    WiFi Unreliable
    114
    7.4k
    • DessiVerseundefined
      DessiVerse
      Reading the M122 result signal strength is good at -39dBm so I'm not sure why I'm getting the problems I am. I was having upload speeds as slow as 3.5 KIB/s after posting the result.
      • SIamundefined
        SIam @DessiVerse
        @dessiverse your signal strength looks not bad (mine is worse and have no problem ). If your WLAN connection is slow again can you post again the result of M122. Perhaps is an Update to RRF 3.3 B3 a solution
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        DessiVerseundefined 1 Reply Last reply Reply Quote 0
          DessiVerse @SIam
          @siam how would I go about updating?
          SIamundefined 1 Reply Last reply Reply Quote 0
          • SIamundefined
            SIam @DessiVerse
            @dessiverse Here is the documentation https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
            The latest firmware you find here: https://forum.duet3d.com/topic/22878/software-package-3-3beta3-released
              DessiVerse @SIam
              @siam I updated the firmware and confirmed the update.
              Console is still getting spammed with the below messages:
              Recv: WiFi reported error: network scan failed
              Recv: WiFi module is idle
              Here is the result of M122
              Send: M122
              Recv: === Diagnostics ===
              Recv: RepRapFirmware for Duet 3 Mini 5+ version 3.3beta3 (2021-04-22 13:48:16) running on Duet 3 Mini5plus WiFi (standalone mode)
              Recv: Board ID: 7HDQX-V296U-D65J0-40KM8-MK03Z-R91J2
              Recv: Used output buffers: 1 of 40 (1 max)
              Recv: === RTOS ===
              Recv: Static ram: 101772
              Recv: Dynamic ram: 106336 of which 12 recycled
              Recv: Never used RAM 35584, free system stack 160 words
              Recv: Tasks: NETWORK(ready,8.0%,346) HEAT(delaying,0.0%,318) Move(notifyWait,0.1%,188) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,371) CanClock(notifyWait,0.0%,341) TMC(notifyWait,0.7%,115) MAIN(running,90.1%,426) IDLE(ready,0.3%,19) AIN(delaying,0.8%,273), total 100.0%
              Recv: Owned mutexes: USB(MAIN)
              Recv: === Platform ===
              Recv: Last reset 00:01:10 ago, cause: software
              Recv: Last software reset at 2021-04-28 12:14, reason: HardFault bfarValid precise, GCodes spinning, available RAM 35584, slot 2
              Recv: Software reset code 0x0063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x00000044 SP 0x200036a8 Task MAIN Freestk 771 ok
              Recv: Stack: 00000000 2000374c 00000571 00000000 00000000 0007be25 000836d8 610f0200 2001d580 00000000 00000000 00088e39 00000000 00000000 00000000 ffffffff 369dc3a0 2001d580 20002a40 2001d37c 20003730 200037d8 200037d6 00088f33 00000001 200202e8 200180d8
              Recv: Error status: 0x00
              Recv: Aux0 errors 0,0,0
              Recv: Aux1 errors 0,0,0
              Recv: MCU revision 3, ADC conversions started 70672, completed 70672, timed out 0, errs 0
              Recv: Step timer max interval 745
              Recv: MCU temperature: min 29.2, current 30.6, max 30.6
              Recv: Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
              Recv: Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0
              Recv: Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 20, reads 3696, writes 9, timeouts 0, DMA errors 0
              Recv: Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 20, reads 3696, writes 9, timeouts 0, DMA errors 0
              Recv: Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 3696, writes 9, timeouts 0, DMA errors 0
              Recv: Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 3696, writes 9, timeouts 0, DMA errors 0
              Recv: Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 19, reads 3696, writes 9, timeouts 0, DMA errors 0
              Recv: Driver 5: position 0, assumed not present
              Recv: Driver 6: position 0, assumed not present
              Recv: Date/time: 1970-01-01 00:00:00
              Recv: Cache data hit count 146022799
              Recv: Slowest loop: 25.74ms; fastest: 0.12ms
              Recv: === Storage ===
              Recv: Free file entries: 10
              Recv: SD card 0 detected, interface speed: 22.5MBytes/sec
              Recv: SD card longest read time 3.2ms, write time 0.0ms, max retries 0
              Recv: === Move ===
              Recv: DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              Recv: === MainDDARing ===
              Recv: Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
              Recv: === AuxDDARing ===
              Recv: === Heat ===
              Recv: Bed heaters = 0 -1, chamberHeaters = -1 -1
              Recv: Heater 1 is on, I-accum = 0.0
              Recv: === GCodes ===
              Recv: Segments left: 0
              Recv: Movement lock held by null
              Recv: HTTP is idle in state(s) 0
              Recv: Telnet is idle in state(s) 0
              Recv: File is idle in state(s) 0
              Recv: USB is ready with "M122" in state(s) 0
              Recv: Aux is idle in state(s) 0
              Recv: Trigger is idle in state(s) 0
              Recv: Queue is idle in state(s) 0
              Recv: LCD is idle in state(s) 0
              Recv: SBC is idle in state(s) 0
              Recv: Daemon is idle in state(s) 0
              Recv: Aux2 is idle in state(s) 0
              Recv: Autopause is idle in state(s) 0
              Recv: Code queue is empty.
              Recv: === CAN ===
              Recv: Messages queued 635, send timeouts 633, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
              Recv: Last cancelled message type 4514 dest 127
              Recv: === Network ===
              Recv: Slowest loop: 199.80ms; fastest: 0.00ms
              Recv: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
              Recv: HTTP sessions: 0 of 8
              Recv: - WiFi -
              Recv: Network state is disabled
              Recv: WiFi module is disabled
              Recv: Failed messages: pending 0, notready 0, noresp 2
              Recv: Socket states: 0 0 0 0 0 0 0 0
              I started running the typical commands to try to get it to reconnect and got an error
              Send: M552 S-1
              Recv: ok
              Send: M552
              Recv: ok
              Send: M105
              Recv: ok T:19.8 /0.0 T0:19.8 /0.0 B:22.5 /0.0
              Send: M552 S0
              Recv: ok
              Recv: WiFi module started
              Send: M552 S1
              Recv: ok
              Send: M105
              Recv: WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to
              After spamming the "network scan failed" messages I got ran M552 to see the status and got Recv: WiFi module is connected to access point , IP address 255.255.255.255
              • SIamundefined
                SIam @DessiVerse
                @dessiverse have you updated the DuetWiFiServer.bin ?
                DessiVerseundefined 2 Replies Last reply Reply Quote 0
                  DessiVerse @SIam
                  @siam I’ve been trying to but it keeps saying the file doesn’t exist even though it’s in the sys directory.
                    DessiVerse @SIam
                      jay_s_uk @DessiVerse
                      @dessiverse it needs to be in a folder called firmware with 3.3 rather than in the sys folder
                        DessiVerse @jay_s_uk
                        @jay_s_uk just got it installed. Doesn't appear to be improved though.
                          DessiVerse
                          Here's an updated M122
                          Send: M122
                          Recv: Used output buffers: 1 of 40 (11 max)
                          Recv: === RTOS ===
                          Recv: Never used RAM 35584, free system stack 157 words
                          Recv: Tasks: NETWORK(ready,19.8%,150) HEAT(delaying,0.0%,318) Move(notifyWait,0.1%,188) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,371) CanClock(notifyWait,0.0%,341) TMC(notifyWait,0.7%,115) MAIN(running,78.2%,426) IDLE(ready,0.4%,19) AIN(delaying,0.8%,273), total 100.0%
                          Recv: Last reset 00:02:18 ago, cause: power up
                          Recv: MCU revision 3, ADC conversions started 138334, completed 138334, timed out 0, errs 0
                          Recv: Step timer max interval 1490
                          Recv: MCU temperature: min 23.8, current 29.7, max 29.7
                          Recv: Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                          Recv: Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 7247, writes 10, timeouts 0, DMA errors 0
                          Recv: Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 7247, writes 10, timeouts 0, DMA errors 0
                          Recv: Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 7247, writes 9, timeouts 0, DMA errors 0
                          Recv: Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 7247, writes 9, timeouts 0, DMA errors 0
                          Recv: Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 7248, writes 9, timeouts 0, DMA errors 0
                          Recv: Date/time: 2021-04-28 13:32:52
                          Recv: Cache data hit count 320404896
                          Recv: Slowest loop: 1051.41ms; fastest: 0.12ms
                          Recv: Free file entries: 9
                          Recv: SD card longest read time 3.9ms, write time 0.0ms, max retries 0
                          Recv: === Move ===
                          Recv: === Heat ===
                          Recv: === CAN ===
                          Recv: Messages queued 1244, send timeouts 1241, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 16)
                          Recv: Slowest loop: 1993.74ms; fastest: 0.00ms
                          Recv: Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                          Recv: HTTP sessions: 1 of 8
                          Recv: - WiFi -
                          Recv: Network state is active
                          Recv: Failed messages: pending 0, notready 0, noresp 0
                          Recv: WiFi firmware version 1.26
                          Recv: WiFi MAC address f0:08:d1:02:ec:f2
                          Recv: WiFi Vcc 3.33, reset reason Power up
                          Recv: WiFi flash size 2097152, free heap 14336
                          Recv: WiFi IP address 10.0.0.201
                          Recv: WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem
                          Recv: Clock register 00002002
                          Recv: Socket states: 0 2 0 0 0 0 0 0
                          Recv: ok
                          • SIamundefined
                            SIam @DessiVerse
                            @dessiverse this looks good so far now the Wi-Fi has a software version and now test if this problem persists
                              DessiVerse
                              @SIam, I'm trying to upload a gcode to test the speed and it seems like it keeps slowing down. So the same issue I was having previously. I'd like to note I don't have this issue in SBC mode.
                              EDIT: It now slowed down to 1.8 KIB/s. Here is the current M122:
                              Send: M122
                              Recv: Used output buffers: 2 of 40 (17 max)
                              Recv: === RTOS ===
                              Recv: Never used RAM 35584, free system stack 146 words
                              Recv: Tasks: NETWORK(ready,15.8%,150) HEAT(delaying,0.0%,318) Move(notifyWait,0.1%,188) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,341) TMC(notifyWait,0.7%,115) MAIN(running,82.6%,372) IDLE(ready,0.0%,19) AIN(delaying,0.8%,273), total 100.0%
                              Recv: Owned mutexes: WiFi(NETWORK) USB(MAIN)
                              Recv: Last reset 00:08:20 ago, cause: power up
                              Recv: MCU revision 3, ADC conversions started 501054, completed 501052, timed out 0, errs 0
                              Recv: Step timer max interval 1489
                              Recv: MCU temperature: min 29.7, current 32.8, max 32.8
                              Recv: Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 19090, writes 0, timeouts 0, DMA errors 0
                              Recv: Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 19090, writes 0, timeouts 0, DMA errors 0
                              Recv: Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 19091, writes 0, timeouts 0, DMA errors 0
                              Recv: Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 19090, writes 0, timeouts 0, DMA errors 0
                              Recv: Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 19090, writes 0, timeouts 0, DMA errors 0
                              Recv: Date/time: 2021-04-28 13:38:55
                              Recv: Cache data hit count 1012800891
                              Recv: Slowest loop: 12.17ms; fastest: 0.12ms
                              Recv: SD card longest read time 4.2ms, write time 3.9ms, max retries 0
                              Recv: === Move ===
                              Recv: === Heat ===
                              Recv: === CAN ===
                              Recv: Messages queued 3265, send timeouts 3265, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                              Recv: Last cancelled message type 30 dest 127
                              Recv: Slowest loop: 200.02ms; fastest: 0.06ms
                              Recv: Responder states: HTTP(3) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                              Recv: - WiFi -
                              Recv: Failed messages: pending 0, notready 0, noresp 1
                              Recv: WiFi flash size 2097152, free heap 20640
                              Recv: WiFi signal strength -36dBm, mode 802.11n, reconnections 0, sleep mode modem
                              Recv: ok
                              Send: M105
                              Recv: ok T:20.1 /0.0 T0:20.1 /0.0 B:22.5 /0.0
                                @dessiverse what sd card are you using? Brand and model?
                                  @jay_s_uk san disk edge, 8gb
                                    @jay_s_uk I just tried using my SanDisk Extreme Pro to see if it was an issue with that and it doesn't seem to be the case. I use that micro sd with my high fps camera so read and writes are never an issue.
                                      @dessiverse the 8gb one appears to only be a class 4. A class 10 may be better. I suggest trying another as card if you have one.
                                        @dessiverse what speeds were you seeing with the extreme?
                                          same as before, and dropping since i took that screenshot. it's now down to 6 KIB/s.
                                            @dessiverse can you grab an M122 output while its uploading with the slower speed?
