fan.
              GrahamExp @dc42
              @dc42 so like this?
              M950 F0 C"out8" Q0 ; create fan 0 on pin out7 and set its frequency - Part Cooling Fan
              M950 F1 C"out7" Q500 ; create fan 1 on pin out8 and set its frequency - Hotend Cooling Fan
              M106 P1 S1 T45 H1 ; set fan 1 value. Thermostatic control is turned on
              GrahamExpundefined dc42undefined 2 Replies Last reply Reply Quote 0
                GrahamExp @GrahamExp
                @grahamexp So what happens now is that the hot end fan (fan 1) starts up at 45 degrees but as soon as the printing begins it switches off again. Part cooling fan is now fan 0.
                SIamundefined 1 Reply Last reply Reply Quote 0
                • SIamundefined
                  SIam @GrahamExp
                  @grahamexp please post the first 50- 100 lines from your generated g-code
                    GrahamExp @SIam
                    @siam ;FLAVOR:RepRap
                    ;TIME:1471
                    ;Filament used: 0.844173m
                    ;Layer height: 0.25
                    ;MINX:127.88
                    ;MINY:109.761
                    ;MINZ:0.3
                    ;MAXX:173.172
                    ;MAXY:190.237
                    ;MAXZ:69.428
                    ;ARCWELDERPROCESSED
                    ;LINEARADVANCEPROCESSED
                    ; Postprocessed by ArcWelder
                    ; Copyright(C) 2020 - Brad Hochgesang
                    ; resolution=0.05mm
                    ; path_tolerance=1%
                    ; max_radius=1000000.00mm
                    ; firmware_compensation=True
                    ; mm_per_arc_segment=1.00mm
                    ; min_arc_segments=12
                    ; default_xyz_precision=3
                    ; default_e_precision=5
                    ;Generated with Cura_SteamEngine 4.8.0
                    T0
                    M190 S70
                    M104 S255
                    M109 S255
                    M82 ;absolute extrusion mode
                    G28 ;Home
                    G1 Z15.0 F6000 ;Move the platform down 15mm
                    ;Prime the extruder
                    G92 E0
                    G1 F200 E3
                    G92 E0
                    M83 ;relative extrusion mode
                    G1 F1500 E-2.5
                    ;LAYER_COUNT:278
                    M572 S0.550000 D0 ;added by LinearAdvanceSettingPlugin
                    ;LAYER:0
                    M107
                    G0 F1800 X129.314 Y111.721 Z0.3
                    ;TYPE:SKIRT
                    G1 F1500 E2.57838
                    G3 X131.478 Y110.170 I4.273 J3.677 E0.05677 F1800
                    G3 X134.459 Y109.809 I2.190 J5.596 E0.06412
                    G3 X148.452 Y112.224 I-9.081 J94.362 E0.30040
                    G3 X167.834 Y128.297 I-8.557 J30.041 E0.54778
                    G3 X173.150 Y151.443 I-42.633 J21.975 E0.50717
                    G3 X166.571 Y173.960 I-48.325 J-1.900 E0.50082
                    G3 X145.391 Y188.503 I-26.690 J-16.176 E0.55959
                    G3 X134.082 Y190.219 I-20.282 J-95.543 E0.24187
                    G3 X131.450 Y189.818 I-0.490 J-5.620 E0.05677
                    G3 X129.295 Y188.255 I2.132 J-5.207 E0.05677
                    G3 X128.096 Y185.878 I4.291 J-3.655 E0.05677
                    G3 X127.968 Y182.725 I8.568 J-1.927 E0.06706
                    G3 X128.417 Y181.251 I9.908 J2.213 E0.03259
                    G2 X128.161 Y118.021 I-89.047 J-31.255 E1.36259
                    G3 X127.893 Y115.782 I5.351 J-1.776 E0.04794
                    G3 X128.567 Y112.834 I7.467 J0.156 E0.06441
                    G3 X129.314 Y111.721 I4.978 J2.534 E0.02838
                    G0 X129.721 Y111.906
                    G3 X131.849 Y110.487 I3.872 J3.502 E0.05457
                    G3 X134.415 Y110.235 I1.804 J5.177 E0.05495
                    G3 X148.343 Y112.638 I-8.992 J93.687 E0.29899
                    G3 X167.386 Y128.359 I-8.429 J29.604 E0.53701
                    G3 X172.726 Y151.316 I-42.320 J21.944 E0.50335
                    G3 X165.883 Y174.252 I-46.997 J-1.533 E0.51142
                    G3 X145.303 Y188.084 I-26.019 J-16.486 E0.53936
                    G3 X134.045 Y189.792 I-20.170 J-94.993 E0.24080
                    G3 X131.520 Y189.383 I-0.456 J-5.186 E0.05458
                    G3 X129.494 Y187.823 I2.074 J-4.789 E0.05456
                    G3 X128.603 Y186.115 I4.064 J-3.206 E0.04092
                    G3 X128.393 Y182.780 I7.886 J-2.171 E0.07113
                    G3 X129.680 Y178.828 I75.446 J22.384 E0.08787
                    G2 X128.567 Y117.886 I-90.315 J-28.832 E1.31137
                    G3 X128.374 Y115.147 I5.612 J-1.772 E0.05851
                    G3 X128.983 Y112.962 I5.422 J0.334 E0.04826
                    G3 X129.721 Y111.906 I4.580 J2.415 E0.02728
                    G1 F1500 E-2.5
                    ;MESH:Canopy_1.stl
                    G0 F1800 X137.542 Y183.534
                    ;TYPE:WALL-OUTER
                    G1 F1500 E2.57838
                    G3 X139.669 Y180.068 I310.315 J188.047 E0.08596 F1800
                    G3 X143.539 Y176.885 I8.004 J5.787 E0.10704
                    G3 X145.915 Y176.082 I8.132 J20.146 E0.05305
                    G2 X153.745 Y171.178 I-5.581 J-17.613 E0.19731
                    G2 X158.010 Y164.600 I-15.846 J-14.946 E0.16657
                    G2 X161.219 Y148.753 I-32.558 J-14.841 E0.34471
                    G2 X156.708 Y132.780 I-36.464 J1.674 E0.35382
                    G2 X149.723 Y125.622 I-17.042 J9.643 E0.21368
                    G2 X144.322 Y123.436 I-11.154 J19.793 E0.12353
                    G3 X140.198 Y120.599 I3.357 J-9.296 E0.10693
                    G3 X139.204 Y119.229 I7.436 J-6.440 E0.03580
                    G2 X137.548 Y116.476 I-260.902 J155.064 E0.06790
                    G2 X133.733 Y116.029 I-12.269 J88.209 E0.08117
                    G1 X133.774 Y115.625 E0.00858
                    G3 X147.119 Y117.926 I-8.473 J88.991 E0.28216
                    G3 X162.737 Y131.183 I-7.194 J24.303 E0.44567
                    G3 X167.287 Y151.609 I-37.413 J19.054 E0.44692
                    G3 X161.434 Y171.144 I-42.187 J-1.996 E0.43529
                    G3 X144.646 Y182.677 I-21.406 J-13.174 E0.44308
                    G3 X133.773 Y184.374 I-20.367 J-94.816 E0.23267
                    G1 X133.733 Y183.971 E0.00856
                    G2 X137.542 Y183.534 I-19.285 J-184.910 E0.07656
                    G0 X137.562 Y183.501
                    G0 X137.645 Y183.363
                    G0 X138.092 Y183.43
                    ;TYPE:SKIN
                    G3 X140.001 Y180.322 I37.766 J21.057 E0.07709
                    G3 X143.716 Y177.264 I7.678 J5.542 E0.10278
                    G3 X146.040 Y176.481 I7.921 J19.670 E0.05188
                    G2 X154.046 Y171.467 I-5.708 J-18.012 E0.20174
                    G2 X158.392 Y164.770 I-16.139 J-15.232 E0.16964
                    G2 X161.637 Y148.737 I-32.932 J-15.010 E0.34873
                    G2 X157.071 Y132.573 I-36.871 J1.688 E0.35807
                    G2 X149.936 Y125.262 I-17.402 J9.846 E0.21826
                    G2 X144.463 Y123.042 I-11.377 J20.192 E0.12521
                    G3 X140.511 Y120.321 I3.220 J-8.908 E0.10250
                    G3 X139.552 Y118.998 I7.107 J-6.161 E0.03456
                    G1 X138.092 Y116.57 E0.05987
                    G3 X147.626 Y118.515 I-8.784 J67.395 E0.20581
                    G3 X162.362 Y131.368 I-7.771 J23.783 E0.42455
                    G3 X166.869 Y151.588 I-37.010 J18.862 E0.44243
                    G3 X161.082 Y170.918 I-41.713 J-1.957 E0.43070
                    G3 X144.511 Y182.279 I-21.068 J-12.964 E0.43715
                    G3 X138.092 Y183.430 I-19.716 J-91.482 E0.13784
                    G0 X138.664 Y182.85
                    G1 X138.923 Y183.108 E0.00773
                    G0 X139.447 Y183.028
                    G1 X138.891 Y182.471 E0.01663
                    G0 X139.119 Y182.094
                    G1 X139.968 Y182.943 E0.02537
                    G0 X140.486 Y182.856
                    G1 X139.345 Y181.715 E0.0341
                    G0 X139.572 Y181.337
                    G1 X141.003 Y182.768 E0.04277
                    G0 X141.515 Y182.674
                    G1 X139.806 Y180.965 E0.05108
                    G0 X140.047 Y180.601
                    G1 X142.027 Y182.581 E0.05918
                    G0 X142.535 Y182.483
                    G1 X140.303 Y180.252 E0.06669
                    G0 X140.57 Y179.914
                    G1 X143.041 Y182.384 E0.07384
                    G0 X143.545 Y182.283
                    G1 X140.855 Y179.593 E0.0804
                    G0 X141.149 Y179.281
                    G1 X144.046 Y182.178 E0.08658
                    G0 X144.543 Y182.07
                    G1 X141.462 Y178.989 E0.09208
                    G0 X141.782 Y178.704
                    G1 X145.036 Y181.959 E0.09727
                    G0 X145.53 Y181.847
                    G1 X142.127 Y178.444 E0.10171
                    G0 X142.476 Y178.188
                    G1 X146.019 Y181.731 E0.10589
                    G0 X146.501 Y181.608
                    G1 X142.848 Y177.954 E0.10919
                    G0 X143.228 Y177.729
                    G1 X146.977 Y181.478 E0.11205
                    G0 X147.44 Y181.336
                    G1 X143.628 Y177.524 E0.11393
                    G0 X144.046 Y177.336
                    G1 X147.9 Y181.191 E0.1152
                    G0 X148.349 Y181.034
                    G1 X144.476 Y177.161 E0.11575
                    G0 X144.932 Y177.012
                    G1 X148.791 Y180.871 E0.11534
                    G0 X149.228 Y180.703
                    G1 X145.395 Y176.87 E0.11456
                    G0 X145.863 Y176.732
                    G1 X149.656 Y180.525 E0.11336
                    G0 X150.079 Y180.343
                    G1 X146.323 Y176.587 E0.11226
                    G0 X146.774 Y176.433
                    G1 X150.495 Y180.154 E0.11121
                    G0 X150.902 Y179.956
                    G1 X147.216 Y176.27 E0.11017
                    G0 X147.648 Y176.097
                    G1 X151.303 Y179.751 E0.10922
                    G0 X151.697 Y179.54
                    G1 X148.072 Y175.915 E0.10834
                    G0 X148.486 Y175.723
                    G1 X152.088 Y179.326 E0.10767
                    G0 X152.472 Y179.104
                    G1 X148.893 Y175.525 E0.10697
                    G0 X149.293 Y175.32
                    G1 X152.848 Y178.876 E0.10627
                    G0 X153.22 Y178.642
                    G1 X149.685 Y175.107 E0.10565
                    G0 X150.067 Y174.884
                    G1 X153.585 Y178.402 E0.10514
                    G0 X153.945 Y178.156
                    G1 X150.443 Y174.654 E0.10467
                    G0 X150.808 Y174.414
                    G1 X154.301 Y177.907 E0.1044
                    G0 X154.649 Y177.65
                    G1 X151.172 Y174.173 E0.10392
                    G0 X151.523 Y173.919
                    G1 X154.993 Y177.389 E0.10371
                    G0 X155.331 Y177.121
                    G1 X151.868 Y173.659 E0.10349
                    G0 X152.213 Y173.398
                    G1 X155.663 Y176.848 E0.10311
                    G0 X155.99 Y176.57
                    G1 X152.544 Y173.123 E0.10301
                    G0 X152.869 Y172.843
                    G1 X156.313 Y176.287 E0.10293
                    G0 X156.629 Y175.998
                    G1 X153.194 Y172.563 E0.10266
                    G0 X153.504 Y172.268
                    G1 X156.94 Y175.704 E0.10269
                    G0 X157.247 Y175.406
                    G1 X153.809 Y171.968 E0.10275
                    G0 X154.115 Y171.668
                    G1 X157.549 Y175.102 E0.10263
                    G0 X157.845 Y174.793
                    G1 X154.406 Y171.354 E0.10278
                    G0 X154.694 Y171.037
                    G1 X158.136 Y174.479 E0.10287
                    G0 X158.422 Y174.159
                    G1 X154.982 Y170.719 E0.10281
                    G0 X155.253 Y170.385
                    G1 X158.703 Y173.835 E0.10311
                    G0 X158.978 Y173.505
                    G1 X155.521 Y170.048 E0.10332
                    G0 X155.789 Y169.71
                    G1 X159.249 Y173.171 E0.10343
                    G0 X159.516 Y172.832
                    G1 X156.042 Y169.358 E0.10383
                    G0 X156.293 Y169.004
                    G1 X159.777 Y172.488 E0.10413
                    G0 X160.03 Y172.135
                    G1 X156.543 Y168.649 E0.1042
                    G0 X156.774 Y168.275
                    G1 X160.281 Y171.781 E0.1048
                    G0 X160.526 Y171.421
                    G1 X157.004 Y167.899 E0.10526
                    G0 X157.235 Y167.524
                    G1 X160.764 Y171.054 E0.10549
                    G0 X160.999 Y170.683
                    G1 X157.445 Y167.13 E0.10621
                    G0 X157.655 Y166.735
                    G1 X161.23 Y170.309 E0.10683
                    G0 X161.452 Y169.926
                    G1 X157.863 Y166.337 E0.10727
                    G0 X158.058 Y165.926
                    G1 X161.67 Y169.538 E0.10795
                    G0 X161.883 Y169.147
                    G1 X158.251 Y165.515 E0.10855
                    G0 X158.446 Y165.104
                    G1 X162.087 Y168.745 E0.10882
                    G0 X162.287 Y168.34
                    G1 X158.634 Y164.687 E0.10918
                    G0 X158.814 Y164.261
                    G1 X162.481 Y167.929 E0.10961
                    G0 X162.676 Y167.519
                    G1 X158.993 Y163.835 E0.11009
                    G0 X159.173 Y163.41
                    • SIamundefined
                      SIam @GrahamExp
                      M107
                      look at your start g code you have a m170 some wehre and this switch off your fan
                        GrahamExp @SIam
                        @siam M107 or M170? I see M107 not M170
                        • SIamundefined
                          SIam @GrahamExp
                          @grahamexp
                          I mean this:
                          ;LAYER:0
                          M107
                          Somewhere in your slicer will add this and this switch your fan off
                          M107: Fan Off
                          Deprecated in RepRapFirmware. Use M106 S0 instead.
                          Note that M107 will turn off the print cooling fan(s) associated with the current tool (see the F parameter in the M563 command).
                            GrahamExp @SIam
                            @siam I see it, so how do I stop this from happening?
                              @grahamexp OK but that is the current tool fan and it set to be using tool 0 the hot end fan is set to be fan 1 so it should then not be affected, right?
                              • SIamundefined
                                SIam @GrahamExp
                                @grahamexp mmmhh I understand this so that this is the hot end cooler
                                  @grahamexp that looks better. Now please post your complete config.g file.
                                    GrahamExp @SIam
                                    @siam yes corect I want it always on .. or at least on as soon as it reached 45 deg. It should not be affected by the g code at all in preference. like on the older duet 2 board you had those always on fan pins.
                                      @grahamexp ; Configuration file for Duet 3 (firmware version 3)
                                      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Mon Feb 01 2021 21:18:26 GMT+0200 (South Africa Standard Time)
                                      G90 ; Send absolute coordinates
                                      M83 ; Relative extruder moves
                                      M550 P"Viking 300" ; Set printer name to Viking 300
                                      M669 K1 ; Select CoreXY mode
                                      G21 ; Set to milimeters
                                      M111 S0 ; Debugging off
                                      M552 P192.168.0.176 S1 ; enable network and acquire dynamic address via DHCP
                                      M586 P0 S1 ; enable HTTP
                                      M586 P1 S0 ; disable FTP
                                      M586 P2 S0 ; disable Telnet
                                      M569 P0.1 S1 ; physical drive 0.1 goes forwards
                                      M569 P0.2 S1 ; physical drive 0.2 goes backwards
                                      M569 P0.3 S1 ; physical drive 0.3 goes forwards
                                      M584 X0.1 Y0.0 Z0.2 E0.3 ; set drive mapping
                                      M92 X80.00 Y80.00 Z3204 E1004.00 ; set steps per mm
                                      M566 X900.00 Y900.00 Z60.00 E500 ; set maximum instantaneous speed changes (mm/min)
                                      M203 X18000.00 Y18000.00 Z360.00 E3000.00 ; set maximum speeds (mm/min)
                                      M201 X3000.00 Y3000.00 Z360.00 E3000.00 ; set accelerations (mm/s^2)
                                      M906 X800 Y800 Z1000 E1200 ; set motor currents (mA) and motor idle factor in per cent
                                      ;M84 S30 ; Set idle timeout
                                      M208 X-5 Y0 Z0 S1 ; set axis minima
                                      M208 X300 Y300 Z360 S0 ; set axis maxima
                                      M574 X1 S3 ; configure sensorless endstop for high end on X
                                      M574 Y2 S3 ; configure sensorless endstop for high end on Y
                                      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                                      ;Stall Detection
                                      M915 X Y S3 R0 ; Stall detection on the X and Y axis With sensitivity set by S and Action set by R ("Take3 No Action")
                                      ;Pressure/Linear Advance
                                      ;M572 D0 S0.75 ; Pressure/Linear advance enabled with D selecting tool and S selecting value.
                                      M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                                      M558 P9 C"^io7.in" H5 F360 T6000 A1 B0.2 ; set Z probe type to bltouch and the dive height + speeds
                                      G31 P500 X-71 Y-42 Z3.0632 ; set Z probe trigger value, offset and trigger height
                                      M557 X15:215 Y15:195 S40 ; define mesh grid
                                      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                                      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                                      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                                      M143 H1 S275 ; set temperature limit for heater 1 to 275C
                                      M950 F0 C"out8" Q0 ; create fan 0 on pin out8 and set its frequency - Part Cooling Fan
                                      M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency - Hotend Cooling Fan
                                      M563 P0 D0 H1 F0:1 ; define tool 0
                                      M575 P1 S1 B57600 ; enable support for PanelDue - io_0
                                        Phaedrux Moderator @GrahamExp
                                        You've got both fan0 and fan1 assigned to tool0 as the part cooling fan.
                                        Change F0:1 to be F0
                                          GrahamExp @Phaedrux
                                          @phaedrux problem solved. thank you for your help 🙂
