    CoreXY: X is now Y, Y is now X
    931
    • Stephen6309undefined
      Stephen6309
      Current Firmware 3.3RC1 on 6HC w/Pi4 and 1LC.
      X is now going Y direction.
      Y is now going X direction.
      No hardware changes.
      Going back to 3.3beta3, no change.
      Shutting it down and firing up to same problem.
      Had to swap the X and Y endstops to get homing to work.
      Even tried going back to an older config.g file, no change.
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat May 01 2021 13:39:57 GMT-0400 (Eastern Daylight Time)
      G90                                                       ; send absolute coordinates...
      M83                                                       ; ...but relative extruder moves
      M550 P"CXY-MSv1"                                          ; set printer name
      M669 K1                                                   ; select CoreXY mode
      M569 P0.0 S1                                              ; physical drive 0.0 goes forwards
      M569 P0.1 S1                                              ; physical drive 0.1 goes forwards
      M569 P0.2 S1                                              ; physical drive 0.2 goes forwards
      M569 P121.0 S0                                            ; physical drive 121.0
      M584 X0.0 Y0.1 Z0.2 E121.0                                ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                                   ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00 E418.00                         ; set steps per mm
      M566 X2000.00 Y2000.00 Z180.00 E120.00                    ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z1800.00 E3000.00                ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z30.00 E250.00                       ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z800 E800 I30                            ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                   ; Set idle timeout
      M208 X0 Y0 Z0 S1                                          ; set axis minima
      M208 X300 Y400 Z150 S0                                    ; set axis maxima
      M574 X1 S1 P"io2.in"                                      ; configure active-high endstop for low end on X
      M574 Y1 S1 P"121.io1.in"                                  ; configure active-high endstop for low end on Y
      M574 Z1 S2                                                ; configure Z-probe endstop for low end on Z
      M950 S0 C"121.io0.out"                                    ; create servo pin 0 for BLTouch
      M558 P9 C"^121.io0.in" H5 F120 T6000                       ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-60 Y0 Z0                                      ; set Z probe trigger value, offset and trigger height
      M557 X15:300 Y15:400 S50                                  ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4092              ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                        ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                          ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                   ; map heated bed to heater 0
      M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0
      M950 H1 C"121.out0" T1                                    ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                              ; set temperature limit for heater 1 to 280C
      M950 F0 C"out9" Q500                                      ; create fan 0 on pin out9 and set its frequency
      M106 P0 C"Parts" S0 H-1                                   ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"121.out1" Q500                                  ; create fan 1 on pin 121.out1 and set its frequency
      M106 P1 C"Hotend" S1 H1 T45                               ; set fan 1 name and value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                          ; define tool 0
      G10 P0 X0 Y0 Z0                                           ; set tool 0 axis offsets
      G10 P0 R0 S0                                              ; set initial tool 0 active and standby temperatures to 0C
      ; Custom settings
      M376 H5                                                   ; taper bed compensation
      M572 D0 S0.05                                             ; pressure advance
      M207 S1.5 F6000	R0 Z0.03                                  ; firmware retraction
      M143 H1 S300                                              ; set temperature limit for heater 1 to 300C
      ;M566 P1                                                  ; Jerk policy,  1 allows jerk to be applied between any pair of moves.
      M912 P0 S-9											                                    ; set mcu temp offset
      G10 P0 S0 R0                                              ; set T0 heater off
      M150 B0 U0 R0 P128 S10 F0                                 ; all neopixels off
      M912 P0 S4											                                     ; calibrate MPU temp
      M575 P1 S1 B57600                                         ; enable support for PanelDue
      M501                                                      ; load saved parameters from non-volatile memory
      M911 S23 R24 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"        ; set voltage thresholds and actions to run on power loss
      T0                                                        ; select first tool
      X and Y are separate, since one axis get to home first and the second goes very slowly.
      ; homeall.g
      ; called to home all axes
      G1 H2 Z10 F6000          ; lift Z relative to current position
      G1 H1 X-450 F6000       ; home X axis
      G1 X5 F6000          ; go back a few mm
      G1 H1 X-405 F360        ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-400 F6000       ; home Y axis
      G1 Y5 F6000          ; go back a few mm
      G1 H1 Y-305 F360        ; then move slowly to Y axis endstop
      G1 X200 Y200 F6000        ; go to first bed probe point and home Z
      G30                     ; home Z by probing the bed
      G1 Z10
      ;G91                    ; relative positioning
      ;G1 Z5 F100             ; lift Z relative to current position
      ;G90                    ; absolute positioning
      Phaedruxundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
        Can you do the motor movement tests described here?
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
        Stephen6309undefined 2 Replies Last reply Reply Quote 0
          Stephen6309 @Phaedrux
          @phaedrux Did them. X still go front/back. Y goes right/left. Swapping driver for X & Y just reverses one of the axes. Fired it up today and it still does it. X0 Y0 is the front left.
            @phaedrux Same thing in stand alone mode.
              Phaedrux Moderator @Stephen6309
              @stephen6309 said in CoreXY: X is now Y, Y is now X:
              When exactly did you notice the change? After updating the firmware? And going back to previous firmware didn't change anything?
              I'm a bit confused about what might have changed.
              Does -x move to the left, +x move to the right?
              Does -y move to the front, =y move to the back?
              X endstop is still on the left side?
              Y endstop is on the front side?
              Can you post the results of M122 and M122 B1?
              Also the results of M98 P"config.g" please.
              Stephen6309undefined 1 Reply Last reply Reply Quote 0
                @phaedrux X endstop is now front right (makes a mirror print on X)
                Y endstop is one left of axis the extruder is on.
                It was X endostop on left of extruder, Y was homing to the switch front on right side.
                Bed is 400x300. Was 400 on X, 300 on Y.
                Was going like X & Y on a cartesion like my other printer.
                Since then X & Y have swapped, X is now 300, Y is now 400.
                Also, updated 6HC to 3.3RC1+1.
                It occured when updating to 3.3RC1 via DWC, the apt-get wasn't updating to it, and I made a new config on the configurator, since I had the wrong config.json for the printer. Going back to the prior config.g didn't change it.
                  Ok, so your motors are at the "rear" so 180 degree flip from "normal". I use quotes because it's all relative.
                  That makes very little sense. Regardless, we can fix it to make sense again.
                  Let's start from the top with our absolutes.
                  0,0 will be the front left corner of the print bed.
                  -x will be left, +x will be right
                  -y will be to the front, +y will be to the back
                  X endstop is on the right side/high end (M574 X2)
                  X homing move will be positive (G1 H1 X+500)
                  Y endstop is at the front/low end (M574 Y1)
                  Y homing move will be negative (G1 H1 Y-500)
                  Your slicer might need to reflect this as well.
                  Those facts do not change.
                  Now with that set in stone, do the motor tests again. This will help you determine what needs to happen next. Either swap motor connectors, change direction of rotation, etc.
                  • o_lampeundefined
                    o_lampe @Stephen6309
                    Can you confirm that firmware changes (back and forth) were applied to both boards?
                      @phaedrux said in CoreXY: X is now Y, Y is now X:
                      On the config.json, it like to keep it current with the config.g. The json was for a different printer. So, I remade it by copying the currect config.g settings. Copied the new congi.g and json into system. It would be nice configurater needs to be able to make a config.json from the config.g file.
                      Yes it is.
                      That's the way it used to work.
                      +X currently goes back
                      +Y currently goes to the right
                      X was on left/low side.
                      Homing X has always been -X
                      was on the front/low side on the right.
                      Homing Y has always been -Y
                      Bed moves up to home Z.
                      Priusa slicer has nothing to due with what the printer is currently doing.
                      M569 P0.0 S1 for the correct direction
                      M569 P0.1 S1
                      G1 H2 X10 F3000: move the extruder diagonally back and left
                      G1 H2 Y10 F3000: move extrueder diagonally to left and back
                      My homeall.g was posted above. Works fine if I swap the X/Y endstop config. Otherwise, the endstops never trigger, since it's mi=oving the wrong axis.
                      My endstops used to configured:
                      M574 X1 S1 P"121.io1.in"
                      M574 Y1 S1 P"io2.in"
                      They worked as expected.
                      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.3RC1+1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2021-05-01 21:43:52
                      Duet TOOL1LC firmware version 3.3RC1 (2021-04-29 10:21:18)
                      The config.g is what is current. The way the printer moves, the the front/back axis, now X, is mirrored.
                      Home X, it now moves to the front. It was to the left.
                      Home Y, it now moves to the left. It was to the front.
                        Have you moved the endstops from where they were originally? If you've changed things to accommodate the problem we're not actually solving the problem.
                        It doesn't really matter where the endstops are located as long as we're able to tell the firmware where they are and instruct it to move to hit those endstops.
                        This is how it should be and how it will be because we say so. If it's not currently doing that does not matter, we will make the changes needed to make it so.
                        So either move the endstops back how they originally were or leave them where they are, either way just let me know.
                          Part of the confusion may also be resulting from the 180 degree rotation with the motors in the rear. That would mean the expected movement from the tests would be inverted as well. Do you get what I mean?
                          The motors here are in the rear, as they are in your machine. This would be 180 degree rotation from the "normal" corexy where the motors are in the front side. This just means that the direction of X and Y are inverted from the expectation, placing 0,0 in the back right corner. The back right is the same as the front left, just rotated half way round. Does that make sense?
                            @phaedrux Since I built it with the original Duet Wifi and changed to a Duet 3 6HC, X0 Y0 was in the front left corner. X move left/right, Y moved front/back.
                            Now it doesn't, it swapped X and Y.
                              Yes, I understand.
                              Where are you endstops located now?
                                @phaedrux The tests are viewed from the front, where the M M is on your graphic and where the PanelDue is mounted.
                                One endstop is on the left of the extruder carraige, was the X. It's mount on purple petg to the left of the wirechain bracket in the photo. The other one the front of the right carriage wheel plate of the extruder axis, was the Y. It's mounted on red pla in the photo.
                                  @phaedrux Just ran a test print with lettering. I was only expect one reverse axis, but both are reversed. Looks like X0 Y0 needs to change.
                                    Ok, so if the X endstop is on the left it's at the low end. So M574 X1 and the homing moves should move in the negative direction.
                                    If Y is triggering when the print head is towards the front, then it's at the low end. M574 Y1 and the homing moves should be negative direction.
                                    Now based on the tests here: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
                                    Start with
                                    M569 P0 S0 ; X motor runs forwards
                                    M569 P1 S0 ; Y motor runs forwards
                                    Then send
                                    G91
                                    G1 H2 X10 F3000
                                    And
                                    G91
                                    G1 H2 Y10 F3000
                                    What do you get?
                                      G91
                                      G1 H2 X10 F3000
                                      Move diagonally towards left front corner
                                      G1 H2 Y10 F3000
                                      Move diagonally toward front right coner.
                                        G1 H2 X10 F3000
                                        Ok so..
                                        If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command.
                                        G1 H2 Y10 F3000
                                        Ok so...
                                        If the head moves diagonally in the +X and -Y directions, all is well.
                                        Ok, so change to M569 P0 S1 and retest.
                                          Already configured for S1 for 0 and 1.
                                          G1 H2 X10 F3000
                                          Moves diagonally to right and rear.
                                          G1 H2 Y10 F3000
                                          Moves diagonally to left and rear.
                                            G1 H2 X10 F3000
                                            If the head moves diagonally in the +X and +Y directions, all is well.
                                            G1 H2 Y10 F3000
                                            If it moves in the -X and +Y directions, change the S parameter in the M569 P1 command to S1.
