    How to set WiFi permanent?
    Using Duet Controllers
    501
    • tecnoundefined
      tecno
      This way I do this
      Stop M552 S-1
      Idle M552 S0
      Set SSID M587 ......
      M552 S1
      Power off and my SSID is no more.
      What am I doing wrong?
        dc42 administrators @tecno
        @tecno after you have set is using M587 with SSID and password parameters, if you then send M587 it should list the networks it knows about. If you power off and on again and then send M552 S0, then M587 should list the same SSID(s) as before. Is that working?
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @dc42
          @dc42 said in How to set WiFi permanent?:
          If I power off > on then I have to do it allover again. = Board is not saving SSID etc.
            @tecno have you tried doing exactly what I said? What does M587 report after you power off and on again?
            • tecnoundefined
              tecno @dc42
              Failed to retrieve etc.....
                jay_s_uk @tecno
                @tecno try reflashing the firmware using M997 S1
                • tecnoundefined
                  tecno @jay_s_uk
                  @jay_s_uk
                  Still the same issue
                    @tecno did re-flashing the WiFi firmware succeed? What WiFi firmware version does M122 report?
                    It could be that the wifi module has developed a fault.
                    • tecnoundefined
                      tecno
                      Well now I can get nowhere.
                      I got it sort of working, did run some G28 and got all sorted out.
                      Suddenly I can not use my browsers to open Duet Web Control.
                      Same now with Yat and Pronterface!
                      WinSCP is OK so with FTP I can see folders, open folders to see files but then I can not go back to root.
                      So what is going on here here???
                      ps. I have never heard so quiet printer before, this board is doing it well.
                      • tecnoundefined
                        tecno
                        I can login with Telnet and run G28
                        M122
                        RepRapFirmware for Duet 3 Mini 5+ version 3.2-beta3.2+1 running on Duet 3 Mini5p lus WiFi (standalone mode)
                        Board ID: 4MUA7-X196U-D65J0-40KM8-4N03Z-HJR3D
                        Used output buffers: 1 of 40 (1 max)
                        Static ram: 97472
                        Dynamic ram: 133200 of which 664 recycled
                        Never used RAM 29784, free system stack 122 words
                        Tasks: NETWORK(ready,414) HEAT(blocked,222) CanReceiv(blocked,967) CanSender(blo cked,357) CanClock(blocked,363) TMC(blocked,65) MAIN(running,448) IDLE(ready,20) AIN(blocked,264)
                        Owned mutexes:
                        Last reset 00:05:48 ago, cause: power up
                        Last software reset at 2021-05-10 17:38, reason: User, GCodes spinning, availabl e RAM 29784, slot 0
                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00430000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                        Error status: 0x00
                        Supply voltage: min 0.0, current 24.4, max 24.5, under voltage events: 0, over v oltage events: 0, power good: yes
                        Driver 0: position 16000, standstill, SG min/max 0/0, read errors 0, write error s 0, ifcnt 9, reads 49635, writes 9, timeouts 0, DMA errors 0
                        Driver 1: position 16000, standstill, SG min/max 0/36, read errors 0, write erro rs 0, ifcnt 12, reads 49632, writes 12, timeouts 0, DMA errors 0
                        Driver 2: position 0, standstill, SG min/max 0/8, read errors 0, write errors 0, ifcnt 12, reads 49587, writes 12, timeouts 44, DMA errors 0, failedOp 0x6f
                        Driver 3: position 0, standstill, SG min/max 0/14, read errors 0, write errors 0 , ifcnt 12, reads 49494, writes 12, timeouts 137, DMA errors 0, failedOp 0x06
                        Driver 4: position 0, standstill, SG min/max 0/14, read errors 0, write errors 0 , ifcnt 12, reads 49632, writes 12, timeouts 0, DMA errors 0
                        Driver 5: position 0, assumed not present
                        Driver 6: position 0, assumed not present
                        Slowest loop: 4.85ms; fastest: 0.12ms
                        === Storage ===
                        Free file entries: 10
                        SD card longest read time 3.3ms, write time 0.0ms, max retries 0
                        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 196250ms
                        === MainDDARing ===
                        Scheduled moves 6, completed moves 6, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                        === AuxDDARing ===
                        Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                        Bed heaters = 0 -1, chamberHeaters = -1 -1
                        Segments left: 0
                        Movement lock held by null
                        HTTP is idle in state(s) 0
                        Telnet is idle in state(s) 0
                        File is idle in state(s) 0
                        USB is idle in state(s) 0
                        Aux is idle in state(s) 0
                        Trigger is idle in state(s) 0
                        Queue is idle in state(s) 0
                        LCD is idle in state(s) 0
                        SBC is idle in state(s) 0
                        Daemon is idle in state(s) 0
                        Aux2 is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 45.05ms; fastest: 0.00ms
                        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(2), 1 sessions
                        HTTP sessions: 0 of 8
                        • WiFi -
                          Network state is active
                          WiFi firmware version 1.25beta0
                          WiFi MAC address f4:cf:a2:6f:bd:d8
                          WiFi Vcc 3.37, reset reason Power up
                          WiFi flash size 2097152, free heap 20976
                          WiFi IP address 192.168.1.88
                          WiFi signal strength -43dBm, mode 802.11n, reconnections 0, sleep mode modem
                          Clock register 00002002
                          Socket states: 2 0 0 0 0 0 0 0
                          === CAN ===
                          Messages sent 0, send timeouts 0, longest wait 0ms for type 0, free CAN buffers 15
                        Hope this helps to get a fix to my new problem.
                        Cheers
                        Bengt
                          @tecno, what happens when you try to load Duet Web Control, by entering the Duet's IP address in your web browser?
                            Phaedrux Moderator @tecno
                            @tecno said in How to set WiFi permanent?:
                            Please update your firmware using these steps:
                            https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_Ethernet
                            Using this file: https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet3Firmware_Mini5plus.uf2
                            Then on your SD card in your PC, replace the contents of the /www/ folder with the contents of this zip file:
                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/DuetWebControl-SD.zip
                            Then place this bin file in the /sys/ folder on the SD card.
                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWiFiServer.bin
                            Then reconnect via usb or telnet terminal and send M997 S1 to reflash the wifi server.
                            Next time you run M122 you should see the firmware listed as 3.2.2 and the wifi server listed as 1.25. The DWC should also be at 3.2.2 if you check the version in the web browser.
                            Future firmware updates will be much more straightforward by simply uploading the full firmware zip file to the system tab in DWC.
                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                            tecnoundefined 2 Replies Last reply Reply Quote 0
                            • tecnoundefined
                              tecno @dc42
                              @dc42 Good morning, nothing just a blank page . Not safe
                              • tecnoundefined
                                tecno @Phaedrux
                                @phaedrux Good morning, will do as listed by you, Thank you.
                                • tecnoundefined
                                  tecno @Phaedrux
                                  @phaedrux
                                  Back on-line with DWC. Thank you !
                                  Now step by step check that heaters, fans are working.
                                  Cheers from Sweden
                                  Bengt
                                    @phaedrux
                                    Cheers from Sweden
                                    Bengt
                                    Does it remember the WiFi access point details through a power cycle now?
                                    • tecnoundefined
                                      tecno @dc42
                                      @dc42 Yes it does.
                                      Have some issues with fans and heaters, where do I start a thread?
                                        @tecno you can start a new thread in this category. I will mark this as solved.
