    noob help dule z setup
    2.4k
      droftarts administrators @Mobietec
      @mobietec This is my bed levelling macro:
      ; Two point bed levelling, automatic leadscrew adjustment
      M561                                 ; clear any bed transform
      G29 S2                               ; disable compensation
      G28                                  ; home all axes
      M671 X255:-255 Y0:0 S5               ; leadscrews at right (255,0) and left (-255,0)
      G30 P0 X135 Y-145 Z-99999            ; probe near right front adjusting screw
      G30 P1 X-145 Y-145 Z-99999 S2        ; probe near left front adjusting screw and report adjustments needed
      G1 X0 Y0 F6000
      I also have a macro for manually levelling the bed; I have just three of the adjustable screws, not all six:
      ; Three point bed levelling
      G28                                  ; home all axes
      M671 X160:-160:0 Y-160:-160:160 P0.5 ; adjusting screws at front right (160,-160) and front left (-160,-160), rear centre (0,160) thread pitch M3 0.5mm
      G30 P0 X135 Y-145 Z-99999            ; probe near an adjusting screw
      G30 P1 X-145 Y-145 Z-99999           ; probe near an adjusting screw
      G30 P2 X0 Y145 Z-99999 S3            ; probe near an adjusting screw and report adjustments needed
      G1 X0 Y0 F6000
      These rely on a number of settings in config.g, particularly M208 bed size and G31 probe X Y offset:
      ; Dual Z
      M584 X0 Y1 Z2:3 E4                                 ; Set drive mapping - 2 Z right, 3 Z left
      M208 X-165 Y-165 Z0 S1                         ; set axis minima
      M208 X165 Y165 Z400 S0                         ; set axis maxima
      M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
      M558 A10 S0.003 B0 R0.2                        ; BLTouch extra settings from Phaedrux
      G31 P500 X-30 Y0 Z1.65                            ; set Z probe trigger value, offset and trigger height
      M557 X-145:135 Y-145:145 P5                   ; define mesh grid
      Hope that helps.
        @mobietec said in noob help dule z setup:
        @mobietec where can i see the log reports please if this has any after the dual z i get bad command in config file any idears
        In config.g? Send M98 P"config.g" to run config.g, and it will report errors in the console. Post config.g and error reported if you can't find it.
        Mobietecundefined 1 Reply Last reply Reply Quote 0
        • Mobietecundefined
          Mobietec @droftarts
          @droftarts uploaded your did a twick all working well many thanks no errors upon running many thank and i do aprecate the help
          im slowley getting the hang of this lol @ me i chouice duet3 as i was told its the best
          im trying out the config forst on the tronxy x5sa upgrading it soon to 3z then im going to rebuild it at 500x500 would like to do 4z but 1 step at a time next will be tool board this will free up a driver for me to do 3 or 4z
          G28 ; home all axes
          M671 X165:-165 Y0:0 S5 ; leadscrews at right (255,0) and left (-255,0)
          G30 P0 X135 Y0 Z-99999 ; probe near right front adjusting screw
          G30 P1 X-145 Y0 Z-99999 S2 ; probe near left front adjusting screw and report adjustments needed
          G1 X0 Y0 F6000
          Mobietecundefined droftartsundefined 2 Replies Last reply Reply Quote 0
          • Mobietecundefined
            Mobietec @Mobietec
            @mobietec nop run it again and again another problem its somthing i have done im sure of it left n right z screw
            upon running code looking good untill it ajusts its self it ajusts left screw up and then the bed is out of wack grr not level
            • Mobietecundefined
              Mobietec @Mobietec
              @mobietec off to bed will try again tommrow thanks all if you post any help ill pick it up in morning
                This is a bit wrong. I define my Z motors in M584 first right, then left, and the M671 should be in the same order. You define yours left then right in M584, so you need to change the order of M671. Also it should be the position of the leadscrew, not the edge of the bed; my leadscrews are 90mm from the bed edge in X, so 165+90=255. Finally, you need to probe near the left leadscrew first, so swap the positions of the probe commands around, making sure the last command ends in S2.
                Alternatively you can swap the Z motor connections on the Duet!
                • Mobietecundefined
                  Mobietec
                  @droftarts thank you that part working now
                  But new problem my E0nnot extruding i plug in a seprat drive i can see its trying and feel it but no turning
                  • Mobietecundefined
                    Mobietec @Mobietec
                    @mobietec my current config e0 seems not to have enoth current flowing into it thats what it feels like
                    setup
                    drive 0 =X
                    Drive 1=y
                    drive 2=z1
                    drive 3=e0
                    drive 4=z2
                    drive 5= not conected yet
                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 09 2021 20:06:02 GMT+0100 (British Summer Time)
                    M550 P"Raptor CoreXY" ; set printer name
                    M669 K1 ; select CoreXY mode
                    M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M569 P0.1 S1 ; physical drive 0.1 goes forwards
                    M569 P0.2 S0 ; physical drive 0.2 goes forwards
                    M569 P0.3 S1 ; physical drive 0.3 goes forwards
                    M569 P0.4 S0 ; physical drive 0.4 goes forwards
                    M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
                    M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
                    M92 X80.00 Y80.00 Z400.00 E100.00:400.00 ; set steps per mm
                    M566 X900.00 Y900.00 Z60.00 E120.00:60.00
                    M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1 ; set maximum instantaneous speed changes (mm/min)
                    M203 X6000.00 Y6000.00 Z180.00 E1200.00:180.00 ; set maximum speeds (mm/min)
                    M201 X500.00 Y500.00 Z20.00 E250.00:20.00 ; set accelerations (mm/s^2)
                    M906 X850 Y850 Z850 E850:850 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    ; Dual Z Axis
                    M584 X0 Y1 Z2:4 E3; two Z motors connected to driver outputs Z and E1
                    M671 X-165:165 Y0:0 S2 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                    M208 X-165:170 Y-165:165 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                    M574 X1 S1 P"io3.in" ; configure active-low endstop for low end on X via pin !io1.in
                    M574 Y1 S1 P"io2.in" ; configure active-low endstop for low end on Y via pin !io2.in
                    M574 Z2 S2 ; configure active-low endstop for high end on Z via pin !io1.in
                    ;M574 X1 S3 ; configure sensorless endstop for low end on X
                    ;M574 Y1 S3 ; configure sensorless endstop for low end on Y
                    ;M574 Z2 S2 ; configure Z-probe endstop for high end on Z
                    M574 Z1 S2 ; set endstops controlled by probe
                    M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                    M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                    G31 P500 X-22.6 Y-3.0 Z2.5 ; set Z probe trigger value, offset and trigger height
                    M557 X-145:140 Y-150:150 P5 ; define mesh grid
                    M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
                    M307 H0 R0.612 C635.3 D7.63 S1.00 V24.4 ; disable bang-bang mode for the bed heater and set PWM limit
                    M308 S1 P"temp1" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin temp1
                    M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                    M307 H1 R3.322 C149.5 D6.72 S1.00 V24.3 ; disable bang-bang mode for heater and set PWM limit
                    M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
                    M106 P0 S0 H T45 ; set fan 0 value. Thermostatic control is turned on
                    M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
                    M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
                    M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
                    M950 F3 C"out7" Q500 ; create fan 3 on pin out7 and set its frequency
                    M106 P3 S1 H1 T45 ; set fan 3 value. Thermostatic control is turned on
                    M950 F4 C"out8" Q500 ; create fan 4 on pin out8 and set its frequency
                    M106 P4 S1 H1 T45 ; set fan 4 value. Thermostatic control is turned on
                    M950 F5 C"out9" Q500 ; create fan 5 on pin out9 and set its frequency
                    M106 P5 S1 H1 T45 ; set fan 5 value. Thermostatic control is turned on
                    T0
                    T0
                    ;M501 ; load saved parameters from non-volatile memory
                      Phaedrux Moderator @Mobietec
                      ; Dual Z Axis
                      You've got M584 listed 3 times in there. It needs to be early in the config right after the M569 commands is fine. Delete the others. And make sure the one you leave is accurately mapping your drivers.
                      • Mobietecundefined
                        Mobietec @Phaedrux
                        @phaedrux maks no diffreance
                        ;M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
                        ;M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
                        ;M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1 ; set maximum instantaneous speed changes
                        (mm/min)
                        ; Dual Z Axis
                        di o have a dud board i can feel the E0 trying to turn i have yested with known working motor and lead etc
                        have to pop out now will try again later thank you
                          (mm/min)
                          Now remove the second E value in those commands since you only have a single extruder.
                          Ensure the stepper motor phases are paired correctly and the wires and crimps are good.
                          https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                          If it's still having troubles, switch the wiring to E1 driver and change the M584 command to bind E to that driver and see if it's still a problem.
                          Also ensure that you have the steps per mm for E close to correct.
                          • Mobietecundefined
                            Mobietec @Phaedrux
                            @phaedrux ty its sort of turning now thats it for tonight ill have anther play tomroe many thanks if need more help will ask (most likley will lol )
                            • Mobietecundefined
                              Mobietec @Mobietec
                              @mobietec thank you all i did my first test print today only a cube it not looking too bad need to sort out ressur or liner advance nexr but getting their
