    24 Volts Bed Heater Problem
    528
    • drmaestro
      drmaestro last edited by
      I was upgrading my configuration from 12 volts to 24 volts. I used a 24 Volts 500 Watts silicone heater for the bed. It is directly connected to the Duet. Whenever I try to increase the bed temperature Duet resets immediately. Is it because 500 watts is too much? Also, none of my fans (PWM and thermostatic) work anymore (the continous fan works). Did I burn something or blow a fuse? I am on Duet Wifi 1.04.
      Thanks...
      jens55 Phaedrux 2 Replies Last reply Reply Quote 0
      • jens55
        jens55 @drmaestro last edited by
        @drmaestro, how big is your 24V power supply?
        Chances are you are drawing too much power for this configuration.
        • Joel
          Joel last edited by Joel
          I think the heater outputs are good for 18A. Your 24 Volt 500 Watt heater would draw about 21A which is a little over but....
          What are you using for a power supply?
          drmaestro 1 Reply Last reply Reply Quote 0
          • drmaestro
            drmaestro @Joel last edited by
            @joel I have a Mean Well: LRS-350-24, 24VDC 14.6A 350W SMPS
            Joel 1 Reply Last reply Reply Quote 0
              Phaedrux Moderator @drmaestro last edited by
              @drmaestro said in 24 Volts Bed Heater Problem:
              Did you also change your hotend heater and fans to 24v?
              • Joel
                Joel @drmaestro last edited by
                You power supply is too small. you are trying to heat up a 500W pad with a 350W power supply. It is likely shutting down.
                • jens55
                  jens55 last edited by
                  Can't draw 600W from a 350W power supply ....
                  ... and Phaedrux, good call on the fans and hotend heater(s)
                  • drmaestro
                    drmaestro @Phaedrux last edited by
                    @phaedrux Partially. I've changed the hotend fan to 24 volts. It is thermostatically controlled, however it isn't working when I increase the temperature. I also have 2 cooling fans however 1 of them is 12 volts, so I am using a voltage regulator for this one.
                    jens55 1 Reply Last reply Reply Quote 0
                    • jens55
                      jens55 @drmaestro last edited by jens55
                      It is highly likely that the 12V fan is not set up correctly.
                      The question of the hot end heater is still open.
                      • drmaestro
                        drmaestro @jens55 last edited by
                        @jens55 Is there a possibility that I might have blown a fuse while trying to use the bed?
                        jens55 Joel dc42 3 Replies Last reply Reply Quote 0
                        • Joel
                          Joel @Joel last edited by
                          @joel said in 24 Volts Bed Heater Problem:
                          Another point, your heating pad is also too big for the duet. Your best bet it to drive a relay with the duet and have the relay provide power to the heater pad.
                          You could get a second 24V supply just for the bed heater ( would recommend something a bit bigger than the 500 Watts you heater needs ) and then use the existing supply ( if not damaged ) for the duet, fans, and nozzle heater.
                          • jens55
                            @drmaestro, there are so many red flags in this 'upgrade' that it is hard to say what all you did to the board. Yes, fuses are a possibility. So is mosfets ....
                            • Joel
                              I think there is a fuse inside the Mean well power supply, you will have to open it up to check. I have a couple of Mean wells and they are soldered in.
                              • drmaestro
                                @joel I may have to change the heating pad instead, as I don't have enough free space for an additional power supply. What is the highest wattage that Duet can directly operate?
                                • drmaestro
                                  @joel The Meanwell is working. I can power-up the printer, move the motors and use the hotend heater, so I think Mean Well is ok.
                                  • jens55
                                    You lucked out ....
                                    I believe there is a separate fuse for the bed heater which is likely blown.
                                    • drmaestro
                                      @jens55 Interestingly it isn't. If I try to increase the neated bed temperature it starts to rise 1-2 degrees but then resets. So I think it isn't blown (I am not doing it anymore of course).
                                      • Joel
                                        Joel @drmaestro last edited by Joel
                                        The switch the duet uses says 18A, you probably want to be something less than that to have some margin. If you say 15A, that would be a 360 Watt heater.
                                        Keep in mind you power supply has to do the bed heater, the nozzle heater, the fans, and the board. The fans and the board are small compared to the nozzle and bed heaters.
                                        Add the bed wattage, the nozzle heater wattage, add 50 watts for the duet and fans, multiply that answer by 1.2 and that's the size power supply you want.
                                        Opps - forgot the steppers, need to add those in too. You want to assume everything is running at the same time
                                        • drmaestro
                                          @joel I should probably have gone with this https://www.aliexpress.com/item/32327554677.html?spm=2114.12010612.8148356.10.3dd87d80abwHH4 insteatd of this https://www.aliexpress.com/item/2050749273.html?spm=2114.12010612.8148356.12.3dd87d80abwHH4
                                          jens55 Joel 2 Replies Last reply Reply Quote 0
                                          • jens55
                                            @drmaestro, most switching power supply are good at sensing output power and shut down so in your case you doubly got lucky (go out and buy a lotto ticket)
                                            What I would do is to disconnect the heat pad and the 12V fan and see what works and doesn't work.
                                            24V is good but you'd need a larger supply and run the heat pad via a relay as the Duet is not capable of powering it directly.
                                            • Joel
                                              Joel @jens55 last edited by
                                              Actually a 24V supply is better for trying to use a higher wattage heater, less current required for the same power.
                                              • jens55
                                                @drmaestro, 500 watts for a 200x200 mm is pretty high. Is the bed only 200x200 or are you improvising with a smaller pad?
                                                • Joel
                                                  yes, 200W is more appropriate for that bed size anyway.
                                                  • jens55
                                                    I would say that 200W is good if your build plate is 200x200. If your build plate is 300x300, I would stick with the 500W heat pad and increase the size of the power supply and run the heater via a relay. (switch to bang/bang operation for a relay)
                                                    • Joel
                                                      What size ( wattage ) nozzle heater are you using?
                                                      Joel drmaestro 2 Replies Last reply Reply Quote 0
