    DuetWifi 2 and LIS3DH wiring
    28
    4.3k
    • nurooundefined
      nuroo
      This post got me up and running on a railcore. Had to change some pins in config setup to use daughter board spi. Im getting data thru the plugin as well. Looking forward to rrf 3.4
      • muleundefined
        mule
        Just a quick info:
        The picture of the adafruit LIS3DH on https://duet3d.dozuki.com/Wiki/Accelerometers is misleading because the V3.3 from the duet is connected to 3Vo (Output) instead of the VIN (Input) pin. Maybe it is better to remove it.
        droftartsundefined 2 Replies Last reply Reply Quote 1
          droftarts administrators @mule
          @mule Thanks. Do you mean this one? https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/Y1YiEWyeIEP5qi4Q
          I see what you mean. I'll try and get @dc42 to take another picture. For now I'll put a note on the page.
            @mule From @dc42:
            connecting +3.3V from Duet to 3V0 is correct. In practice, connecting it to Vcc works too.
            Connecting to Vcc would be necessary if we were using 5V supply
            So I'll leave as is.
            • muleundefined
              mule
              For me it did not work to connect +3.3V from duet to the output of the adafruit board. Maybe there are different boards with different layouts being sold by adafruit?
              nick9one1undefined 1 Reply Last reply Reply Quote 0
              • nick9one1undefined
                nick9one1 @mule
                Glad my diagram helped!
                I never got it working on the Duet2 WiFi, but have recently upgraded to a 3 Mini 5+ and trying again...
                https://forum.duet3d.com/topic/25904/mini-3-5-and-lis3dh-wiring/2
                • MrTundefined
                  MrT
                  HI , I also have a duet wifi2 and just got my self an LIS3DH to try out, I was wondering if it was possible to use other pins then the temp board pins as it is in use already .
                  I do not use a screen or so .
                  thanks in advance for the help
                  Best Regards
                  Manuel
                    jay_s_uk @MrT
                    @mrt no, you need to use hardware SPI pins. You can however use an accelerometer and 1 temp daughterboard. Just use the CS2 and CS3 pins
