    Duet2 or Duet3 for new Jubilee build
    407
    • jens55
      jens55 last edited by
      I thought I had made up my mind to use a Duet3 with tool boards to simplify my wiring but thought I would throw this out here and see if there is any consensus about which system to use.
      So, If you were building a new printer with tool changing capability, what would you use for the controller Duet2 with Duex5 or Duet3 with tool boards?
      A secondary reason for me asking this is that we seem to have a lot of finicky issues going on lately (based on the forum) with the Duet3 eco system.
      Share your thoughts!
      DIY-O-Sphere dc42 2 Replies Last reply Reply Quote 0
      • DIY-O-Sphere
        DIY-O-Sphere @jens55 last edited by
        @jens55
        Two Mini5+ connected +2 tool boards?
        This is the solution i want to implement one day....
        (UTC+1)
        jens55 1 Reply Last reply Reply Quote 0
        • jens55
          jens55 @DIY-O-Sphere last edited by
          @diy-o-sphere, that's an odd combination. How would you connect two mini5's to run one printer ????
          DIY-O-Sphere 1 Reply Last reply Reply Quote 0
          • DIY-O-Sphere
            @jens55
            It is supported by the firmware.
            https://forum.duet3d.com/topic/20587/duet-3-mini-5-future-expansion-options/8
            (UTC+1)
            • jens55
              @diy-o-sphere, cool ... but why would you go that route? What extra features does it get you ?
              • DIY-O-Sphere
                DIY-O-Sphere @jens55 last edited by DIY-O-Sphere
                @jens55
                That' s cheaper than the 6HC with expansion and i will need 11 drivers.
                And with the new 1LC tool board input shaper will be supported soon.
                Also the can bus makes wiring much easier.
                For me, a Duet2 is no longer an option.
                (UTC+1)
                • jens55
                  @diy-o-sphere, got it. Agreed on the CANbus. I think that simplifies things a lot and makes the wiring more reliable. I was just a bit concerned with all the issues that were reported. Most of that is expected with the fast development pace but I don't need CAN that badly if I end up with other issues.
                  There have been comments about people having issues with attached SBC's and actually reverting back. Well, the Duet3 6HC doesn't have wifi on the board so if I want to run wifi, I need the SBC.
                  • DIY-O-Sphere
                    @jens55
                    I partially agree with you. Fortunately, I rarely need a SBC.
                    You always have to gain experience with a new technology.
                    I hope that the problems can be solved quickly.
                    (UTC+1)
                    • deckingman
                      deckingman last edited by
                      In theory, Canbus and tool boards would be the way to go. However I'd hold fire for now (which is what I'm doing) because gen 3 firmware still isn't reliable enough (IMO) even after nearly 2 years. I'm running a version of the latest beta but still have unresolved issues. I reported the latest problem via a different medium to these forums on 26th April and have been away for a week. Bit disappointed to find that nothing has happened in the intervening period. Maybe in another year or so.....
                      • jens55
                        jens55 @deckingman last edited by
                        @deckingman are we talking esoteric stuff that the average human likely wouldn't see or are we talking stuff that is used everyday by an average person spending way too much money to just print little toy boats all day every day?
                          dc42 administrators @jens55 last edited by
                          @jens55 are the TMC2209 drivers on the Duet 3 Mini sufficient to drive the Jubilee motors? If so then I suggest you start from that. You can expand it via CAN bus, and you can also add two mode drivers on a daughter board.
                          • jens55
                            jens55 @dc42 last edited by
                            @dc42, yes it's just a standard Jubilee I am building so the drivers should be fine. The reason I was thinking 6HC board is because it is only $100 USD more and I won't be kicking myself at a later point for saving a few dollars. I am a bit concerned about there possibly being a hardware upgrade in the works though.
                            Dougal1957 1 Reply Last reply Reply Quote 0
                            • deckingman
                              deckingman @jens55 last edited by
                              @jens55 said in Duet2 or Duet3 for new Jubilee build:
                              Dunno - what is an average user? Given that you (and I) want to build a tool changer, then that likely means using expansion boards of one sort or another. Most of the problems I have encountered (and still encounter) are related to the use of expansion boards. Whether that is related to CanBus or some other aspect of expansion boards, I'm not qualified to say.
                              The latest 3.3. beta3 broke my printer yet again. I use M116 in a macro to wait for temperatures to stabilise. When this was executed, the board reset and this lost all it's homing status. Apparently this was due to something called a stack overflow.
                              I'm currently running another binary which has fixed that issue but this gives other error messages such as "Warning: Discarded msg src=3 typ=4510 RID=80 exp 81". That's what I reported on 26th April but I'm still waiting for a fix.
                              • Dougal1957
                                Dougal1957 @jens55 last edited by
                                If you are using the Recommended LDO Motors for x/y then IIRC the recommended drive current for them is around 2.4 amps don't think the 2209's can supply that but I could be wrong on both counts my Jubilee is at about the 80-90% complete at the moment. but I have a 6HC plus a 3HC on mine it will have 3 tools plus an ASMBL Tool so 9 drivers is sufficient
                                @DIY-O-Sphere would be interested to know how you came up with the figure of 11?
                                hth
                                Doug
                                DIY-O-Sphere jens55 2 Replies Last reply Reply Quote 0
                                  dc42 administrators @deckingman last edited by
                                  @deckingman, the stack overflow is fixed in firmware 3.3RC1+1 and we are about to release 3.3RC2. Unfortunately when using RTOS, there are as yet no good tools for establishing how large the size of each task stack needs to be. If we make them too large than that wastes RAM, which we can't afford to do on the Duet 2 builds. So we set them to a high value initially, then after doing things that we think use maximum stack, use M122 to see how much spare is left. The we remove some (not all) of that spare. However, it sometimes happens that certain configurations that we haven't tested with use a lot more stack than normal, which is why in beta releases a few users sometimes report stack overflows.
                                  The warning messages are nothing to worry about because we established that they are duplicate "success" messages; but on my list to investigate further and fix.
                                  • DIY-O-Sphere
                                    DIY-O-Sphere @Dougal1957 last edited by
                                    @dougal1957
                                    (UTC+1)
                                    jens55 Dougal1957 2 Replies Last reply Reply Quote 0
                                    • jens55
                                      jens55 @Dougal1957 last edited by
                                      @dougal1957 said in Duet2 or Duet3 for new Jubilee build:
                                      Just looked it up the x/y motors are 2 amp motors and you wouldn't run them at 100% power but it is getting close to the driver limit so a good point.
                                      • jens55
                                        @diy-o-sphere said in Duet2 or Duet3 for new Jubilee build:
                                        @dougal1957
                                        What is 'tool parking' ?
                                        • Dougal1957
                                          yes they are 2amps RMS so you would run close to that in fact I do know that the devs use around 2.4 amps to them to get the additional speed out of them (They are high Temp motors as well)
                                          • Dougal1957
                                            Dougal1957 @DIY-O-Sphere last edited by
                                            @dougal1957
                                            AS jens has asked what are the tool parking motors and wouldn't you need 3 if you have 3 tools?
                                            • jens55
                                              @dougal1957, thanks .... that pretty much only leaves the 6HC board as a viable contender.
                                              • Dougal1957
                                                Dougal1957 @jens55 last edited by Dougal1957
                                                not really as you could use a 3hc as a slave to a duet3mini but you don't have to run the XY motors flat out if you don't want to but I wouldn't go below 1.6A
                                                • jens55
                                                  @dougal1957, grrrr, just as I made the decision ..... this is hard 😞
                                                  • DIY-O-Sphere
                                                    @dougal1957 @jens55
                                                    I knew the question would come up.
                                                    This is something that has been on my mind for a long time.
                                                    I want to park my tools in the front, but here they are in the way for maintenance work. So I was thinking about moving a tool platform in Z.
                                                    But this should only happen when needed, not for a tool change.
                                                    For example, at the end of a print to get more space to reach in.
                                                    I already have a concept and first CAD drafts for this.
                                                    (UTC+1)
                                                    • Dougal1957
                                                      @diy-o-sphere ah ok makes some sense i guess but that could be done with low current motors I guess you would have to ensure that they always come bake to the normal position quite accurately tho.
