    Trinamic 5160 for Nema23 motor with 5A current phase
    195
    • Oleksii_Solntsev
      Oleksii_Solntsev last edited by
      Hi everyone!
      I would be grateful for your help in choosing motors for our new printer that we want to launch on Duet3D)
      We assemble our printer on ready-made CCM belt-driven modules.
      Can native mainboard drivers Trinamic 5160 (4.45A RMS, 6.3A peak) handle the 57CM3 Nema23 stepper motors? (specification below)
      Thanks for support!
      Best regards,
      Oleksii
      Luke'sLaboratory 1 Reply Last reply Reply Quote 0
      • Luke'sLaboratory
        Luke'sLaboratory @Oleksii_Solntsev last edited by
        @oleksii_solntsev
        Hi there!
        Without knowing 1) whether or not that current is either RMS or Peak on your datasheet and 2) What kinematics it is, plugging those specs into the EMF calculator it looks like you're good to go for at least moderate speeds.
        Luke
        http://lukeslab.online
        Oleksii_Solntsev 1 Reply Last reply Reply Quote 0
        • Oleksii_Solntsev
          Oleksii_Solntsev @Luke'sLaboratory last edited by
          @luke-slaboratory
          Hi dear Luke!
          Thank you so much!
          We have parallel kinematics.
          https://smartzavod.com/
          Here is the landing page of our startup)
          And I tried to figure out all Parameters (like belt characteristics) and made the calculation.
          but I definitely lack the expertise to understand the output and make any conclusion. Could you recommend a resource where I could read more about this?)
          but if simple.
          if we use our printer at speeds up to 400mm / s, then according to this calculation the driver should withstand?
          Thank you.
          dc42 o_lampe 2 Replies Last reply Reply Quote 0
            dc42 administrators @Oleksii_Solntsev last edited by
            @oleksii_solntsev I think something is wrong with the input data. 15mm belt pitch does not make sense unless you are printing houses or other large structures.
            Luke'sLaboratory Oleksii_Solntsev 2 Replies Last reply Reply Quote 0
            • Luke'sLaboratory
              Luke'sLaboratory @dc42 last edited by
              I was thinking the same thing, that is a long-ass belt pitch.
              Luke
              • gallaghersart
                gallaghersart last edited by
                Noob ?
                Is the EMF Calculator something online? can I get link?
                thanks!
                `mike
                o_lampe 1 Reply Last reply Reply Quote 0
                • o_lampe
                  o_lampe @gallaghersart last edited by
                  @gallaghersart
                  It's on the same page as the configurator tool, unfortunately it's not very well documented.
                  Although they've changed 'max. speed' to requested max. speed.
                  After filling in all known numbers, this value is the one to play with until the resulting back EMF values are close to the input voltage.
                  Then you can play with the motor current value and learn that more current means lower max. speed. A real eye opener!
                  • Oleksii_Solntsev
                    Oleksii_Solntsev @dc42 last edited by Oleksii_Solntsev
                    @dc42 @Luke-sLaboratory
                    Yes. I definitely made a mistake.
                    We use HTD 3M 15 PU belt. And the EMF calculations looks so..
                    how can i interpret the results i got?
                    Thanks!
                    Luke'sLaboratory dc42 2 Replies Last reply Reply Quote 0
                    • Luke'sLaboratory
                      @oleksii_solntsev
                      I'd expect that you're going to have a good time printing, assuming you keep your top speeds below all of these numbers.
                      Luke
                        You've also selected x256 microstepping, which isn't reasonable or necessary. Stick to x16 and allow the drivers to internally interpolate to x256.
                        • o_lampe
                          o_lampe @Luke'sLaboratory last edited by
                          @luke-slaboratory said in Trinamic 5160 for Nema23 motor with 5A current phase:
                          Based on the EMF numbers, you are right. But a 3mm pitch/25 teeth pulley on a Nema23 motor wont run smooth enough for good prints.
                          That's only 42.67 steps/mm@16 microsteps
                          @Oleksii_Solntsev
                          I'd try a smaller pulley, it will still be fast enough.
                          400mm/s isn't max. achievable speed, since the back-EMF is 4-5V below supply voltage.
                          • o_lampe
                            o_lampe @Phaedrux last edited by
                            @phaedrux said in Trinamic 5160 for Nema23 motor with 5A current phase:
                            I thought, that Duet3 boards can interpolate on any microstep setting? What you suggested is true for Duet2 drivers, right?
                            jay_s_uk 1 Reply Last reply Reply Quote 0
                            • o_lampe
                              o_lampe @Oleksii_Solntsev last edited by
                              @oleksii_solntsev said in Trinamic 5160 for Nema23 motor with 5A current phase:
                              In that case you have to calculate steps/degree, which isn't available yet in the EMF calculator.
                              Right, @dc42 ?
                              • jay_s_uk
                                jay_s_uk @o_lampe last edited by
                                @o_lampe they can interpolate at any setting but what @Phaedrux is implying is that anything above x16 doesn't make a difference anyway and theres really no need to stress the CPU
                                Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32F4 port of RRF
                                • o_lampe
                                  o_lampe @o_lampe last edited by
                                  @o_lampe said in Trinamic 5160 for Nema23 motor with 5A current phase:
                                  Right, @dc42 ?
                                  I'm confused. Their landing page looks like they use Delta kinematics, but with towers at an angle??
                                    dc42 administrators @Oleksii_Solntsev last edited by dc42
                                    @oleksii_solntsev you will need to calculate the maximum linear carriage speed that you need for your printer to achieve the desired XY speed. Our EMF calculator does that for regular delta printers, but not for your inclined tower kinematics.
                                    One thing that worries me about your kinematics is that the Z resolution will vary with Z height, being (I think) worse at low heights and better higher up. Are you certain that you have sufficient Z resolution? Don't rely on microstepping to increase resolution, because microsteps are not necessarily uniform.
