    Help with fault - Print auto-paused due to low voltage
    • Sculpt Fabricator
      Sculpt Fabricator last edited by
      Ok I got this fault about half way through a 80 hour print. X and Y motors try
      to run but don't move. Just a small vibration like they are trying to move.
      z and extruder motors run when print is paused. Right now it is just hovering
      off the top of the print.
      Not sure how to go forward
      Thanks for any help -
      config.g
      M122.txt
        ;Generated by Modix - 1.3
        ;Modix Big-60, Dual Printhead
        G90                                          		; Send absolute coordinates...
        M83                                          		; ...but relative extruder moves
        M550 P"Big-60"                              	; Set machine name
        ;M551 P"my-password"                  	; Set password (optional)
        M552 S1                                        	; Enable network
        M586 P0 S1                                   	; Enable HTTP
        M586 P1 S0                                   	; Disable FTP
        M586 P2 S0                                   	; Disable Telnet
        M569 P0 S1                                                       ; Physical drive 0 goes forwards. X-Axis.
             ;M569 P1 S0                                                       ; Physical drive 1 goes backwards. Y-Axis.
             ;M569 P2 S0                                                       ; Physical drive 2 goes backwards. Z-Axis.
        M569 P3 S1                                                       ; Physical drive 3 goes forwards. E0-Extruder.
        M569 P4 S0                                                       ; Physical drive 4 goes backwards. E1-Extruder.
        ; DUEX5 BOARD
        M569 P5 S0                                                       ; Physical drive 5 . Y-Axis
        M569 P6 S0                                                       ; Physical drive 6 . Z LEFT REAR.
        M569 P7 S0                                                       ; Physical drive 7 . Z LEFT FRONT
        M569 P8 S0                                                       ; Physical drive 8 . Z RIGHT FRONT
        M569 P9 S0                                                       ; Physical drive 9 . Z RIGHT REAR
        M584 X0 Y5 Z6:7:8:9 E3:4
        M671 X-10:580:-10;580 Y580:-10:-10:580 S10
        M350 X16 Y16 Z16 E16 I1                                 ; Configure microstepping with interpolation
        M92 X100.00 Y100.00 Z2000.00 E686:700                   ; Set steps per mm
        M566 X300 Y500 Z100.00 E120.00                          ; Set maximum instantaneous speed changes (mm/min)
        M203 X18000.00 Y18000.00 Z300.00 E1200.00               ; Set maximum speeds (mm/min)
        M201 X1000 Y1000 Z100.00 E250.00                        ; Set accelerations (mm/s^2)
        M204 P500 T1000                                         ; Set print and travel accelerations  (mm/s^2)
        M906 X1800 Y1800.00 Z2400.00 E800:800 I40               ; Set motor currents (mA) and motor idle factor in per cent
        M84 S40                                                 ; Set idle timeout
        M208 X0 Y0 Z-0.05 S1		                         ; Set axis minima
        M208 X600 Y580 Z649 S0                                   ; Set axis maxima
        M574 X1 Y2 S1                                                 ; Set active low and disabled endstops
        M574 Z2 S2                                                      ; Set endstops controlled by probe
        M307 H3 A-1 C-1 D-1                                     ; Disable heater on PWM channel for BLTouch
        M558 P9 H5 F120 T6000 A1 R0.7                   ; Set Z probe type to bltouch and the dive height + speeds
        G31 P500 X-30 Y0 Z1.57                        ; Set Z probe trigger value, offset and trigger height(Z-Offset)       **** Z height change + 0.29 ****
        M557 X0:560 Y0:580 S35:36.25                         ; Define mesh grid. 100 Points
        M376 H10			                     ; Height (mm) over which to taper off the bed compensation
        ;E0:_________________________________________________
        M305 P0 T100000                     	              ; Set thermistor + ADC parameters for bed heat
        M140 S55 R0                                           ; bed heater on
        M143 H0 S125                                          ; set the maximum bed temperature to 125C
        M307 H0                                               ; report the process parameters for heater 0
        ;E1:_________________________________________________
        M305 P1 X200                      	             ; Set thermistor + ADC parameters for heater 1
        M143 H1 S450                                         ; Set temperature limit for heater 1 to 450C
        M307 H1 A# C# D# V# S0.25  B0                         ; PID calibration
        ;E2:________________________________________________
        M305 P2 X201                     	             ; Set thermistor + ADC parameters for heater 2
        M143 H2 S450                                         ; Set temperature limit for heater 2 to 450C
        M307 H2 A# C# D# V# S0.25  B0                         ; PID calibration
        ;E4: _______________________________________________
        M141 H5              			             ; Heater H5 is the Chamber Heater
        M143 H5 S120					     ; Set max chamber temp to 120c
        M305 S"Chamber temp" P5 T100000 B4267 C0 	     ; heater 5 is monitored by a 100K thermistor with B=3988
        M307 H5 			                     ; report the process parameters for heater 5
        M106 P0 S0 I0 F500 H-1                        ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S0 I0 F500 H-1                       ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P2 I-1 ;LED
        M106 P3 S1                                    ; Set fan 3 value for bed relay to on
        M563 P0 S"E0 Main" D0 H1 F0                      ; Define tool 0
        G10 P0 X0 Y0 Z0                                   ; Set tool 0 axis offsets
        G10 P0 R0 S210                                ; Set initial tool 0 active and standby temperatures to 0C
        M563 P1 S"E1 Support" D1 H2 F1                     ; Define tool 1
        G10 P1 X0 Y65 Z0                             ; Set tool 1 axis offsets   Y-2 moves filament 2mm to back of machine     X-1 moves filament 1mm to the right
        G10 P1 R0 S210                               ; Set initial tool 1 active and standby temperatures to 0C
        ; Automatic power saving
        M911 S22.5 R29.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                      ; Set voltage thresholds and actions to run on power loss. Power Failure Pause
        ; Custom settings
        ;M564 H0 S0                                                     	; Negative movements are allowed
        G29 S1                                                             	; Load the height map from file and activate bed compensation
        M915 P1 S4 H400 F1 R2			; Stall detection. For Y motor. Set to run rehome.g
        M591 D0 P1 C3 S1			         	; Regular filament sensor for E0
        M591 D1 P1 C4 S1			        	; Regular filament sensor for E1
        ;M581 E2 S1 T0 C0                                            	; Optional external switch for emergency stop
        ;M593 F40                                                        	; Cancel ringing at 40Hz
        ;M592 D0 A0.01 B0.0005 L0.25                           ;The amount of extrusion requested is multiplied by (1 + min(L, A*v + B*v^2)) where v is the requested extrusion speed (calculated from the actual speed at which the move will take place) in mm/sec.
        ;M592 D1 A0.01 B0.0005 L0.25                           ;The amount of extrusion requested is multiplied by (1 + min(L, A*v + B*v^2)) where v is the requested extrusion speed (calculated from the actual speed at which the move will take place) in mm/sec.
        M501
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later + DueX5
        Board ID: 08DLM-996RU-N85T0-6J1D4-3SJ6K-TAVZR
        Used output buffers: 3 of 24 (14 max)
        Static ram: 25712
        Dynamic ram: 94208 of which 0 recycled
        Exception stack ram used: 496
        Never used ram: 10656
        Tasks: NETWORK(ready,628) HEAT(blocked,808) DUEX(suspended,160) MAIN(running,3728) IDLE(ready,160)
        Owned mutexes:
        Last reset 49:08:13 ago, cause: power up
        Last software reset at 2021-05-12 16:56, reason: User, spinning module GCodes, available RAM 10720 bytes (slot 2)
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04417000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
        Error status: 8
        Free file entries: 9
        SD card longest block write time: 107.9ms, max retries 0
        MCU temperature: min 26.7, current 37.7, max 39.8
        Supply voltage: min 22.5, current 23.7, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: standstill, SG min/max 0/689
        Driver 3: standstill, SG min/max 0/1023
        Driver 5: standstill, SG min/max 0/445
        Driver 6: standstill, SG min/max 0/1023
        Driver 7: standstill, SG min/max 0/1023
        Driver 8: standstill, SG min/max 0/1023
        Driver 9: standstill, SG min/max 0/1023
        Date/time: 2021-05-22 06:17:34
        Slowest loop: 60.68ms; fastest: 0.07ms
        Hiccups: 0, FreeDm: 160, MinFreeDm: 82, MaxWait: 339336ms
        Bed compensation in use: mesh, comp offset -0.270
        === DDARing ===
        Scheduled moves: 1298601, completed moves: 1298601, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
        Bed heaters = 0 -1 -1 -1, chamberHeaters = 5 -1
        Heater 0 is on, I-accum = 0.0
        Heater 1 is on, I-accum = 0.2
        Heater 5 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is idle in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 109.27ms; fastest: 0.00ms
        HTTP sessions: 2 of 8
        - WiFi -
        Network state is running
        WiFi firmware version 1.23
        WiFi MAC address ec:fa:bc:5b:41:b9
        WiFi Vcc 3.38, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 25216
        WiFi IP address 192.168.5.142
        WiFi signal strength -72dBm, reconnections 0, sleep mode modem
        === Filament sensors ===
        Extruder 0 sensor: ok
        Extruder 1 sensor: ok
          What status does the DWC show? Paused?
          Can you try and resume?
          Could have been a brown out on the psu with min voltage 22.5, your M911 sets that as the pause threshold
          Sculpt Fabricator Juris 2 Replies Last reply Reply Quote 0
          • Sculpt Fabricator
            Sculpt Fabricator @Phaedrux last edited by
            @phaedrux It say's " Paused "
            When I resume it just trys to run the xy motors and then runs the
            z down.
            I will shut down the machine and restart at that print height and see
            if it still happens.
              Well the print progress should have been saved as if it was a power outage, so you should be able to resume it following that procedure.
              https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
              • Juris
                Juris @Phaedrux last edited by
                @phaedrux How do I make the auto pause threshold lower?
                • droftarts
                  droftarts administrators @Juris last edited by
                  @juris M911 S parameter. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes/M911
