    Hybrid 3d printer.
    My Duet controlled machine
    • Hoops40
      Hoops40 last edited by
      Good evening this is my first post.
      In the middle of building a large hybrid 3d printer.
      Pellet extruder, spindle and 3d scanner manual tool changer.
      When changing tools I want to use relays to switch the power and signals on and off at the connector.
      Do you think this will cause any problems with the board.
      mrehorstdmd 1 Reply Last reply Reply Quote 0
      • mrehorstdmd
        mrehorstdmd @Hoops40 last edited by
        @hoops40 Which connector?
        You usually want to keep a hot-end cooling fan working until the temperature has dropped before killing power to the controller...
        Hoops40 1 Reply Last reply Reply Quote 0
        • Hoops40
          Hoops40 @mrehorstdmd last edited by
          @mrehorstdmd using liquid cooling, tools will only change once the unit is cooled.
          Just want to make sure the control board does not have a fit when I disconnect the tool.
          o_lampe 1 Reply Last reply Reply Quote 0
          • o_lampe
            o_lampe @Hoops40 last edited by o_lampe
            @hoops40 said in Hybrid 3d printer.:
            Use freewheel diodes with the relais and connect them to unused heater output pins.
            I'm switching lots of solenoids with separate driver boards (TB6612/ 1$ each). That way I can use any GPIO pin and the Duet board is safe.
            • Hoops40
              Hoops40 @o_lampe last edited by
              @o_lampe thank you I will try that.
              Might be a while, should start wiring in a few weeks.
