    Bigtreetech smart filament sensor trigger2.g or trigger3.g
    • jsinicro
      jsinicro last edited by
      Hi
      Just getting to test this sensor it seemed like a good buy, but I've connected and seen other posts on here on the settings but this is not working for me. Noting happens when filament runs out. I have a simple trigger#.g to just display a message when triggered but no message. This is my config:
      ; Fillament sensor
      M591 D0 P7 C"1.io5.in" L7 R50:200 E15 S0 ;Bigtree smart filament moniter
      M591 D1 P7 C"3.io5.in" L7 R50:200 E15 S0 ;Bigtree smart filament moniter 55%-150% of 7 counts over a distance of 22mm
      M581 P"1.io5.in" T2 C0
      M581 P"3.io5.in" T3 C0
      here is the trigger#.g code
      M291 P"Please load fillamet, or check fillament status on RIGHT TOWER" R"Fillament Runout Sensor Trigger"  S2 ; Display message
      any help, please.
      Thankyou.
      Nurgelrot 1 Reply Last reply Reply Quote 0
      • Nurgelrot
        Nurgelrot @jsinicro last edited by
        @jsinicro How are you trying to make the test event occur.? Mine will only trigger when I'm actually printing.
        jsinicro 1 Reply Last reply Reply Quote 0
        • jsinicro
          jsinicro @Nurgelrot last edited by
          @nurgelrot to test it I cut the filament, activate and heat up the hot end, and then extrude till all filament runs out. which should pop up the message. I am using RRF3.3RC2.
            S0 is disable filament monitoring. And I think it's only going to be monitored during a print from SD. So try creating a basic gcode file that will extruder and then print that rather than doing it manually.
            https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_RotatingMagnetVersion#Section_RepRapFirmware_3_x
            • jsinicro
              @phaedrux OK Thx, I did have S1 before.
