Hotend fan direction?
which way should the hotend fan blow? Towards the hotend or suck air over the hotend?
P.S: I got dual drive extruder with Mosquito hotend -
@user3d
Towards -
@user3d normally the fan blows towards the hotend.
But when your fans for the dual setup are vis-à-vis, then i think it is better one fan blows towards the hotend and the other one is sucking over the hotend. To get a better airflow... -
@cosmowave @tecno
Thank you -
Thats my current setup, but I'm getting heater faults at hotend whose fan sucks air that is toward hotend. Hence the doubt !
@user3d said in Hotend fan direction?:
have you tried to make a pid-tuning?
@cosmowave Yup! I've even noticed that that side of hotend takes longer to heat up and clogging issue is there too!
Given how efficient the mosquito is I'm surprised you're getting clogging. Maybe post a photo of your assembly?
@user3d Recently I in an enclosure I had the air from copperhead hotend blowing over my ABS part and causing warp, so I found out that the small 25 mm slice fan (same for mosquito and copperhead) blows a lot of air to the side direction. The fastest fix was to rotate the fan to suck with small shroud to point air up. Worked great for drafts, but I started to get partial clogs.
@user3d
I've made fan shrouds from color-changing PLA, just to see if there is any difference in fan-direction.
The color changes from orange to yellow above 33°C
I could see changes with different filament temps, but not related to fan direction.
