    Extruder slows to a crawl
    238
    • HtRabbit
      HtRabbit last edited by
      this is a cory XY with a Kracken head, 4 nozzles 4 extruders
      All x/y/z/ movements are fine and at normal speed, but fore some reason the extruder will slow down to barely visible movement. stepper and wiring have been verified and known good.
      a power cycle fixes the issue for a bit and then at random it slows down.
      Config.g
      M575 P1 S1 B57600									;connect a PanelDue to this port as of RRF 3.1.1
      M550 P"TronXY"                                     ; set printer name
      M667 S1                                            ; select CoreXY mode
      ;M551 P"xxxx"                                       ; set password
      M586 P2 S1                                         ; enable Telnet
      ;       Drives
      ;Extruders
      M569 P3 S0                                         ; physical drive 1 goes backwards
      M569 P4 S0                                         ; physical drive 2 goes backwards
      M569 P6 S1                                         ; physical drive 3 goes fowards
      M569 P7 S1                                         ; physical drive 4 goes fowards
      ;X axis
      M569 P0 S1                                         ; physical drive 0 goes forwards
      ;Y axis
      M569 P1 S1                                         ; physical drive 1 goes forwards
      ;Z axis
      M569 P2 S0                                         ; physical drive 2 goes backwards
      M569 P5 S0                                         ; physical drive 5 goes backwards
      ;      End Drives
      M584 X0 Y1 Z2:5 E3:4:6:7                           ; set drive mapping
      M671 X410:-85 Y165:165 S10 			               ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
      M208 X0:330 Y-5:340 				               ; X carriage moves from 0 to 330, Y bed goes from -5 to 330
      M350 X16 Y16 Z16 E16:16:16:16 I1                         ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E142:142:142:142             ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00           ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z180.00 E1200.00:1200.00:1200.00:1200.00  ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E2500.00:2500.00:2500.00:2500.00    ; set accelerations (mm/s^2)
      M906 X950 Y950 Z1200 E950:950:950:950 I30                          ; set motor currents (mA) and motor idle factor in per cent
      M84 S600                                                           ; Set idle timeout
      M208 X330 Y320 Z400 S0                             ; set axis maxima
      M574 X1 S1 P"xstop"                                ; configure active-low May need ! before pin name to invert signal, S0 Retired
      M574 Y1 S1 P"ystop"                                ; configure active-low May need ! before pin name to invert signal, S0 Retired
      M574 Z1 S2 P"zstop+e2stop" 			               ; configure active-high endstops for low end on Z via pins zstop and e2stop
      ;Filament Sensors
      M591 D0 P2 C"!e0_stop" S1   			           ;Extruder 1(0)
      M591 D1 P2 C"!e1_stop" S1   			           ;Extruder 2(1)
      M591 D2 P2 C"!duex.e3stop" S1   			       ;Extruder 3(2).....!e3_stop
      M591 D3 P2 C"!duex.e4stop" S1   			       ;Extruder 4(3)..,...!e4_stop
      ;M581 P"e0stop" T1 C0                              ;Any trigger number # greater than 1 causes the macro file sys/trigger#.g to be executed.
      M950 S0 C"duex.e6heat"                             ; create servo pin 0 for BLTouch
      M558 P9 C"zprobe.in+zprobe.mod" H5 F1500 T8000      ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-20 Y57.7 Z1.05           ; set Z probe trigger value, offset and trigger height org=Z1.47 (positive number moves bed closer to nozzle)      ***************************************
      M557 X0:330 Y0:330 S75                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      ; Heater Ex 1
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      ; Heater Ex 2
      M308 S2 P"e1temp" Y"thermistor" T100000 B4138      ; configure sensor 2 as thermistor on pin e0temp
      M950 H2 C"e1heat" T2                               ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H2 S280                                       ; set temperature limit for heater 1 to 280C
      M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      ; Heater Ex 3
      M308 S3 P"duex.e2temp" Y"thermistor" T100000 B4138      ; configure sensor 3 as thermistor on pin e0temp
      M950 H3 C"duex.e2heat" T3                               ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H3 S280                                       ; set temperature limit for heater 1 to 280C
      M307 H3 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      ; Heater Ex 4
      M308 S4 P"duex.e3temp" Y"thermistor" T100000 B4138      ; configure sensor 4 as thermistor on pin e0temp
      M950 H4 C"duex.e3heat" T4                               ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H4 S280                                       ; set temperature limit for heater 1 to 280C
      M307 H4 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      ; End Heaters
      M950 F0 C"fan0"                                    ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1 C"Right_Fan"                                  ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1"                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S0 H-1 C"Left_Fan"                              ; set fan 1 value. Thermostatic control is turned off
      M950 F7 C"duex.fan7"                               ; create fan 0 on pin fan0 and set its frequency
      M106 P7 S1 C"Rad_Fan" T45 H1:2:3:4                            ; set fan 7 value. Thermostatic control is turned on for heaters 1 Thru 4
      M950 F8 C"duex.fan8"                               ; create fan 0 on pin fan0 and set its frequency
      M106 P8 S1 C"Coolent_Pump" T45 H1:2:3:4                           ; set pump 8 value. Thermostatic control is turned on for heaters 1 Thru 4
      ;       Tools
      ; nozzle map
      ;    _______
      ;   | 3 | 1 |  Nozzles are 20mm on center
      ;   | 4 | 2 |
      ;     front
      ;Tool 1
      M563 P0 D0 H1 F0:1                                ; define tool 0
      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures [R] to 0C
      ;Tool 2
      M563 P1 D1 H2 F0:1                                 ; define tool 1
      G10 P1 X0.65 Y-19.8 Z0                                    ; set tool 1 axis offsets
      G10 P1 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      ;Tool 3
      M563 P2 D2 H3 F0:1                                 ; define tool 0
      G10 P2 X-19.75 Y0 Z0                                  ; set tool 0 axis offsets
      G10 P2 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      ;Tool 4
      M563 P3 D3 H4 F0:1                                 ; define tool 1
      G10 P3 X-19.6 Y-20.4 Z0                                    ; set tool 1 axis offsets
      G10 P3 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      ; End Tools
      M929 P"eventlog.txt" S1 ; start logging to file eventlog.txt
      M570 H1 P20 T20 S5
      M570 H2 P20 T20 S5
      M570 H3 P20 T20 S5
      M570 H4 P20 T20 S5
      M912 P0 S-4.1                                        ; At cold boot Temp of cold extruder - Temp of cold MCU...may be negative
      M501                                               ; load saved parameters from non-volatile memory
      ;T0                                                 ; select first tool
      M122 before power cycle
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DJM-9178L-L2MS8-6JTF4-3S86S-99GLP
      Used output buffers: 1 of 24 (16 max)
      Static ram: 27980
      Dynamic ram: 96616 of which 52 recycled
      Exception stack ram used: 664
      Never used ram: 5760
      Tasks: NETWORK(ready,268) HEAT(blocked,1168) DUEX(suspended,160) MAIN(running,1228) IDLE(ready,80)
      Owned mutexes:
      Last reset 01:20:32 ago, cause: power up
      Last software reset at 2021-05-08 21:46, reason: User, spinning module GCodes, available RAM 5872 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 24.6, current 32.4, max 33.5
      Supply voltage: min 12.3, current 12.5, max 12.8, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/1023
      Driver 1: standstill, SG min/max 0/1023
      Driver 5: standstill, SG min/max not available
      Driver 6: standstill, SG min/max not available
      Driver 7: standstill, SG min/max not available
      Driver 8: standstill, SG min/max not available
      Driver 9: standstill, SG min/max not available
      Date/time: 2021-05-10 18:57:54
      Slowest loop: 59.96ms; fastest: 0.15ms
      I2C nak errors 2, send timeouts 336010, receive timeouts 3, finishTimeouts 336010, resets 336015
      === Storage ===
      Free file entries: 9
      SD card longest read time 3.2ms, write time 34.6ms, max retries 0
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 119, MaxWait: 442195ms
      Bed compensation in use: mesh, comp offset -0.166
      === MainDDARing ===
      Scheduled moves: 28339, completed moves: 28339, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      Heater 0 is on, I-accum = 0.0
      Heater 4 is on, I-accum = 0.2
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is ready with "M408 S0 R41" in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 46.45ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.23
      WiFi MAC address cc:50:e3:e3:ac:2c
      WiFi Vcc 3.36, reset reason Unknown
      WiFi flash size 4194304, free heap 21912
      WiFi IP address 192.168.0.125
      WiFi signal strength -38dBm, reconnections 0, sleep mode modem
      === Filament sensors ===
      Extruder 0 sensor: ok
      Extruder 1 sensor: ok
      Extruder 2 sensor: no filament
      Extruder 3 sensor: no filament
      === DueX ===
      Read count 93, 1.15 reads/min
      5/10/2021, 6:48:35 PM	m92
      Steps/mm: X: 80.000, Y: 80.000, Z: 400.000, E: 142.000:142.000:142.000:142.000
      M122 after power cycle
      M122
      Used output buffers: 3 of 24 (16 max)
      Static ram: 27980
      Dynamic ram: 96416 of which 52 recycled
      Exception stack ram used: 552
      Never used ram: 6072
      Tasks: NETWORK(ready,348) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1816) IDLE(ready,80)
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:01:20 ago, cause: power up
      Error status: 0
      MCU temperature: min 30.8, current 32.5, max 32.8
      Supply voltage: min 12.3, current 12.5, max 12.7, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, SG min/max 0/204
      Driver 1: standstill, SG min/max 0/0
      Date/time: 2021-05-10 19:04:40
      Cache data hit count 132628069
      Slowest loop: 9.84ms; fastest: 0.15ms
      === Storage ===
      SD card longest read time 2.5ms, write time 15.1ms, max retries 0
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 23195ms
      === MainDDARing ===
      Scheduled moves: 11, completed moves: 11, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Segments left: 0
      Aux is idle in state(s) 0
      === Network ===
      Slowest loop: 45.72ms; fastest: 0.00ms
      Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      - WiFi -
      WiFi flash size 4194304, free heap 18384
      Socket states: 0 4 0 0 0 0 0 0
      Extruder 2 sensor: ok
      Extruder 3 sensor: ok
      === DueX ===
      Read count 1, 0.74 reads/min
        Phaedrux Moderator @HtRabbit last edited by
        @htrabbit said in Extruder slows to a crawl:
        Is this during a print? or when?
        Can you show a video of the behaviour?
        If it's during a print can you share the gcode file?
        • HtRabbit
          @phaedrux
          this happens during print initially, and then remains in this error state till power cycle
          file is too big to upload(5mb) tried to zip and rar it still wont upload(server error
            You can rename the zip file as .txt and upload it.
            HtRabbit 1 Reply Last reply Reply Quote 0
            • HtRabbit
              HtRabbit @Phaedrux last edited by
              @phaedrux
              rename to .zip
              single_joycon_grip.txt
              • HtRabbit
                HtRabbit @HtRabbit last edited by
                it has happened to other files as well, this one was failing after layer 30ish and i stopped print at layer 47,
                while it was in error state i tested a new stepper , and a new cable, neither fixed the issue.
                the steppper was activated,(could not manually turn the stepper by hand. ) it was turning just super slow, could barely detect movement.
                power cycled duet and it was like it never happened.
                could cura be getting funky? hmmm.
                  dc42 administrators @HtRabbit last edited by
                  @htrabbit when it happens again, please send the following commands, without parameters;
                  M92
                  M350
                  M221
                  Then check that the M92 and M350 values reported for the extruder are the same values that you configured in config.g and that M221 still reports the extrusion factor as 100%.
                  If you power off/on and reprint the same file, does the problem recur at exactly the same place in the print?
                    Can you send M98 P"config.g" and see if there are any errors?
                    Does it still happen with logging turned off?
                    • HtRabbit
                      HtRabbit @dc42 last edited by
                      @dc42 if i reprint it does not happen in the same spot , if at all.
                      i will check what you asked when it happens again. thanx
                      i will report back here.
                      • HtRabbit
                        HtRabbit @Phaedrux last edited by HtRabbit
                        @phaedrux the heater 0 line is weird, and i dont use logging....i think
                        	M98 P"config.g"
                        HTTP is enabled on port 80
                        FTP is enabled on port 21
                        TELNET is enabled on port 23
                        Error: Invalid use of P parameter
                        Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                        Here is my config.g
                        ;M551 P"2001"                                       ; set password
                        M586 P1 S1                                         ; S0 disable FTP, S1 Enable
                        ;       Drives
                        ;Extruders
                        ;X axis
                        ;Y axis
                        ;Z axis
                        ;      End Drives
                        ;Filament Sensors
                        ; Heater Ex 1
                        ; Heater Ex 2
                        ; Heater Ex 3
                        ; Heater Ex 4
                        ; End Heaters
                        ;       Tools
                        ; nozzle map
                        ;    _______
                        ;   | 4 | 2 |
                        ;     front
                        ;Tool 1
                        ;Tool 2
                        G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
                        ;Tool 3
                        M563 P2 D2 H3 F0:1                                 ; define tool 2
                        G10 P2 X-19.75 Y0 Z0                                  ; set tool 2 axis offsets
                        G10 P2 R0 S0                                       ; set initial tool 2 active and standby temperatures to 0C
                        ;Tool 4
                        M563 P3 D3 H4 F0:1                                 ; define tool 3
                        G10 P3 X-19.6 Y-20.4 Z0                                    ; set tool 3 axis offsets
                        G10 P3 R0 S0                                       ; set initial tool 3 active and standby temperatures to 0C
                        ; End Tools
                        M570 H1 P20 T20 S5
                        M570 H2 P20 T20 S5
                        M570 H3 P20 T20 S5
                        M570 H4 P20 T20 S5
                        i found a log file for the event, see below
                        power up + 00:03:22 HTTP client 192.168.0.100 login succeeded
                        2021-05-10 17:40:44 Date and time set at power up + 00:03:22
                        2021-05-10 17:50:50 HTTP client 192.168.0.100 login succeeded
                        2021-05-10 17:50:58 HTTP client 192.168.0.100 disconnected
                        2021-05-10 17:50:58 Started printing file 0:/gcodes/single_joycon_grip+_Txy-PLA-02mm-@17-50.gcode
                        2021-05-10 17:51:50 Leadscrew adjustments made: -0.144 -0.091, points used 2, (mean, deviation) before (-0.116, 0.014) after (0.000, 0.000)
                        2021-05-10 17:51:50 Warning: Skipping grid point (0.0, 0.0) because Z probe cannot reach it
                        2021-05-10 17:51:51 Warning: Skipping grid point (75.0, 0.0) because Z probe cannot reach it
                        2021-05-10 17:51:51 Warning: Skipping grid point (150.0, 0.0) because Z probe cannot reach it
                        2021-05-10 17:51:51 Warning: Skipping grid point (225.0, 0.0) because Z probe cannot reach it
                        2021-05-10 17:51:51 Warning: Skipping grid point (300.0, 0.0) because Z probe cannot reach it
                        2021-05-10 17:53:10 20 points probed, min error 0.013, max error 0.400, mean 0.179, deviation 0.120
                        Height map saved to file 0:/sys/heightmap.csv
                        2021-05-10 18:27:25 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:27:44 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:28:27 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:28:48 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:29:29 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:29:50 Warning: motor phase A may be disconnected reported by driver(s) 7
                        2021-05-10 18:29:50 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:30:34 Warning: motor phase A may be disconnected reported by driver(s) 7
                        2021-05-10 18:30:34 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:31:08 Warning: motor phase A may be disconnected reported by driver(s) 7
                        2021-05-10 18:31:08 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:31:38 Warning: motor phase A may be disconnected reported by driver(s) 7
                        2021-05-10 18:31:38 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:31:56 Warning: motor phase A may be disconnected reported by driver(s) 7
                        2021-05-10 18:31:56 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:32:17 Warning: motor phase A may be disconnected reported by driver(s) 7
                        2021-05-10 18:32:17 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:34:22 Warning: motor phase A may be disconnected reported by driver(s) 7
                        2021-05-10 18:34:22 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:34:40 Warning: motor phase A may be disconnected reported by driver(s) 7
                        2021-05-10 18:34:40 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:35:21 Resume state saved
                        2021-05-10 18:35:21 Extruder 2 reports no filament
                        2021-05-10 18:35:21 Warning: motor phase A may be disconnected reported by driver(s) 7
                        2021-05-10 18:35:21 Warning: motor phase B may be disconnected reported by driver(s) 1 7
                        2021-05-10 18:35:26 Printing paused at X134.3 Y165.3 Z9.7
                        2021-05-10 18:37:20 Warning: motor phase B may be disconnected reported by driver(s) 7
                        2021-05-10 18:47:00 Cancelled printing file 0:/gcodes/single_joycon_grip+_Txy-PLA-02mm-@17-50.gcode, print time was 0h 44m
                        Phaedrux dc42 2 Replies Last reply Reply Quote 0
                          2021-05-10 18:34:40 Warning: motor phase A may be disconnected reported by driver(s) 7 2021-05-10 18:34:40 Warning: motor phase B may be disconnected reported by driver(s) 7
                          Seems like a wiring issue maybe?
                            @htrabbit you have 4 extruders configured, on drivers 3, 4, 6 and 7. Which extruder is failing? Is it the one connected to driver 7, which is reporting the phase errors?
                            • HtRabbit
                              @phaedrux @dc42
                              the phase errors is me unplugging and testing wiring, and inserting a known good stepper in. the error will occur on whatever extruder is active.
                                @htrabbit don't unplug the stepper while it's powered. You'll damage the driver. 😳
