    Mesh Leveling ? Auto Bed compensation?
    Using Duet Controllers
    • Hiroakiundefined
      Hiroaki
      Hello.
      My printer has four lead screws for Z axis and a BL touch.
      So it's easily possible to level the bed automatically.
      Today when I was printing I noticed that the Z motors are moving while printing each layer.
      It seems that the Z motors are adjusting the level according to BED's warp.
      I actually don't understand the difference between Auto bed compensation and mesh grid compensation. I tried to find the manual for Auto bed compensation and mesh grid compensation, but I couldn't.
      Can anybody let me know where I can find the manual for these?
      • SIamundefined
        SIam
        The bed compensation aligns your print bed evenly.
        And mesh compensation compensates for unevenness in the print bed during printing so the z axis will move when you print
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        Hiroakiundefined 1 Reply Last reply Reply Quote 1
        • Hiroakiundefined
          Hiroaki @SIam
          @siam Oh, That's great!
          But one thing I wonder is
          OK, with mesh compensation, the machine compensates, but until the top ?
          eg, If I print a cube with warped bed, the top of the cube will be also warped then ?
          SIamundefined engikeneerundefined 3 Replies Last reply Reply Quote 0
          • SIamundefined
            SIam @Hiroaki
            @hiroaki ähm no let's say when your bed is on the right side 0.5mm higher as your left side. When you now print a cube then the Mesh will compensate this so that you will get an unwarped cube at the end
            • engikeneerundefined
              engikeneer @Hiroaki
              @hiroaki by default, mesh compensation will apply up the full height of the object, but you can set up Mesh Compensation Taper (M376) so the amount of compensation applied reduces as you go up the part. You can read more about it here:
              https://duet3d.dozuki.com/Wiki/Gcode#Section_M376_Set_bed_compensation_taper
              i3 clone with a bunch of mods
                engikeneer @Hiroaki
                @hiroaki Here is the guide on using mesh compensation:
                https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
                And here is the guide for using automatic bed leveling with independant Z-motors:
                https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                • Hiroakiundefined
                  Hiroaki @engikeneer
                  @engikeneer Thank you so much. I will check the guide!!!
