    End of print conditional position change?
    Gcode meta commands
    • Thaliosundefined
      Thalios
      Hello, I'm trying to make my life a touch easier and prevent errors like clicking the wrong button at the end of a print, so I was wondering if there's a way to do this:
      I want the Z to increase by 100 at the end of a print, but not if it will go past the limit (305).
      Is it possible to add a end gcode in the slicer like:
      if Z is between 0 and 200, add 100 to Z
      If Z is between 201 and 249, Move Z to 300
      If Z is 250 or more, don't move Z
      Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
      Heavily modified Ender 3 Pro (Duet 3 6HC)
      Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
      CR-10S Pro V2 (Duet 3 Mini 5+)
      and a bunch of SLA printers..
      engikeneerundefined 1 Reply Last reply Reply Quote 0
      • engikeneerundefined
        engikeneer @Thalios
        @thalios if you've set up your machine limits it will respect them anyway
        Try moving to z=300, then jogging it 100mm via DWC. It will still end up at 305mm in your case. Simply add a relative motion to your end gcode.
        Alternatively you could add some conditional gcode to stop.g to do something more clever?
        i3 clone with a bunch of mods
        Thaliosundefined 1 Reply Last reply Reply Quote 1
        • Thaliosundefined
          Thalios @engikeneer
          @engikeneer That's not really what I want to do. Yes it is set properly in the Duet, but I want it to do different things as per my example depending on where it's at. I don't want a 25mm print to send the bed all the way down to 305 for nothing.
          OwenDundefined 1 Reply Last reply Reply Quote 0
          • OwenDundefined
            OwenD @Thalios
            @thalios
            Do as @engikeneer suggested and put your conditional code in stop.g
            use the object model to get the current Z height.
            • Thaliosundefined
              Thalios
              I was thinking something like this:
              {if Z< 200} G1 Z+100 F10000
              {elsif Z>= 200} G1 Z300 F10000
              {endif}
              I just cannot find infos on wether these commands are valid..
              I guess i'll just try it hehe
              • OwenDundefined
                OwenD @Thalios
                @thalios said in End of print conditional position change?:
                {endif}
                The wiki section on IF statements is here
                https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Conditional_construct
                There are lots of examples in the meta commands section of the forum that should help you construct what you want.
                • Thaliosundefined
                  Thalios
                  Wow I was approaching this totally the wrong way...
                  All I have to do, as per your recommandations, is to set in relative mode, and add 100 to Z...
                  I was WAYYYYYYY overthinking this...
                  Thanks guys
