    [3.3-RC1] - Disabling DAA bug
    Beta Firmware
    • BoAundefined
      BoA
      I noticed that one of my macro causes error when it thies to disable DAA using command M593 F0, as documented in gcode wiki:
      "Fnnn Frequency of ringing to cancel by DAA, in Hz. Zero or negative values disable DAA"
      M593 F0
      Error: M593: parameter 'F' too low
      and DAA is not disabled.
      Also executing M593 F0 during print caused print to stop, but not same way as pausing it. After pause-resume on web gui print is continued properly.
      Duet3 3.3-RC1 standalone.
        dc42 administrators @BoA
        @boa try using M593 P0 to disable DAA.
        sebkritikelundefined 1 Reply Last reply Reply Quote 1
        • sebkritikelundefined
          sebkritikel @dc42
          Can confirm M593 P0 is what (now) does the trick.
          3.3beta3
          M593 F0
          M593 P0
          M593
          Input shaping is disabled
          3.3RC1
          M593 F0
          M593 P0
          M593
          Large(ish?) IDEX - 6HC, 1HCL
          Stratasys Dimension 1200es to 6HC Conversion
            dc42 administrators @sebkritikel
            @sebkritikel thanks, I will update the documentation.
