setting Retraction after restart
hi, after restarting my printer i lost the retraction setting
however I have M207 S4.0 F5000 Z0.5 in config.g and also in filament config,
but after a restart I have 2mm retraction at 16mm / s
what did I miss? -
please post your config.g file
Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Aug 27 2020 18:42:39 GMT+0200 (heure d’été d’Europe centrale) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Predator" ; set printer name M665 L440.000 R226 B185.0 H456 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 A0.00 B0.00 ; put your endstop adjustments here, or let auto calibration find them ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S1 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80 Y80 Z80 E498.8; set steps per mm M566 X1000 Y1000 Z1000 E1000 ; set maximum instantaneous speed changes (mm/min) M203 X12000 Y12000 Z12000 E1200 ; set maximum speeds (mm/min) M201 X3000 Y3000 Z3000 E3000 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Retraction M207 S4.0 F5000 Z0.5 ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop ; Z-Probe M558 P5 C"e0stop" H8 F120 T6000 ; set Z probe type to switch and the dive height + speeds M558 H10 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved G31 P500 X0 Y0 Z17.0 ; set Z probe trigger value, offset and trigger height M557 R175 S20 ; Define mesh grid G29 S1 ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4300 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S80 ; set temperature limit for heater 0 to 80C M308 S1 P"e0temp" Y"thermistor" T100000 B4300 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Custom settings are not configured M572 D0 S0.1 ; Pressure Advance ;M591 D0 P2 C"e1stop" S0 ; Activate filament sensor M404 N1.75 ; Set for print monitor M592 D0 A0.07772 B-0.00029 ; Nonlinear extrusion. Set parameters for extruder drive 0 ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501 -
@bastien said in setting Retraction after restart:
would say you should define your tool first and then add the retract settings add :
after the tool definition
I will test, but normally the setting of the filament config will have to be taken care of on T0 then that the filament is loaded
Even with T0 before, the settings are not loaded, I also tested to keep only the filament config, same result after a restart,
while waiting to find a solution, I will put it in my macro, start print, so as not to forget -
@bastien You misunderstood me. You have defined the settings for the retract in your configuration in line 33. Your tool is first defined from line 68 onwards so put your M207 after line 71
@siam it works, in config after line 68, thanks
