    Use Out 0 for Hot End instead of Bed Heater
    out 0 hot end bed heater
    • guitartoys
      guitartoys last edited by
      Since I am going to use a solid state relay for my bed heater, could I use Out 1 for the extruder Hot End and then use Out 0 for for my Extruder Hot end?
      I'm currently getting set up for a regular Hemera hot end, but will soon move to a Super Volcano. And rather than have to use the separate MOSFET Board for the super volcano, I was figuring that Out 0 can handle the higher current.
      And as I'm using a solid state relay for the bed heater, that Out 1 would be sufficient.
      Would this be OK?
      Thanks.
      Michael
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @guitartoys last edited by
        @guitartoys yep, thats fine. RRF3 is very flexible
          Just choose the pins you want to use in the config tool.
          https://configtool.reprapfirmware.org/Start
          • guitartoys
            Awesome, thanks. I just didn't want to have to install that separate MOSFET board if I didn't need to.
            Thanks for pointing out the config wizard. I hadn't quite gotten far enough to look into that.
            Thanks.
            M
