WiFi module not working on Duet 2 WiFi 1.04c
Hi Everyone
So I have recently bought a Duet 2 WiFi 1.04c board and everything seems to be working just fine, except the WiFi. I am planning to run it as an access point, for other electronics to connect to. All the steps outlined on the website were followed in detail (the M552 S0's, M589's etc), but I could never get the WiFi module enabled and/or in idle mode. Whenever I send the M122 command, the WiFi module is disabled for some reason unknown to me.
Does anybody have advice? At this stage, the only other explanation would be a dead WiFi module (ESP-07s). Is there a way to test this using e.g. a voltmeter?
Many thanks.
PJ -
@pjkruger pls post the result of M122
M122:
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
Board ID: 08DLM-996RU-N8PS4-6J9D6-3SD6K-9UUBN
Used output buffers: 5 of 24 (11 max)
Static ram: 23460
Dynamic ram: 72036 of which 0 recycled
Never used RAM 16584, free system stack 190 words
Tasks: NETWORK(ready,521) HEAT(blocked,366) MAIN(running,419) IDLE(ready,20)
Owned mutexes: USB(MAIN)
Last reset 00:00:50 ago, cause: power up
Last software reset time unknown, reason: User, GCodes spinning, available RAM 16548, slot 0
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 20.1, current 20.8, max 21.0
Supply voltage: min 0.2, current 0.4, max 0.4, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: position 0, ok, SG min/max not available
Driver 1: position 0, ok, SG min/max not available
Driver 2: position 0, ok, SG min/max not available
Driver 3: position 0, ok, SG min/max not available
Driver 4: position 0, ok, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Cache data hit count 67293480
Slowest loop: 100.55ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.1ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.22ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is starting2
Failed messages: pending 0, notready 1, noresp 0
ok
M589: (With all the other S, P, I parameters):
Error: M589: Failed to retrieve own SSID data: another SPI transfer is pending
ok
- WiFi -
@pjkruger said in WiFi module not working on Duet 2 WiFi 1.04c:
I'm not complete sure, but I think you have to install the DuetWiFiServer.bin from the RRF 3.2.2 to get wifi to work
Please try sending M997 S1 to initiate the wifi firmware flash. It seems to have not gone through previously.
I uploaded via SD card RRF 3.2.2 DuetWifiServer.bin to /sys and sent M997 S1, response as follows:
M997 S1
Trying to connect at 230400 baud: success
Erasing 4096 bytes...
Erasing 196608 bytes...
Uploading file...
5% complete
10% complete
15% complete
20% complete
25% complete
30% complete
35% complete
40% complete
45% complete
50% complete
55% complete
60% complete
65% complete
70% complete
75% complete
80% complete
85% complete
90% complete
95% complete
Upload successful
ok
Disconnected, reconnected, sent the following:
M552 S0
ok
M552
WiFi module is being started
ok
M122
Used output buffers: 5 of 24 (10 max)
Static ram: 23460
Never used RAM 16584, free system stack 192 words
Tasks: NETWORK(ready,521) HEAT(blocked,366) MAIN(running,492) IDLE(ready,20)
Last reset 00:00:44 ago, cause: power up
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 16.4, current 18.7, max 19.1
Supply voltage: min 0.3, current 0.5, max 0.7, under voltage events: 0, over voltage events: 0, power good: no
Cache data hit count 60541246
Slowest loop: 5.27ms; fastest: 0.14ms
=== Storage ===
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
=== Network ===
Slowest loop: 1.02ms; fastest: 0.00ms
ok
Still no luck.
- WiFi -
How bout just sending m552 S1?
@pjkruger please try running M997 S1 again. Sometimes the firmware upload fails first time, and unfortunately the ESP flashing mechanism does not provide any error checking. After it reports successful completion, try M552 S0 again. If necessary, power the Duet down and up again.
If after that it still always reports "WiFi module is being started" when you send M552, and it's a genuine Duet, then I will approve a replacement under warranty.
M552 S1
Turn off the current WiFi mode before selecting a new one
ok
M552 S-1
WiFi module stopped
ok
M552 S1
ok
M552
ok
M122
Used output buffers: 2 of 24 (11 max)
Static ram: 23460
Tasks: NETWORK(ready,519) HEAT(blocked,366) MAIN(running,427) IDLE(ready,20)
Last reset 00:01:36 ago, cause: power up
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 20.7, current 21.6, max 21.7
Supply voltage: min 0.5, current 0.5, max 0.7, under voltage events: 0, over voltage events: 0, power good: no
Cache data hit count 133944405
Slowest loop: 99.34ms; fastest: 0.14ms
=== Storage ===
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
=== Network ===
Slowest loop: 0.19ms; fastest: 0.00ms
ok
No Luck
- WiFi -
M997 S1
Uploading file...
5% complete
10% complete
15% complete
20% complete
25% complete
30% complete
35% complete
40% complete
45% complete
50% complete
55% complete
60% complete
65% complete
70% complete
75% complete
80% complete
85% complete
90% complete
95% complete
Upload successful
ok
Power off; on
M552 S0
ok
M552
ok
M122
Used output buffers: 4 of 24 (9 max)
Static ram: 23460
Tasks: NETWORK(ready,521) HEAT(blocked,366) MAIN(running,524) IDLE(ready,20)
Last reset 00:00:45 ago, cause: power up
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 21.2, current 23.6, max 23.9
Supply voltage: min 0.3, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
Cache data hit count 62597900
Slowest loop: 5.28ms; fastest: 0.14ms
=== Storage ===
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
=== Network ===
ok
Again seems to be no luck. I can confirm it is a genuine Duet, purchased from Da Vinci Labs in RSA (Graeme). You are most welcome to contact them to verify, they are aware of the situation and pointed me to this forum since they don't provide after-sale service.
- WiFi -
@pjkruger Please contact your vendor to initiate a warranty exchange. Include a link to this thread as authorization.
