    Firmware 1.19+1 bug fix
    Firmware installation
    2.2k
      I have put pre-release 1.19 bugfix firmware versions for Duet WiFi, Duet Ethernet and Duet 06/085 at https://www.dropbox.com/sh/wq0u70kpapqc3is/AAC6I8TS5Lbwuziq_r3M15Qea?dl=0. The fixes to 1.19 are:
      • M669 should report current kinematics, but doesn't for delta (also check Cartesian and CoreXY etc.)
      • SCARA kinematics doesn't apply Z limits or limits to U, V etc. Delta kinematics doesn't apply limits to U, V etc.
      • SCARA forward kinematics are wrong
      • SCARA minimum radius limit is wrong
      • SCARA: allow S and T parameters to be changed on the fly i.e. don't require re-homing when they are changed
      • M140 S0 and M104 S0 at the end of a print file don't turn off the heaters if used at the end of a gcode file with >8 following M300 commands
      • Bed adjusting wizard: leave one of the screws alone when suggesting corrections
      • This problem: https://www.duet3d.com/forum/thread.php?pid=22326
      • When a heater was named in a M305 command, the memory allocated was overflowed by 1 byte
      If you are affected by any of these issues or you are declaring named heaters in M305 commands, please try this version.
      • lolorcundefined
        lolorc
        I've just upgraded from 1.18 to the whole 1.19 package + this bug fix.
        I can't find a way to delete/rename/etc files from the web gui (macros, sys, …) There's a check box in front of the files, but there're no associated action.
        (I've observed this with firefox & chromium)
        • Dougal1957undefined
          Dougal1957
          @lolorc:
          Right click the file name and a drop down appears
          • lolorcundefined
            lolorc
            Thanks
            • frafaundefined
              frafa
              Hi
              Scara begins to really work well!
              a big thank-you 🙂
              Scara with DuetWifi => Scarlette3D
              https://youtu.be/mBF5cO8vGhI
                Thanks for the feedback, and for choosing the Duet despite the initial incomplete SCARA support.
                • Jareryundefined
                  Jarery
                  Applied the patch.
                  Still have difficult time connecting via wifi. Router is reset to channel 6, no joy.
                  I have a dedicated laptop parked 3 ft away, Whats recommended method to have a wired connection., USB cable ?
                    @jarery, is it not connected ting at all, or connecting but timing out, or something else?
                    • ESTIMULOundefined
                      ESTIMULO
                      same problem, it get connected but in a few seconds connection timeout, connection reset, etc. if i do ping continually some are lost. That not happend on 1.18. Something with wifi is not as good as previous version.
                      • Jareryundefined
                        Jarery
                        It does connect, but times out a lot.
                        I created a macro that turns the wifi module off/on just to help in reconnecting.
                        Once connected it stays connected for the most part, until I begin a print. Then it usually times out after a 10-20 min into a print.
                        Getting it to reconnect after the print is just a hit/miss process of restarting the wifi, hitting connect repeatedly, rebooting, etc. I log into my routers page and see the IP assigned, it just has a hard time opening in a web page (safari).
                        I have a main router in the room behind, about 10' away, and a second router as an access point half a house away. Both use same name/ssid and pass.
                          When it is connected, if you run M122 what RSSI does it report?
                          • Jareryundefined
                            Jarery
                            Heres the network section
                            Network state is running
                            WiFi firmware version 1.19
                            WiFi MAC address 5c:cf:7f:a4:a1:64
                            WiFi Vcc 3.12, reset reason Turned on by main processor
                            WiFi flash size 4194304, free heap 39168
                            WiFi IP address 192.168.2.53
                            WiFi signal strength -35dBm
                            HTTP sessions: 2 of 8
                            Socket states: 2 0 0 0 0 0 0 0
                            Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                              You have a very strong signal! I don't think I have seen a RSSI as high as -35 before.
                              You appear to have 2 active http sessions, which I think means you have connected from 2 different IP addresses. Is that correct?
                              • Jareryundefined
                                Jarery
                                at times I've connected from a second laptop yes. But that is not always the case.
                                Much of the time I am only connected via the one laptop.
