    WiFi Unreliable
    114
    1788
    • DessiVerse
      DessiVerse last edited by
      Hello, I'm not sure why but my WiFi connection is very unreliable on my Duet 3 Mini 5+. I have the antenna plugged in and everything, but it seems to be really unstable where it won't connect sometimes or will be insanely slow. Any ideas?
      SIam Stephen6309 2 Replies Last reply Reply Quote 0
      • SIam
        SIam @DessiVerse last edited by
        @dessiverse This can have a lot of reasons.. router to far away, thickness of the wall, crowded WLAN frequency... please post the result from M122
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        DessiVerse 1 Reply Last reply Reply Quote 0
        • DessiVerse
          DessiVerse @SIam last edited by
          @siam here's the result:
          RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus WiFi (standalone mode)
          Board ID: 7HDQX-V296U-D65J0-40KM8-MK03Z-R91J2
          Used output buffers: 3 of 40 (23 max)
          Static ram: 98732
          Dynamic ram: 108004 of which 24 recycled
          Never used RAM 38456, free system stack 124 words
          Tasks: NETWORK(ready,168) HEAT(blocked,315) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,362) TMC(blocked,106) MAIN(running,401) IDLE(ready,20) AIN(blocked,264)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:06:15 ago, cause: power up
          Last software reset at 2021-04-28 14:42, reason: User, GCodes spinning, available RAM 50508, slot 1
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task Linu Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Aux1 errors 0,0,0
          Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 2507, writes 0, timeouts 0, DMA errors 0
          Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 2507, writes 0, timeouts 0, DMA errors 0
          Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 2507, writes 0, timeouts 0, DMA errors 0
          Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 2507, writes 0, timeouts 0, DMA errors 0
          Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 2507, writes 0, timeouts 0, DMA errors 0
          Driver 5: position 0, assumed not present
          Driver 6: position 0, assumed not present
          Date/time: 2021-04-28 10:50:21
          Cache data hit count 773393444
          Slowest loop: 8.47ms; fastest: 0.12ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.1ms, write time 2.1ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = 0 -1, chamberHeaters = -1 -1
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 203.24ms; fastest: 0.09ms
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is active
          Failed messages: pending 0, notready 0, noresp 1
          WiFi firmware version 1.25
          WiFi MAC address f0:08:d1:02:ec:f2
          WiFi Vcc 3.34, reset reason Power up
          WiFi flash size 2097152, free heap 19200
          WiFi IP address 10.0.0.201
          WiFi signal strength -39dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
          === CAN ===
          Messages queued 158, send timeouts 158, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
          • DessiVerse
            DessiVerse @DessiVerse last edited by DessiVerse
            I do want to note that I have two pi's really close to the duet that never experiences any network issues. One is a Pi 3, one is a Pi 4. When I ran the Duet in SBC mode connectivity was fine, so it's likely an issue with the WiFi on the duet.
            EDIT: I also do already have a WiFi repeater to ensure all my devices on the network run smoothly.
            SIam 1 Reply Last reply Reply Quote 0
            • DessiVerse
              Reading the M122 result signal strength is good at -39dBm so I'm not sure why I'm getting the problems I am. I was having upload speeds as slow as 3.5 KIB/s after posting the result.
              • SIam
                @dessiverse your signal strength looks not bad (mine is worse and have no problem ). If your WLAN connection is slow again can you post again the result of M122. Perhaps is an Update to RRF 3.3 B3 a solution
                • DessiVerse
                  @siam how would I go about updating?
                  • SIam
                    @dessiverse Here is the documentation https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                    The latest firmware you find here: https://forum.duet3d.com/topic/22878/software-package-3-3beta3-released
                    • DessiVerse
                      @siam I updated the firmware and confirmed the update.
                      Console is still getting spammed with the below messages:
                      Recv: WiFi reported error: network scan failed
                      Recv: WiFi module is idle
                      Here is the result of M122
                      Send: M122
                      Recv: === Diagnostics ===
                      Recv: RepRapFirmware for Duet 3 Mini 5+ version 3.3beta3 (2021-04-22 13:48:16) running on Duet 3 Mini5plus WiFi (standalone mode)
                      Recv: Board ID: 7HDQX-V296U-D65J0-40KM8-MK03Z-R91J2
                      Recv: Used output buffers: 1 of 40 (1 max)
                      Recv: === RTOS ===
                      Recv: Static ram: 101772
                      Recv: Dynamic ram: 106336 of which 12 recycled
                      Recv: Never used RAM 35584, free system stack 160 words
                      Recv: Tasks: NETWORK(ready,8.0%,346) HEAT(delaying,0.0%,318) Move(notifyWait,0.1%,188) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,371) CanClock(notifyWait,0.0%,341) TMC(notifyWait,0.7%,115) MAIN(running,90.1%,426) IDLE(ready,0.3%,19) AIN(delaying,0.8%,273), total 100.0%
                      Recv: Owned mutexes: USB(MAIN)
                      Recv: === Platform ===
                      Recv: Last reset 00:01:10 ago, cause: software
                      Recv: Last software reset at 2021-04-28 12:14, reason: HardFault bfarValid precise, GCodes spinning, available RAM 35584, slot 2
                      Recv: Software reset code 0x0063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x00000044 SP 0x200036a8 Task MAIN Freestk 771 ok
                      Recv: Stack: 00000000 2000374c 00000571 00000000 00000000 0007be25 000836d8 610f0200 2001d580 00000000 00000000 00088e39 00000000 00000000 00000000 ffffffff 369dc3a0 2001d580 20002a40 2001d37c 20003730 200037d8 200037d6 00088f33 00000001 200202e8 200180d8
                      Recv: Error status: 0x00
                      Recv: Aux0 errors 0,0,0
                      Recv: Aux1 errors 0,0,0
                      Recv: MCU revision 3, ADC conversions started 70672, completed 70672, timed out 0, errs 0
                      Recv: Step timer max interval 745
                      Recv: MCU temperature: min 29.2, current 30.6, max 30.6
                      Recv: Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                      Recv: Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0
                      Recv: Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 20, reads 3696, writes 9, timeouts 0, DMA errors 0
                      Recv: Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 20, reads 3696, writes 9, timeouts 0, DMA errors 0
                      Recv: Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 3696, writes 9, timeouts 0, DMA errors 0
                      Recv: Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 3696, writes 9, timeouts 0, DMA errors 0
                      Recv: Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 3696, writes 9, timeouts 0, DMA errors 0
                      Recv: Driver 5: position 0, assumed not present
                      Recv: Driver 6: position 0, assumed not present
                      Recv: Date/time: 1970-01-01 00:00:00
                      Recv: Cache data hit count 146022799
                      Recv: Slowest loop: 25.74ms; fastest: 0.12ms
                      Recv: === Storage ===
                      Recv: Free file entries: 10
                      Recv: SD card 0 detected, interface speed: 22.5MBytes/sec
                      Recv: SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                      Recv: === Move ===
                      Recv: DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                      Recv: === MainDDARing ===
                      Recv: Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                      Recv: === AuxDDARing ===
                      Recv: === Heat ===
                      Recv: Bed heaters = 0 -1, chamberHeaters = -1 -1
                      Recv: Heater 1 is on, I-accum = 0.0
                      Recv: === GCodes ===
                      Recv: Segments left: 0
                      Recv: Movement lock held by null
                      Recv: HTTP is idle in state(s) 0
                      Recv: Telnet is idle in state(s) 0
                      Recv: File is idle in state(s) 0
                      Recv: USB is ready with "M122" in state(s) 0
                      Recv: Aux is idle in state(s) 0
                      Recv: Trigger is idle in state(s) 0
                      Recv: Queue is idle in state(s) 0
                      Recv: LCD is idle in state(s) 0
                      Recv: SBC is idle in state(s) 0
                      Recv: Daemon is idle in state(s) 0
                      Recv: Aux2 is idle in state(s) 0
                      Recv: Autopause is idle in state(s) 0
                      Recv: Code queue is empty.
                      Recv: === CAN ===
                      Recv: Messages queued 635, send timeouts 633, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                      Recv: Last cancelled message type 4514 dest 127
                      Recv: === Network ===
                      Recv: Slowest loop: 199.80ms; fastest: 0.00ms
                      Recv: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                      Recv: HTTP sessions: 0 of 8
                      Recv: - WiFi -
                      Recv: Network state is disabled
                      Recv: WiFi module is disabled
                      Recv: Failed messages: pending 0, notready 0, noresp 2
                      Recv: Socket states: 0 0 0 0 0 0 0 0
                      I started running the typical commands to try to get it to reconnect and got an error
                      Send: M552 S-1
                      Recv: ok
                      Send: M552
                      Recv: ok
                      Send: M105
                      Recv: ok T:19.8 /0.0 T0:19.8 /0.0 B:22.5 /0.0
                      Send: M552 S0
                      Recv: ok
                      Recv: WiFi module started
                      Send: M552 S1
                      Recv: ok
                      Send: M105
                      Recv: WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to
                      After spamming the "network scan failed" messages I got ran M552 to see the status and got Recv: WiFi module is connected to access point , IP address 255.255.255.255
                      • SIam
                        @dessiverse have you updated the DuetWiFiServer.bin ?
                        DessiVerse 2 Replies Last reply Reply Quote 0
                        • DessiVerse
                          @siam I’ve been trying to but it keeps saying the file doesn’t exist even though it’s in the sys directory.
                          • DessiVerse
                            jay_s_uk 1 Reply Last reply Reply Quote 0
                            • jay_s_uk
                              jay_s_uk @DessiVerse last edited by
                              @dessiverse it needs to be in a folder called firmware with 3.3 rather than in the sys folder
                              • DessiVerse
                                DessiVerse @jay_s_uk last edited by
                                @jay_s_uk just got it installed. Doesn't appear to be improved though.
                                • DessiVerse
                                  Here's an updated M122
                                  Send: M122
                                  Recv: Used output buffers: 1 of 40 (11 max)
                                  Recv: === RTOS ===
                                  Recv: Never used RAM 35584, free system stack 157 words
                                  Recv: Tasks: NETWORK(ready,19.8%,150) HEAT(delaying,0.0%,318) Move(notifyWait,0.1%,188) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,371) CanClock(notifyWait,0.0%,341) TMC(notifyWait,0.7%,115) MAIN(running,78.2%,426) IDLE(ready,0.4%,19) AIN(delaying,0.8%,273), total 100.0%
                                  Recv: Last reset 00:02:18 ago, cause: power up
                                  Recv: MCU revision 3, ADC conversions started 138334, completed 138334, timed out 0, errs 0
                                  Recv: Step timer max interval 1490
                                  Recv: MCU temperature: min 23.8, current 29.7, max 29.7
                                  Recv: Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                  Recv: Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 7247, writes 10, timeouts 0, DMA errors 0
                                  Recv: Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 7247, writes 10, timeouts 0, DMA errors 0
                                  Recv: Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 7247, writes 9, timeouts 0, DMA errors 0
                                  Recv: Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 7247, writes 9, timeouts 0, DMA errors 0
                                  Recv: Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 7248, writes 9, timeouts 0, DMA errors 0
                                  Recv: Date/time: 2021-04-28 13:32:52
                                  Recv: Cache data hit count 320404896
                                  Recv: Slowest loop: 1051.41ms; fastest: 0.12ms
                                  Recv: Free file entries: 9
                                  Recv: SD card longest read time 3.9ms, write time 0.0ms, max retries 0
                                  Recv: === Move ===
                                  Recv: === Heat ===
                                  Recv: === CAN ===
                                  Recv: Messages queued 1244, send timeouts 1241, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 16)
                                  Recv: Slowest loop: 1993.74ms; fastest: 0.00ms
                                  Recv: Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                                  Recv: HTTP sessions: 1 of 8
                                  Recv: - WiFi -
                                  Recv: Network state is active
                                  Recv: Failed messages: pending 0, notready 0, noresp 0
                                  Recv: WiFi firmware version 1.26
                                  Recv: WiFi MAC address f0:08:d1:02:ec:f2
                                  Recv: WiFi Vcc 3.33, reset reason Power up
                                  Recv: WiFi flash size 2097152, free heap 14336
                                  Recv: WiFi IP address 10.0.0.201
                                  Recv: WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem
                                  Recv: Clock register 00002002
                                  Recv: Socket states: 0 2 0 0 0 0 0 0
                                  Recv: ok
                                  • SIam
                                    @dessiverse this looks good so far now the Wi-Fi has a software version and now test if this problem persists
                                    • DessiVerse
                                      @SIam, I'm trying to upload a gcode to test the speed and it seems like it keeps slowing down. So the same issue I was having previously. I'd like to note I don't have this issue in SBC mode.
                                      EDIT: It now slowed down to 1.8 KIB/s. Here is the current M122:
                                      Send: M122
                                      Recv: Used output buffers: 2 of 40 (17 max)
                                      Recv: === RTOS ===
                                      Recv: Never used RAM 35584, free system stack 146 words
                                      Recv: Tasks: NETWORK(ready,15.8%,150) HEAT(delaying,0.0%,318) Move(notifyWait,0.1%,188) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,341) TMC(notifyWait,0.7%,115) MAIN(running,82.6%,372) IDLE(ready,0.0%,19) AIN(delaying,0.8%,273), total 100.0%
                                      Recv: Owned mutexes: WiFi(NETWORK) USB(MAIN)
                                      Recv: Last reset 00:08:20 ago, cause: power up
                                      Recv: MCU revision 3, ADC conversions started 501054, completed 501052, timed out 0, errs 0
                                      Recv: Step timer max interval 1489
                                      Recv: MCU temperature: min 29.7, current 32.8, max 32.8
                                      Recv: Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 19090, writes 0, timeouts 0, DMA errors 0
                                      Recv: Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 19090, writes 0, timeouts 0, DMA errors 0
                                      Recv: Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 19091, writes 0, timeouts 0, DMA errors 0
                                      Recv: Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 19090, writes 0, timeouts 0, DMA errors 0
                                      Recv: Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 19090, writes 0, timeouts 0, DMA errors 0
                                      Recv: Date/time: 2021-04-28 13:38:55
                                      Recv: Cache data hit count 1012800891
                                      Recv: Slowest loop: 12.17ms; fastest: 0.12ms
                                      Recv: SD card longest read time 4.2ms, write time 3.9ms, max retries 0
                                      Recv: === Move ===
                                      Recv: === Heat ===
                                      Recv: === CAN ===
                                      Recv: Messages queued 3265, send timeouts 3265, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                      Recv: Last cancelled message type 30 dest 127
                                      Recv: Slowest loop: 200.02ms; fastest: 0.06ms
                                      Recv: Responder states: HTTP(3) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                                      Recv: - WiFi -
                                      Recv: Failed messages: pending 0, notready 0, noresp 1
                                      Recv: WiFi flash size 2097152, free heap 20640
                                      Recv: WiFi signal strength -36dBm, mode 802.11n, reconnections 0, sleep mode modem
                                      Recv: ok
                                      Send: M105
                                      Recv: ok T:20.1 /0.0 T0:20.1 /0.0 B:22.5 /0.0
                                      • jay_s_uk
                                        @dessiverse what sd card are you using? Brand and model?
                                        • DessiVerse
                                          @jay_s_uk san disk edge, 8gb
                                          • DessiVerse
                                            @jay_s_uk I just tried using my SanDisk Extreme Pro to see if it was an issue with that and it doesn't seem to be the case. I use that micro sd with my high fps camera so read and writes are never an issue.
                                            • jay_s_uk
                                              @dessiverse the 8gb one appears to only be a class 4. A class 10 may be better. I suggest trying another as card if you have one.
                                              • jay_s_uk
                                                @dessiverse what speeds were you seeing with the extreme?
                                                • DessiVerse
                                                  same as before, and dropping since i took that screenshot. it's now down to 6 KIB/s.
                                                  • jay_s_uk
                                                    @dessiverse can you grab an M122 output while its uploading with the slower speed?
                                                    • DessiVerse
                                                      @jay_s_uk
                                                      Send: M122
                                                      Recv: Used output buffers: 1 of 40 (17 max)
                                                      Recv: === RTOS ===
                                                      Recv: Never used RAM 35584, free system stack 154 words
                                                      Recv: Tasks: NETWORK(ready,14.8%,221) HEAT(delaying,0.0%,318) Move(notifyWait,0.1%,188) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,341) TMC(notifyWait,0.7%,115) MAIN(running,83.6%,374) IDLE(ready,0.0%,19) AIN(delaying,0.8%,273), total 100.0%
                                                      Recv: Last reset 00:04:46 ago, cause: power up
                                                      Recv: MCU revision 3, ADC conversions started 286329, completed 286328, timed out 0, errs 0
                                                      Recv: Step timer max interval 752
                                                      Recv: MCU temperature: min 26.6, current 30.6, max 30.6
                                                      Recv: Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 10585, writes 0, timeouts 0, DMA errors 0
                                                      Recv: Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 10585, writes 0, timeouts 0, DMA errors 0
                                                      Recv: Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 10585, writes 0, timeouts 0, DMA errors 0
                                                      Recv: Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 10585, writes 0, timeouts 0, DMA errors 0
                                                      Recv: Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 10585, writes 0, timeouts 0, DMA errors 0
                                                      Recv: Date/time: 2021-04-28 14:54:39
                                                      Recv: Cache data hit count 551034519
                                                      Recv: Slowest loop: 4.92ms; fastest: 0.12ms
                                                      Recv: SD card longest read time 0.7ms, write time 0.0ms, max retries 0
                                                      Recv: === Move ===
                                                      Recv: === Heat ===
                                                      Recv: === CAN ===
                                                      Recv: Messages queued 1810, send timeouts 1810, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                                      Recv: Slowest loop: 200.87ms; fastest: 0.00ms
                                                      Recv: - WiFi -
                                                      Recv: WiFi flash size 2097152, free heap 20976
                                                      Recv: ok
