Extruder dont work
My extruder does not work.
I tested the extruder motor on the X shaft connection without filament, then the engine works fine.
I connect the extruder to the drive3 E0 and make a print, the extruder engine does not work.
How can I fix the problemWim
; Configuration file for Duet WiFi (firmware version 1.17)
; generated by RepRapFirmware Configuration Tool on Thu Aug 17 2017 16:03:38 GMT+0200 (West-Europa (zomertijd)); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
M555 P2 ; Set firmware compatibility to look like RepRapFirmare
M208 X290 Y300 Z350 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; Define active high microswitches
M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
M557 X25:175 Y25:175 S20 ; Define mesh grid; Drives
M350 X128 Y128 Z128 E128 I0 ; Configure microstepping without interpolation
M92 X640 Y640 Z2040 E420 ; Set steps per mm
M203 X12000 Y12000 Z1200 E3000 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z100 E5000 ; Set accelerations (mm/s^2)
M906 X855 Y855 Z855 E855 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M143 S260 ; Set maximum heater temperature to 260C
M305 P0 T100000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4725 C0 R4700 ; Set thermistor + ADC parameters for heater 1; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PMijn 3Dprinter ; Set machine name
M551 Pxxxxxxx ; Set password
M552 S1 ; Enable network
M587 Slinksys P"xxxxx" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings are not configured
T0 ; Select first tool
What happens when you try and extrude? does the stepper motor move at all?
The engine rattles. It seems he makes 1 step forward and 1 step reserve. enz.
Without filemant
Are you using relative extrusion?
Sounds like the wiring to the stepper is wrong. Did you check the poles?
