    Bed Mesh Skipping grid
    484
    • ap742undefined
      ap742
      guys old dumb dumb over here needs help again.
      can't wrap my head around this .
      I know I need to offset
      trying to make mesh bit smaller and keep getting skipping grid on x
      5/7/2021, 12:33:26 PM Warning: Skipping grid point (300.0, 310.0) because Z probe cannot reach it
      5/7/2021, 12:32:26 PM Warning: Skipping grid point (300.0, 260.0) because Z probe cannot reach it
      Warning: Skipping grid point (300.0, 285.0) because Z probe cannot reach it
      5/7/2021, 12:31:30 PM Warning: Skipping grid point (300.0, 210.0) because Z probe cannot reach it
      Warning: Skipping grid point (300.0, 235.0) because Z probe cannot reach it
      5/7/2021, 12:30:33 PM Warning: Skipping grid point (300.0, 160.0) because Z probe cannot reach it
      Warning: Skipping grid point (300.0, 185.0) because Z probe cannot reach it
      5/7/2021, 12:29:37 PM Warning: Skipping grid point (300.0, 110.0) because Z probe cannot reach it
      Warning: Skipping grid point (300.0, 135.0) because Z probe cannot reach it
      5/7/2021, 12:28:41 PM Warning: Skipping grid point (300.0, 60.0) because Z probe cannot reach it
      Warning: Skipping grid point (300.0, 85.0) because Z probe cannot reach it
      5/7/2021, 12:27:45 PM Warning: Skipping grid point (300.0, 10.0) because Z probe cannot reach it
      Warning: Skipping grid point (300.0, 35.0) because Z probe cannot reach it
      first my printer is bit backwords maybe?
      so probe on the left of the of the hotend 42.4 defined x-42.4 ( limit switch on the right side)
      M208 X320 Y350 Z400 S0 ; set axis maxima X used to be set to 350 had to limit it because probe would go off bed
      M574 Z0 ; configure Z-probe endstop on Z
      M591 P1 C"e0stop" S1 D0
      M558 P9 C"^zprobe.in" H2.5 F180 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-42.4 Y0 Z2.883 ; set Z probe trigger value, offset and trigger height
      M557 X-25:320 Y10:320 S25 ;M557 X0:305 Y0:315 S25 ; this is what I play with if limit of bed increased it'll go off bed
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
        Can you post your full config.g and your homeall?
        0,0 should be the front left corner of the bed
        -X moves left, +X moves right
        -Y move to the front, +Y moves to the rear
        based on your config the endstops are at the low end, so the left side for x and the front for y. Is that correct?
        When the x and y endstops are triggered the nozzle should be at 0,0 just at the corner of the bed based on your config. Is that correct?
        ap742undefined 3 Replies Last reply Reply Quote 0
        • ap742undefined
          ap742 @Phaedrux
          @phaedrux
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Apr 16 2021 19:18:05 GMT-0400 (Eastern Daylight Time)
          M550 P"Ender" ; set printer name
          ;MCU temp
          M912 P0 S21 - 26
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P3 S0 ; physical drive 3 goes backwards
          M92 X80.00 Y80.00 Z800.00 E391.455 ; set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E500.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E1000 I30 ;Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X320 Y350 Z400 S0 ; set axis maxima x350
          M557 X-25:320 Y10:320 S50 ;M557 X0:305 Y0:315 S25 ; define mesh grid
          ;M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
          ;M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0
          ;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
          ;M140 H0 ; map heated bed to heater 0
          ;M143 H0 S120 ; set temperature limit for heater 0 to 120C
          ;M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
          ;M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
          ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          ;M143 H1 S280 ; set temperature limit for heater 1 to 280C
          ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
          M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4725 C7.06e-8 ;M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
          M143 H1 S300 ; set temperature limit for heater 1 to 300C
          M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
          ; Custom settings
          ;591 D0 P2 C3 S1 ; Filament Run out sensor
          • ap742undefined
            ap742 @Phaedrux
            @phaedrux and homeall
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Apr 16 2021 19:18:06 GMT-0400 (Eastern Daylight Time)
            G91 ; relative positioning
            G1 H2 Z2.5 F6000 ; lift Z relative to current position
            G1 H1 X-360.5 Y-355 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-360.5 Y-355 F360 ; move slowly to X and Y axis endstops once more (second pass)
            ;G1 H1 Z-405 F360 ; move Z down stopping at the endstop
            ;G90 ; absolute positioning
            ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
            ;G1 X220 Y175 F4000 ; Move probe to middle of bed
            G1 X140 Y160 F6000 ; go to first probe point
            G30
            • ap742undefined
              ap742 @Phaedrux
              @phaedrux said in Bed Mesh Skipping grid:
              when end stops triggered the hotend up right corner
              • Stephen6309undefined
                Stephen6309 @ap742
                @ap742 The hotend would have to go outside the bed to allow the Z probe to reach X300. If you have room on the X axis, make the bed bigger in X, and the mesh bed size bigger. Test to make sure you didn't go to big.
                ap742undefined 2 Replies Last reply Reply Quote 0
                • ap742undefined
                  ap742 @Stephen6309
                  @stephen6309 had to make smaller . else it'll probe outside bed
                  • ap742undefined
                    ap742 @Stephen6309
                    @stephen6309 M557 X-25:320 Y10:320 S50 this works
                    I figured i'll do smaller squares or more probes
                      So it sounds like your coordinates are rotated 180 degrees with 0,0 in the back right corner and X and Y directions both flipped from "normal" orientation. That's fine, but you also need to take that account when measuring your probe XY offset and the M577 grid size.
